Windows Vista How to make a simple add, edit, delete, in asp.net
francemj
hi! everyone i'm new in using asp.net and vb.net, if there someone who can help me how to make a simple program of add, edit, delete and also include search in asp.net. thanks and more blessings...!!!
Great to be here:D. Need help caus I am a novice at computers. My system says no audio output device installed. What do I do:confused::confused:?
Hi Prakash and welcome to the forum. Just for future reference..This would have been better posted in the section called 'Support' as you'll get a better response.
Anyhow.. Back to your problem, First of all Prakash can you post some details of what your using( pc spec) and how it came to be that way (how did you lose the audio)
Hey Bios can you move this to the multimedia thread?
Thanks
now back to the issue..yes any USEFUL information is helpful. what brand of sound card are you running and whatever else you can tell us. If it is a sound blaster you can download "Danial's" drivers. I've herd it has helped a lot of people.
I'm sure Kemical knows where you can get it.
The link I posted should still work but I'll wait and see what his card is first and then if need be go find it ( the post)
