Realtek PCIe GBE Family Controller is disconnected from network.
Discussion in 'Windows 7 Blue Screen of Death (BSOD)' started by rocky050371, Jan 25, 2011.
  1. rocky050371
    rocky050371 New Member
    Jan 25, 2011
    6
    Before I get into uploading memory dumps I wonder if anyone has any ideas on the following
    When playing WOW and wow only I get blue screens. I have checked the event viewer and on each ocassion prior to the dump it states that
    Any ideas?
    Thanks for any help in advance
  2. cybercore
    cybercore New Member
    Jul 7, 2009
    15,826
  3. rocky050371
    Jan 25, 2011
    6
    Here you go, hope they help
  4. Trouble
    Trouble Noob Whisperer
    Nov 30, 2009
    13,803
    N.W. Indiana
    First determine the actual chipset of the card, probably one of these Realtek download and use device manager to force an update of the driver for your NIC if you are not using the most current one from realtek.
    Not sure how, why or if that particular issue is also producing your blue screens, but we have seen some issues with Gigabit Ethernet NICs, having some problems maintaining consistent connections with certain routers when the speed and duplex of the card is left at "Auto Negotiate".
    You can try this and see if it helps with the reliability of the connection
    type ncpa.cpl into the search box and hit enter
    select then right click your Network adapter (probably says something like "Local Area Connection) and choose properties
    Click the configure button near the top right
    Select the advanced tab
    In the left "Property" column, look for something called Speed & Duplex (may be worded slightly differently "Link Speed / Duplex Mode", etc.
    In the right "Value" column select the drop down arrow and change Auto Negotiation to 10Mbps/Half Duplex
    OK your way back out of there and reboot.
    See if that resolves the disconnect issue.
    If it does fine. Experiment with different settings, ideally you would want 1000/Full if you have a gig network (router, cableing, etc.), Alternately you would probably want 100/Full but don't be affraid to settle for 100/half if that resolves your issues.
    Keep us posted.
  5. cybercore
    Jul 7, 2009
    15,826
    One of them was caused by NETGEAR WG111v3 Wireless-G USB Adapter:
    BugCheck 19, {20, fffffa8006a16bb0, fffffa8006a16cc0, 4110003}
    Probably caused by : wg111v3.sys
    Update NetGear Wireless:
    wg111v3.sys Wed Nov 18 04:47:46 2009
    Update other drivers too:
    Realtek NDIS Protocol Driver
    RtNdPt60.sys Sun Jul 19 22:27:32 2009
    Realtek Audio
    RTKVHD64.sys Tue Oct 20 05:55:09 2009
    Intel Matrix Storage
    iaStor.sys Thu Jun 04 21:53:40 2009
    If crashes persist, replace McAfee with MSE:
    How to uninstall or reinstall supported McAfee consumer products using the McAfee Consumer Products Removal tool (MCPR.exe)
    https://www.microsoft.com/security_essentials/
    MSE is much more resistent to BSOD's than any other antivirus. Besides, McAfee will not work well with all those outdated drivers.
    Crash Dumps:
    Loading Dump File [F:\a\Minidump\D M P\DMP\012511-24211-01.dmp]
    Executable search path is:
    Windows 7 Kernel Version 7600 MP (2 procs) Free x64
    Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
    Machine Name:
    Kernel base = 0xfffff800`03206000 PsLoadedModuleList = 0xfffff800`03443e50
    Debug session time: Tue Jan 25 02:06:39.428 2011 (UTC - 5:00)
    System Uptime: 0 days 0:11:25.270
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    Unable to load image \SystemRoot\system32\DRIVERS\wg111v3.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for wg111v3.sys
    *** ERROR: Module load completed but symbols could not be loaded for wg111v3.sys
    Probably caused by : wg111v3.sys ( wg111v3+57a85 )
    Followup: MachineOwner
    0: kd> !analyze -v
    BAD_POOL_HEADER (19)
    The pool is already corrupt at the time of the current request.
    This may or may not be due to the caller.
    The internal pool links must be walked to figure out a possible cause of
    the problem, and then special pool applied to the suspect tags or the driver
    verifier to a suspect driver.
    Arguments:
    Arg1: 0000000000000020, a pool block header size is corrupt.
    Arg2: fffffa8006a16bb0, The pool entry we were looking for within the page.
    Arg3: fffffa8006a16cc0, The next pool entry.
