I believe Windows 8.1 can use a reader natively.
PC Settings > Accounts > Sign-in Options > Fingerprint
If the service is not running you need to enable Windows Biometric Service
- Joined
- Jul 4, 2015
- Messages
- 8,998
In Windows 10 you can use Windows Hello for fingerprint authentication. Should be under Settings > Accounts > Sign-in Options. Windows 7 doesn't have built-in support, you'd need some third party application to support it.
- Thread Author
- #3
What application should i use? can you help me? (windows 8.1)In Windows 10 you can use Windows Hello for fingerprint authentication. Should be under Settings > Accounts > Sign-in Options. Windows 7 doesn't have built-in support, you'd need some third party application to support it.
- Thread Author
- #5
can you make tutorial or picture?I believe Windows 8.1 can use a reader natively.
- Joined
- Jul 4, 2015
- Messages
- 8,998
- Thread Author
- #7
i have only password, picture password, pin, no fingerprints.
- Thread Author
- #9
yes, i have CD driver. i am use windows 8.1 with bingDid you install the driver for the fingerprint reader?
Similar threads
- Article
- Replies
- 0
- Views
- 478
- Article
- Replies
- 0
- Views
- 505
- Article
- Replies
- 0
- Views
- 301
- Article
- Replies
- 0
- Views
- 267
- Article
- Replies
- 0
- Views
- 400
