Hello, dear members and web travellers!
I need some thoughts and tips on an issue with booting from a flash drive.
Today I used the application WinToUsb to install a copy of Windows 7 Home Premium 64Bit on a SanDisk thumbstick which uses a USB 3.0 connection.
Now I want to boot from this stick what does not work when I plug the flash drive into a USB 3.0 hub because my machine does not detect it at all. It works when I use a USB 2 hub but that takes an eternity to load all the files!
Actually I did install a USB 3.0 driver but this only works on an already running operating system of course. Hence, I need to know if I can somehow make my motherboard support USB 3.0 natively... the one I use is called Gigabyte GA-790XTA-UD4 - I wonder if a BIOS update can help but there is no information to be found when I use Google for search.
Though I still count on the awesome community of Windowsforum to help me out.
thanks in advance!
TRSS
thanks in advance!
TRSS