    Arg4: 0000000004110003, (reserved)
    Debugging Details:
    BUGCHECK_STR:  0x19_20
    POOL_ADDRESS: GetPointerFromAddress: unable to read from fffff800034ae0e0
     fffffa8006a16bb0
    CUSTOMER_CRASH_COUNT:  1
    PROCESS_NAME:  System
    CURRENT_IRQL:  2
    LAST_CONTROL_TRANSFER:  from fffff800033a96d3 to fffff80003276740
    STACK_TEXT:
    fffff880`031fc108 fffff800`033a96d3 : 00000000`00000019 00000000`00000020 fffffa80`06a16bb0 fffffa80`06a16cc0 : nt!KeBugCheckEx
    fffff880`031fc110 fffff880`016ee695 : 00000000`00000000 00000000`00000000 fffff880`37383138 00000000`37383138 : nt!ExDeferredFreePool+0x12c4
    fffff880`031fc1c0 fffff880`05057a85 : fffffa80`06a27d30 fffffa80`06a1cfe8 00000000`0000001b fffffa80`03d691b0 : ndis!NdisFreeMemory+0x15
    fffff880`031fc1f0 fffffa80`06a27d30 : fffffa80`06a1cfe8 00000000`0000001b fffffa80`03d691b0 fffffa80`0742f000 : wg111v3+0x57a85
    fffff880`031fc1f8 fffffa80`06a1cfe8 : 00000000`0000001b fffffa80`03d691b0 fffffa80`0742f000 fffff880`050397d0 : 0xfffffa80`06a27d30
    fffff880`031fc200 00000000`0000001b : fffffa80`03d691b0 fffffa80`0742f000 fffff880`050397d0 fffffa80`06a0f820 : 0xfffffa80`06a1cfe8
    fffff880`031fc208 fffffa80`03d691b0 : fffffa80`0742f000 fffff880`050397d0 fffffa80`06a0f820 00000000`00000000 : 0x1b
    fffff880`031fc210 fffffa80`0742f000 : fffff880`050397d0 fffffa80`06a0f820 00000000`00000000 fffffa80`0742f000 : 0xfffffa80`03d691b0
    fffff880`031fc218 fffff880`050397d0 : fffffa80`06a0f820 00000000`00000000 fffffa80`0742f000 fffffa80`03d691b0 : 0xfffffa80`0742f000
    fffff880`031fc220 fffffa80`06a0f820 : 00000000`00000000 fffffa80`0742f000 fffffa80`03d691b0 fffffa80`0762e000 : wg111v3+0x397d0
    fffff880`031fc228 00000000`00000000 : fffffa80`0742f000 fffffa80`03d691b0 fffffa80`0762e000 fffff880`0501282e : 0xfffffa80`06a0f820
    STACK_COMMAND:  kb
    FOLLOWUP_IP:
    wg111v3+57a85
    fffff880`05057a85 ??              ???
    SYMBOL_STACK_INDEX:  3
    SYMBOL_NAME:  wg111v3+57a85
    FOLLOWUP_NAME:  MachineOwner
    MODULE_NAME: wg111v3
    IMAGE_NAME:  wg111v3.sys
    DEBUG_FLR_IMAGE_TIMESTAMP:  4b03c2c2
    FAILURE_BUCKET_ID:  X64_0x19_20_wg111v3+57a85
    Loading Dump File [F:\a\Minidump\D M P\DMP\012511-25272-01.dmp]
    Machine Name:
    Kernel base = 0xfffff800`03214000 PsLoadedModuleList = 0xfffff800`03451e50
    Debug session time: Tue Jan 25 01:54:34.419 2011 (UTC - 5:00)
    System Uptime: 0 days 8:57:49.261
    BugCheck 3B, {c0000005, fffff80003290670, fffff880037c9bf0, 0}
    Probably caused by : ntkrnlmp.exe ( nt!IofCallDriver+50 )
    1: kd> !analyze -v
    SYSTEM_SERVICE_EXCEPTION (3b)
    An exception happened while executing a system service routine.
    Arguments:
    Arg1: 00000000c0000005, Exception code that caused the bugcheck
    Arg2: fffff80003290670, Address of the instruction which caused the bugcheck
    Arg3: fffff880037c9bf0, Address of the context record for the exception that caused the bugcheck
    Arg4: 0000000000000000, zero.
