My WiFi NIC will always use 127.0.0.1 when its TCP/IP settings are on DHCP. If I change to static no issue but as you can imagine this creates some unwanted issues every time I connect with my laptop to a new WiFI network (as the address range is different)
So Interface index 6
Now check this out:
You see? I can set it manually but as soon as I set DHCP it autoset itself to 127.0.0.1.
This is not a DHCP issue as my Android mobile phone works perfectly on the same network.
Has anyone an idea on how to fix this?
Thanks!!
InterfaceAlias Interface Address ServerAddresses
Index Family
Ethernet 18 IPv4 {}
Ethernet 18 IPv6 {}
Resetting DNS servers on interface Wi-Fi - the system will use default DNS service.
-InputObjext
Wi-Fi 6 IPv4 {127.0.0.1}
Wi-Fi 6 IPv6 {}
Now check this out:
PS C:\Program Files\Stubby> Set-DnsClientServerAddress -InterfaceIndex 6 -ResetServerAddresses
PS C:\Program Files\Stubby> get-dnsclientserveraddress Wi-Fi
Index Family
Wi-Fi 6 IPv6 {}
PS C:\Program Files\Stubby> Set-DnsClientServerAddress -InterfaceIndex 6 -ServerAddresses ("10.10.6.1")
Index Family
Wi-Fi 6 IPv4 {10.10.6.1}
Wi-Fi 6 IPv6 {}
Index Family
Wi-Fi 6 IPv6 {}
Thanks!!
