gathernetworkinfo.vbs????????
Discussion in 'Windows 7 Help and Support' started by kevin from Chi-town, May 14, 2009.
  1. kevin from Chi-town
    kevin from Chi-town New Member
    Jan 11, 2009
    714
    I came across this in my system 32 folder. I'm aware that there is a program looking throoughout your lan that uses visual basic. I also came across a site that says this is a virus. Is the anyone else that has this on their x86 OS ?
  2. reghakr
    reghakr Excellent Member
    Jan 26, 2009
    14,221
    Erie, PA
    No Kevin
    Not a virus, just part of Windows 7.
    It's used by the Network and Sharing Center.
  3. Josephur
    Josephur Windows Forum Admin Staff Member Premium Supporter
    Aug 3, 2010
    768
    Indiana, USA
    You will also see this in Windows 8. It is scheduled by Task Scheduler by default in both OS's to do some network inventory. Can be found in Task Scheduler, Windows, NetTrace.
    Location is:
    %windir%\System32\gatherNetworkInfo.vbs
    If your wondering if its infected (as it is possible for a vbs file to be maliciously altered), you can check the MD5 sum of these files,
    Windows 8's gatherNetworkInfo.vbs should have a sum of bc9cccbe9800c732940c7f8ed335b7d9
    Windows 7's should have a sum of 2ae808cb0d9a667b0cf41ea74b3b9bac
    If these files have been altered I suggest running a malware and virus scan, as well as "sfc /scannow" to replace corrupted files.
  4. bassfisher6522
    bassfisher6522 Excellent Member
    Aug 27, 2008
    4,824
    Joe, you do realize this post is almost 4 years old...lol. None the less, great information given.
  5. Teemocaptain
    Teemocaptain Member
    Aug 6, 2013
    43
    :eek:Can't imagine!
  6. Pauli
    Pauli Extraordinary Member Premium Supporter
    Mar 1, 2012
    2,521
    Helsinki, Finland, Europe
    Well, it gives the point of view that it might be important to check what files or folders belong to Windows, and what don't. Like if you get an extra engine in your car... heh.
Share This Page
