Windows 7 Ramdom reboot BSOD IRQ and TCPIP.sys
aelwan
i have a windows 2003, server, sometime computer reboots, the BSOD is attached in here!
The minidump is here also!
Thanks in advance!
here is the mini dump.
  • Minidump_64.zip
BugCheck D1, {0, 2, 0, fffffadcbb62d0d3}
*** WARNING: Unable to verify timestamp for bxnd52a.sys
*** ERROR: Module load completed but symbols could not be loaded for bxnd52a.sys
Probably caused by : bxnd52a.sys ( bxnd52a+cad8 )
Followup: MachineOwner
you have a number of different dump files and they fall mainly into two groups. The dump file above is blaming bxnd52a.sys which is a Broadcom NetExtreme II driver? The other dump file group is Bugcheck FFF blaming orafencedrv.sys which apparently is caused by corruption in the cluster. This I think is related to the above driver which should be updated. As I'm not too familiar with your os I did a little googling. See this thread which kind of concurs with the above:
http://h30499.www3.hp.com/t5/ProLia...eck-STOP-0x000000D1/td-p/4490346#.VTVvdF9VhBc
Hopefully updating the Broadcom driver will stop the bsod.
https://www.broadcom.com/support/ethernet_nic/determine_driver.php
Edit:
Thread moved to bsod section.
Top Bottom
