void HashedFiles::SortAndCheck(int SortMode)
// Shell Sort
BOOL swap;
tagFileNode* TempNode;
int i, j, diff = 0;
for (j = _NodeCount / 2; j > 0; j /= 2)
swap = true;
while (swap)
swap = false;
for (i = 0; i + j < _NodeCount; ++i)
switch (SortMode)
case 0: // By FileHash, then by FileName
diff = HashCompare(_NodeList[i]->FileHash->c_str(), _NodeList[i + j]->FileHash->c_str());
if (diff == 0) diff = FileCompare(_NodeList[i]->FileName->c_str(), _NodeList[i + j]->FileName->c_str());
break;
case 1: // By FileName alone
break;
case 2: // By FileDate, then by FileTime, then by FileName
diff = DateCompare(_NodeList[i]->FileDate->c_str(), _NodeList[i + j]->FileDate->c_str());
if (diff == 0) diff = TimeCompare(_NodeList[i]->FileTime->c_str(), _NodeList[i + j]->FileTime->c_str());
break;
case 3: // By FileSize, then by FileName
diff = SizeCompare(_NodeList[i]->FileSize->c_str(), _NodeList[i + j]->FileSize->c_str());
break;
if (diff > 0)
swap = true;
TempNode = _NodeList[i];
_NodeList[i] = _NodeList[i + j];
_NodeList[i + j] = TempNode;
// Scan for duplicate hashes and mark them.
if (SortMode == 0)
for (i = 1; i < _NodeCount; ++i)
if (_NodeList[i]->FileHash->compare(_NodeList[i - 1]->FileHash->c_str()) == 0)
_NodeList[i]->Duplicate = true; else _NodeList[i]->Duplicate = false;
