Gabriel Rocha
Hello everyone,
First time here.
I got a computer about 3 months ago, and im having BOSD with this different messages every day, twice or three times a day.
It happens randomly, sometimes its when im navigating on facebook/email/news, sometimes im working on video (After effects, photoshop and illustrator), and sometimes im just organizing folders.
I already tried changing the Memory sticks by new ones, so its not memory. my drivers are all updated and i dont know what else to do. PLEASE SOME HELP?
Here is the file with all the files requested from the W7F diagnostic tool.
no no, it froze up once. But the last time was a BSOD.
It happened when i was navigating on Facebook, nothing else opened.
I dont use my PC for gaming, just to work basically.
ill do some tests with it and will let you know. Thanks again for all your effort on helping me.
ill keep you posted.
Gabriel do you have an install disk for windows? If so, boot from it as if your going to do a clean install but on the install page click repair instead.
OK, its been a while i dont post here. Thanks for the rply anyways.
I dont have the WIndows disc actually. I've been having BSOD every 2-3 weeks now.
Tha latest shown "Memory Management".
Once again here are the files.
Besides the Windows disc idea, what else can i do?
Hi Gabriel,
I actually started this post last night but was interrupted by late visitors.
BugCheck 1A, {41790, fffffa800c150030, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35084 )
Followup: MachineOwner
Most of the dump files are like the above apart from one blaming Nvidia gpu drivers and another blaming NTFS.
BiosVersion = F8
BiosReleaseDate = 08/03/2013
SystemManufacturer = Gigabyte Technology Co., Ltd.
SystemProductName = Z87M-D3H
You have a further two Bios updates pending:
Rt64win7.sys Tue Nov 26 07:33:02 2013: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet.
RtNdPt60.sys Mon Jul 20 03:27:32 2009: Realtek NDIS User mode I/O Driver - Ethernet :
The above as well as your other system drivers have later versions on your motherboard website please update:
You still have this driver to be updated ..If possible?
anodlwfx.sys Fri Mar 06 10:10:08 2009: anodlwfx.sys is from ALPHA Filter Link Removed, Alpha Networks Inc.. related to your D-Link Wireless G-Adapter. Please update:
http://www.dlink.com/uk/en/support
Found this in your driver stack and cannot find any information about it:
enovq.sys Mon Aug 05 23:33:54 2013: Any ideas?
If after making the above changes you still get a bsod then you really need to test your RAM and RAM slots. I'd also test the RAM individually and in one slot only. Once tested move on to the next slot and so on. See if you can find a slot or stick that doesn't error out.
Post any new dump files.