    Debugging Details:
    FAULTING_IP:
    nt!IofCallDriver+50
    fffff800`03290670 49ff64c070      jmp     qword ptr [r8+rax*8+70h]
    CONTEXT:  fffff880037c9bf0 -- (.cxr 0xfffff880037c9bf0)
    rax=0000000000000000 rbx=fffff88000e7b850 rcx=fffffa8007b67050
    rdx=fffffa8004137240 rsi=fffffa8004137240 rdi=fffffa800893e1a0
    rip=fffff80003290670 rsp=fffff880037ca5c8 rbp=0000000000000000
     r8=fffffa800885d8e0  r9=0000000000000000 r10=fffff880009e8ac0
    r11=fffffa800827fad0 r12=0000000000000000 r13=fffffa800760ae70
    r14=fffffa8007744070 r15=fffffa8004128000
    iopl=0         nv up ei ng nz na pe nc
    cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
    nt!IofCallDriver+0x50:
    fffff800`03290670 49ff64c070      jmp     qword ptr [r8+rax*8+70h] ds:002b:fffffa80`0885d950=????????????????
    Resetting default scope
    BUGCHECK_STR:  0x3B
    PROCESS_NAME:  svchost.exe
    CURRENT_IRQL:  0
    LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80003290670
    STACK_TEXT:
    fffff880`037ca5c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!IofCallDriver+0x50
    FOLLOWUP_IP:
    nt!IofCallDriver+50
    SYMBOL_STACK_INDEX:  0
    SYMBOL_NAME:  nt!IofCallDriver+50
    MODULE_NAME: nt
    IMAGE_NAME:  ntkrnlmp.exe
    DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
    STACK_COMMAND:  .cxr 0xfffff880037c9bf0 ; kb
    FAILURE_BUCKET_ID:  X64_0x3B_nt!IofCallDriver+50
    Drivers:
    fffff880`00eeb000 fffff880`00f42000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
    fffff880`03c95000 fffff880`03d1f000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`04a00000 fffff880`04a16000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
    fffff880`011d1000 fffff880`011dc000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
    fffff960`00890000 fffff960`008f1000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
    fffff880`02f9e000 fffff880`02fa5000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
    fffff880`03db3000 fffff880`03dc4000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
    fffff880`03bb7000 fffff880`03bd5000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
    fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      unavailable (00000000)
    fffff880`02f87000 fffff880`02f95000   cdrbsdrv cdrbsdrv.SYS Mon Feb 20 05:15:35 2006 (43F996C7)
    fffff880`02f5d000 fffff880`02f87000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`090fe000 fffff880`0910b980   cfwids   cfwids.sys   Wed Oct 06 16:00:36 2010 (4CACD564)
    fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
    fffff880`01bc1000 fffff880`01bf1000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00d47000 fffff880`00da5000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`0136b000 fffff880`013de000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
    fffff880`03e74000 fffff880`03e84000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
    fffff880`0446a000 fffff880`04478000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
    fffff880`03c77000 fffff880`03c95000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
    fffff880`03c68000 fffff880`03c77000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
    fffff880`01bab000 fffff880`01bc1000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`0459c000 fffff880`045be000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
    fffff880`04478000 fffff880`0448b000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
    fffff880`02e25000 fffff880`02f41000   dump_iaStor dump_iaStor.sys Thu Jun 04 21:53:40 2009 (4A287AA4)
    fffff880`05a00000 fffff880`05a0c000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
    fffff880`03e8d000 fffff880`03f81000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:51:31 2010 (4CCF7CB3)
    fffff880`03f81000 fffff880`03fc7000   dxgmms1  dxgmms1.sys  Mon Nov 01 22:50:56 2010 (4CCF7C90)
    fffff880`09159000 fffff880`0918f000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
    fffff880`011dc000 fffff880`011f0000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
    fffff880`00da5000 fffff880`00df1000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
    fffff880`0142b000 fffff880`01435000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
    fffff880`01b71000 fffff880`01bab000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
    fffff880`0179b000 fffff880`017e5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
    fffff880`03e67000 fffff880`03e74000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
    fffff800`037f0000 fffff800`03839000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
    fffff880`03fc7000 fffff880`03feb000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
    fffff880`044a7000 fffff880`044c0000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
    fffff880`044c0000 fffff880`044c8080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
    fffff880`04499000 fffff880`044a7000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
    fffff880`03aef000 fffff880`03bb7000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
    fffff880`01b68000 fffff880`01b71000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
    fffff880`010b5000 fffff880`011d1000   iaStor   iaStor.sys   Thu Jun 04 21:53:40 2009 (4A287AA4)
    fffff880`03dea000 fffff880`03e00000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
    fffff880`04acb000 fffff880`04ada000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
    fffff880`0297f000 fffff880`0298d000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
    fffff800`00bd4000 fffff800`00bde000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
