I was able to install drivers for this, but get a "Blue Screen" on shutdown
I was able to install driver by installing Catalyst run as Administrator, using "Suggested Compatibility" mode, then uninstalling Catalyst Control Panel(kept getting incompatible program message)
From Event Viewer
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 5/20/2009 10:38:34 AM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Mark-Win7PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2009-05-20T14:38:34.234375000Z" />
<EventRecordID>1517</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Mark-Win7PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">207</Data>
<Data Name="BugcheckParameter1">0x8fcbf9cc</Data>
<Data Name="BugcheckParameter2">0x8</Data>
<Data Name="BugcheckParameter3">0x8fcbf9cc</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">true</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Note: this was a normal shutdown/reboot to start XP.
On the upside, I can now play native Windows games
From Event Viewer
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
