Windows 7 BSoD after exiting Thief. Memory Management Error
imjustademo
Member
I attached the zip folder for the diagnostics and I'll include the html file from rammon along with screenshots from cpuid..
BugCheck 1A, {31, fffffa8006fc5d70, fffff880132d3000, fffff8a0053a229c}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::NNGAKEGL::`string'+7171 )
Followup: MachineOwner
Bugcheck 1A is often associated with faulty RAM as the bugchecks actual meaning is a severe memory management...
Hey Kemical. Just upgraded and went back to win7 for now. I have a fresh install and my "looking for updates" is stuck. Currently the updates I do have are these Link Removed I think it grabbed some but it's stuck. I tried a couple things but I feel like you'd give me a better answer.
I tried the third option on that link I gave you and it seems like It might have worked. It shows another update and gives me 1 option in the update history so at least I'm getting somewhere.
Nvm it still gets stuck on the checking for updates.
Try running a SFC scan. Open an admin command prompt and type:
sfc /scannow
Press enter and await results.
Does your Win 7 install have the Service pack 1 update? If not you can download a copy here:
Hey sorry to put you through the trouble. I talked to a Microsoft agent and just went back to windows 10. They had troubles too. I didn't try that service pack, I wonder if it would of helped. Thanks though man, you're a king.
