Hello,
Indeed, automatic updates can sometimes be inconvenient, but updates are installed automatically to ensure your system is protected from threats and always running efficiently. That said, you have control over your update settings and can choose when updates are installed.
Here are the steps on how you can manage your update settings:
1. Click on the "Start" button and then the "Settings" icon (which looks like a gear).
2. In the "Settings" window, click on "Update & Security".
3. From here, you should be in the "Windows Update" section. Click on "Advanced options"
4. In the "Advanced options" menu, you have several controls like 'Pause until', 'Choose when updates are installed', and more. If you don't want to pause but prefer to schedule the updates, under 'Choose when updates are installed', select 'Semi-Annual Channel". This will postpone feature updates for several months, allowing you to choose a suitable time.
Also, remember that updates are an integral part of keeping your PC secure and running smoothly. I would recommend setting them to be done during times when they won't be a disruption to your work or personal use.
If you find updates to be disruptive, remember you can also set your "Active Hours" on Windows to tell your system when you're typically at your computer so it won't force any restarts during those hours. You can set active hours under the same "Windows Update" section in "Update & Security".
Hopefully, this provides some clarity for you. If you have any other questions feel free to ask!
