The thread discusses precautions for handling PCs, emphasizing the dangers of static electricity—such as sitting a PC directly on carpet and the importance of grounding oneself—and advises against opening the case while it’s powered on. The original poster, Drew, highlights these points to prevent static damage and electrical mishaps. A subsequent user questions whether removing or replacing side panels while the PC is powered off poses similar static risks, seeking clarification on the safety implications.
Drew
Banned
It has occurred to me that maybe I should mention this...
Electronics and specifically, PCs do not like static electricity. W/out explaining the science or physics of it here is my point... Often I have gone to clients' homes or offices and discover PCs sitting on carpets. Remember, if you rub a balloon on a carpet it will then stick to a wall? That's static electricity @ work. DO NOT sit PCs directly on carpets. IF, the machine is going to be placed on a carpeted floor put something under it to isolate it from the carpet; a wooden board, newspaper, cardboard, you get the idea.
And another thing, while I'm @ it... do not remove or replace PC case covers, side panels and such whilst a PC is running. Always do this ONLY after & while the machine is unpowered or shut off.
Cheers,
Drew
An image from 'Carpets (ignore Prefix)'. Windows 8.1 logo with blue window icon and text on white background.
seekermeister
Honorable Member
I understand most of what you said, except in regards to removing/replacing side panels. I assume that is to prevent a static discharge, which I know is important with the internal components themselves, but a static discharge with a panel doesn't seem any more risky than touching the outside of the case itself, which we all do regularly. Am I missing something?
