ErMurazor
Hi all, I'm looking for a help to solve a big problem with Xbox Game-bar. I used the integrated Windows gamebar recorder to record my gameplays since all the time. And still, I like to it rather than using third party software. But there's a very disturbing problem with it; Whenever I record any gameplay with the game-bar and play it, the audio in the recorded video sounds choppy. The video plays very smooth and the gameplay is also smooth while recording. This happens for nearly two years now. I tried every solution I could find regarding this issue, but nothing worked.
These are my Laptop's specs;
- AMD A9-9425 Radeon R5 dual core 3.10GHz APU (CPU with integrated graphics)
- 8GB DDR4 3200MHz RAM
- 1TB HDD
- Lenovo LNVNB161216 Motherboard
I'm currently running Windows 10 22H2 Home edition (64-bit). before that, 1909 Home edition (64bit). Before that I used a lite version of 10-pro. That's when the problem occurred. I decided to re-install a full version after failing to fix the issue on the lite version. Initially I was intended to install 10-pro but I got a activation key from a friend for the home edition and install it (1909). The problem didn't occur for like few days but suddenly it started again. Then I looked everywhere for solution and tried everything I could find. Finally I tried upgrading windows to the latest edition and the problem is still there...
What should I do ?
***Also the problem only occurs in my Laptop. There is not such a problem on my PC which has i5-4460+intel HD 4600 quad core CPU. AMD A9-9th gen is the equivalent of i3-8th gen. Which is a quiet similar CPU to i5-4th gen. Also the R5 graphics is far superior to intel HD 4600. And the overall gaming experience in my Laptop is far better than my PC.
- 1TB HDD
What should I do ?