    fffff880`01a72000 fffff880`01ab5000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
    fffff880`01400000 fffff880`0141a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
    fffff880`01770000 fffff880`0179b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
    fffff880`045be000 fffff880`045c3200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
    fffff880`029a8000 fffff880`029bd000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
    fffff880`0291e000 fffff880`02941000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
    fffff880`00cef000 fffff880`00d33000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
    fffff880`09000000 fffff880`0901bc80   mfeapfk  mfeapfk.sys  Wed Oct 06 15:56:26 2010 (4CACD46A)
    fffff880`045c4000 fffff880`045f0800   mfeavfk  mfeavfk.sys  Wed Oct 06 15:56:49 2010 (4CACD481)
    fffff880`04400000 fffff880`04469780   mfefirek mfefirek.sys Wed Oct 06 15:59:47 2010 (4CACD533)
    fffff880`01282000 fffff880`01300c80   mfehidk  mfehidk.sys  Wed Oct 06 15:55:49 2010 (4CACD445)
    fffff880`03d4e000 fffff880`03d5e900   mfenlfk  mfenlfk.sys  Wed Oct 06 15:56:13 2010 (4CACD45D)
    fffff880`01200000 fffff880`01243200   mfewfpk  mfewfpk.sys  Wed Oct 06 15:56:04 2010 (4CACD454)
    fffff880`0448b000 fffff880`04499000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
    fffff880`01a63000 fffff880`01a72000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
    fffff880`044c9000 fffff880`044d6000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
    fffff880`0109b000 fffff880`010b5000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`03bd5000 fffff880`03bed000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
    fffff880`03a00000 fffff880`03a2d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
    fffff880`03a2d000 fffff880`03a7b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
    fffff880`03a7b000 fffff880`03a9e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
    fffff880`02e09000 fffff880`02e14000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`00f4b000 fffff880`00f55000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
    fffff880`0130d000 fffff880`0136b000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
    fffff880`03c5d000 fffff880`03c68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
    fffff880`01b56000 fffff880`01b68000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
    fffff880`0161e000 fffff880`01710000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`04a3a000 fffff880`04a46000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
    fffff880`02853000 fffff880`02866000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
    fffff880`04a46000 fffff880`04a75000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
    fffff880`04531000 fffff880`04546000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
    fffff880`03d75000 fffff880`03d84000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff880`01a1e000 fffff880`01a63000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
    fffff880`01710000 fffff880`01770000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
    fffff880`02e14000 fffff880`02e25000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
    fffff880`03c51000 fffff880`03c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
    fffff800`03214000 fffff800`037f0000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
    fffff880`01450000 fffff880`015f3000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
    fffff880`02f95000 fffff880`02f9e000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
    fffff880`055a2000 fffff880`055a3180   nvBridge nvBridge.kmd Wed Jan 13 20:17:24 2010 (4B4E70A4)
    fffff880`04546000 fffff880`0455f000   nvhda64v nvhda64v.sys Thu Jan 28 09:24:54 2010 (4B619E36)
    fffff880`04adc000 fffff880`055a1380   nvlddmkm nvlddmkm.sys Wed Jan 13 20:45:42 2010 (4B4E7746)
    fffff880`02800000 fffff880`02853000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
    fffff880`03d28000 fffff880`03d4e000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
    fffff880`00f95000 fffff880`00faa000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00f55000 fffff880`00f88000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
    fffff880`0141a000 fffff880`0142b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
    fffff880`06e28000 fffff880`06ece000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
    fffff880`0455f000 fffff880`0459c000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
    fffff880`00d33000 fffff880`00d47000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
    fffff880`01301000 fffff880`0130ce00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
    fffff880`04a16000 fffff880`04a3a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
    fffff880`04a75000 fffff880`04a90000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
    fffff880`04a90000 fffff880`04ab1000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
    fffff880`04ab1000 fffff880`04acb000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
    fffff880`03c00000 fffff880`03c51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
    fffff880`02fe8000 fffff880`02ff1000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`02ff1000 fffff880`02ffa000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`02e00000 fffff880`02e09000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
    fffff880`01b1c000 fffff880`01b56000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
    fffff880`02866000 fffff880`0287e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
    fffff880`055a4000 fffff880`055fa000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
