Oberst Hajj
- Joined
- Apr 19, 2014
I corrected a BSoD issue related to my vid card drivers (looks like that or a similar issue might be back now) and then was just getting random shutdowns/reboots. (that thread has some background info in it that might be helpful) After trying to sort those out with out any success, the BSoD started coming back. So, I'm starting this thread in this section of the forum to see if anyone can help.
I've ran the over night memory test (7 passes) and no errors were returned. Below is the WhoCrashed report from today:
System Information (local)
computer name: COLHAJJ-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
Hardware: GA-MA770T-UD3P, Gigabyte Technology Co., Ltd.
CPU: AuthenticAMD AMD Phenom(tm) II X4 955 Processor AMD586, level: 16
4 logical processors, active mask: 15
RAM: 6440869888 total
VM: 2147352576, free: 1926545408
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 4/26/2014 2:52:22 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042614-19422-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF880131212E6)
Bugcheck code: 0x50 (0xFFFFF100079F2C00, 0x1, 0xFFFFF880131212E6, 0x7)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 335.23
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 335.23
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 335.23 , NVIDIA Corporation).
Google query: NVIDIA Corporation PAGE_FAULT_IN_NONPAGED_AREA
On Sat 4/26/2014 2:34:31 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042614-19032-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0xA (0x1, 0xD, 0x1, 0xFFFFF80002ECF1F4)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sat 4/26/2014 2:32:37 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042614-20529-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF80002ED3740)
On Sat 4/26/2014 5:42:29 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042514-22152-01.dmp
Bugcheck code: 0xA (0xFFFFF880270E0BCD, 0xD, 0x0, 0xFFFFF80002EC7128)
On Sat 4/26/2014 5:32:09 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042514-19078-01.dmp
Bugcheck code: 0xBE (0x74F02450, 0x91000013E2CE025, 0xFFFFF8800A0B0A90, 0xA)
Error: ATTEMPTED_WRITE_TO_READONLY_MEMORY
Bug check description: This is issued if a driver attempts to write to a read-only memory segment.
On Sat 4/26/2014 4:00:28 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042514-22510-01.dmp
Bugcheck code: 0xA (0x468, 0x2, 0x0, 0xFFFFF80002EC0758)
On Sat 4/26/2014 1:32:26 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042514-21808-01.dmp
This was probably caused by the following module: ndis.sys (ndis+0xBE4F1)
Bugcheck code: 0xA (0xF, 0x2, 0x1, 0xFFFFF80002FFDE83)
file path: C:\Windows\system32\drivers\ndis.sys
description: NDIS 6.20 driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sat 4/26/2014 1:18:16 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042514-19936-01.dmp
Bugcheck code: 0xA (0xA8, 0x2, 0x1, 0xFFFFF80002E9B476)
On Fri 4/25/2014 11:09:43 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042514-21372-01.dmp
Bugcheck code: 0xA (0x468, 0x2, 0x0, 0xFFFFF80002E88758)
On Fri 4/25/2014 1:29:40 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\042414-24148-01.dmp
Bugcheck code: 0xA (0x1, 0xD, 0x1, 0xFFFFF80002E99FCF)
17 crash dumps have been found and analyzed. Only 10 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Hopefully I've attached all the files and screenshot that are normally requested.
Thanks for any help and your time,
Keith
Crash Dump Analysis
Keith