    fffff880`05a0f000 fffff880`05bf8c80   RTKVHD64 RTKVHD64.sys Tue Oct 20 05:55:09 2009 (4ADD88FD)
    fffff880`0287e000 fffff880`0288a000   RtNdPt60 RtNdPt60.sys Sun Jul 19 22:27:32 2009 (4A63D614)
    fffff880`06ece000 fffff880`06ed9000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
    fffff880`01b14000 fffff880`01b1c000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
    fffff880`0903b000 fffff880`090d1000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
    fffff880`06f18000 fffff880`06f7f000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
    fffff880`06ed9000 fffff880`06f06000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
    fffff880`03e84000 fffff880`03e85480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
    fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
    fffff880`06f06000 fffff880`06f18000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
    fffff880`017e5000 fffff880`017f2000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
    fffff880`01a00000 fffff880`01a1e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
    fffff880`03d9f000 fffff880`03db3000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
    fffff960`005b0000 fffff960`005ba000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`03dc4000 fffff880`03dea000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
    fffff880`01ab5000 fffff880`01ac7000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
    fffff880`0298d000 fffff880`029a7c00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
    fffff880`02962000 fffff880`0297f000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
    fffff880`05a0c000 fffff880`05a0df00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
    fffff880`03e56000 fffff880`03e67000   usbehci  usbehci.sys  Fri Dec 04 02:26:02 2009 (4B18B98A)
    fffff880`044d7000 fffff880`04531000   usbhub   usbhub.sys   Fri Dec 04 02:26:39 2009 (4B18B9AF)
    fffff880`03e00000 fffff880`03e56000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
    fffff880`02f41000 fffff880`02f5c000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
    fffff880`03feb000 fffff880`03ff8000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
    fffff880`00f88000 fffff880`00f95000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
    fffff880`02fa5000 fffff880`02fb3000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
    fffff880`02fb3000 fffff880`02fd8000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
    fffff880`00faa000 fffff880`00fbf000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`0103f000 fffff880`0109b000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
    fffff880`01ac8000 fffff880`01b14000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
    fffff880`0901c000 fffff880`09029000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
    fffff880`03d5f000 fffff880`03d75000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
    fffff880`03d84000 fffff880`03d9f000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
    fffff880`02fd8000 fffff880`02fe8000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
    fffff880`00e38000 fffff880`00edc000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
    fffff880`00edc000 fffff880`00eeb000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`03d1f000 fffff880`03d28000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff880`06f7f000 fffff880`06ff7000   wg111v3  wg111v3.sys  Wed Nov 18 04:47:46 2009 (4B03C2C2)
    fffff960`000b0000 fffff960`003c0000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
    fffff880`00f42000 fffff880`00f4b000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
    fffff880`02941000 fffff880`02962000   WudfPf   WudfPf.sys   Fri Jan 15 02:32:54 2010 (4B501A26)
    fffff880`09128000 fffff880`09159000   WUDFRd   WUDFRd.sys   Fri Jan 15 02:33:30 2010 (4B501A4A)
    Unloaded modules:
    fffff880`0918f000 fffff880`09200000   spsys.sys
        Checksum:  00000000
        ImageSize:  00071000
    fffff880`02911000 fffff880`0291e000   vwifibus.sys
        Checksum:  00000000
        ImageSize:  0000D000
    fffff880`02899000 fffff880`02911000   wg111v3.sys
        Checksum:  00000000
        ImageSize:  00078000
    fffff880`0910c000 fffff880`09128000   mfeapfk.sys
        Checksum:  00000000
        ImageSize:  0001C000
    fffff880`090d1000 fffff880`090fe000   mfeavfk01.sy
        Checksum:  00000000
        ImageSize:  0002D000
    fffff880`01bf1000 fffff880`01bff000   crashdmp.sys
        Checksum:  00000000
        ImageSize:  0000E000
    fffff880`02e2e000 fffff880`02f4a000   dump_iaStor.
        Checksum:  00000000
        ImageSize:  0011C000
    fffff880`02f4a000 fffff880`02f5d000   dump_dumpfve
        Checksum:  00000000
        ImageSize:  00013000
  6. rocky050371
    Jan 25, 2011
    6
    Thank you both for your excellant help, I will start making changes
    With regards to
    Realtek Audio
    Where would I get these from, is realtek both the network and audio?
  7. cybercore
    Jul 7, 2009
    15,826
    Yes, both Realtek Audio and Network Protocol. Get updates for them here:
    1. Realtek
    2. your motherboard support site since these devices are part of it
    Get Intel updates with IntelĀ® Driver Update Utility.
    Also, follow Trouble's post too.
  8. cybercore
    Jul 7, 2009
    15,826
    Lol, don't forget about NetGear Wireless, the culprit of one of your crashes. Update the driver.
  9. dikbozo
    dikbozo Active Member
    Jun 20, 2013
    30
    Northwestern quadrisphere
    Dumping McAfee alone should help with most of your problems.
Share This Page
