Nibiru2012
Forget traditional metal block coolers a nanowick could remove 10 times the heat of current chip designs
Link Removed due to 404 Error
The new cooler design uses copper-coated carbon nanotubes.
(Source: Wikimedia Commons)
It essentially offers a pumpless liquid cooler,
which can dissipate massive amounts of heat
by boiling the cooling fluid -- water -- in microchannels.
(Source: School of Mechanical Engineering, Purdue University)
Purdue has implemented and tested the nanotech
cooler and expects to bring it to market with a few years.
(Source: Purdue University School of Mechanical Engineering)
A collaboration of university researchers and top industry experts has created a pumpless liquid cooling system that uses Link Removed - Invalid URL to push the limits of past designs.
One fundamental computing problem is that there are only two ways to increase computing power -- increase the speed or add more processing circuits. Adding more circuits requires advanced chip designs like 3D chips or, more traditionally, die shrinks that are approaching the Link Removed - Invalid URL as applied to current manufacturing approaches. Meanwhile, speedups are constrained by the fact that increasing chip frequency increases power consumption and heat, as evidence by the gigahertz war that peaked in the Pentium 4 era.
A team led by Suresh V. Garimella, the R. Eugene and Susie E. Goodson Distinguished Professor of Mechanical Engineering at Purdue University, may have a solution to Link Removed - Invalid URL higher frequency chips and power electronics. His team cooked up a bleeding edged cooler consisting of tiny copper spheres and Link Removed - Invalid URL, which wick coolant passively towards hot electronics.
The coolant used is everyday water, which is transferred to an ultrathin "thermal ground plane" -- a flat hollow plate.
The new design can handle an estimated 10 times the heat of current computer chip designs. That opens the door to higher frequency CPUs and GPUs, but also more efficient electronics in Link Removed - Invalid URL and Link Removed - Invalid URL applications.
The new design can wick an incredible 550 watts per square centimeter. Mark North, an engineer with Thermacore comments, "We know the wicking part of the system is working well, so we now need to make sure the rest of the system works."
The design was first verified with computer models made by Gamirella, Jayathi Y. Murthy, a Purdue professor of mechanical engineering, and doctoral student Ram Ranjan. Purdue mechanical engineering professor Timothy Fisher's team then produced physical nanotubes to implement the cooler and test it in an advanced simulated electronic chamber.
Garimella describes this fused approach of using computer modeling and experimentation hand in hand, stating, "We have validated the models against experiments, and we are conducting further experiments to more fully explore the results of simulations."
Essentially the breakthrough offers pumpless water-cooling, as the design naturally propels the water. It also uses microfluidics and advanced microchannel research to allow the fluid to fully boil, wicking away far more heat than similar past designs.
This is enabled by smaller pore size than previous sintered designs. Sintering is fusing together tiny copper spheres to form a cooling surface. Garimella comments, "For high drawing power, you need small pores. The problem is that if you make the pores very fine and densely spaced, the liquid faces a lot of frictional resistance and doesn't want to flow. So the permeability of the wick is also important."
To further improve the design and make the pores even smaller the team used 50-nm copper coated carbon nanotubes.
The research was Link Removed - Invalid URL in this month's edition of the peer-reviewed journal International Journal of Heat and Mass Transfer.
Raytheon Co. is helping design the new cooler. Besides Purdue, Thermacore Inc. and Georgia Tech Research Institute are also aiding the research, which is funded by a Defense Advanced Research Projects Agency (DARPA) grant. The team says they expect commercial coolers utilizing the tech to hit the market within a few years. Given that commercial cooling companies (Thermacore, Raytheon) were involved, there's credibility in that estimate.
The article from Daily Tech.com on July 27, 2010, discusses a groundbreaking pumpless liquid cooling system that leverages nanotechnology to enhance current chip cooling capabilities significantly. Here's a breakdown of the key points from the article:
Key Points:​
  • Cooler Design:
    • Utilizes copper-coated carbon nanotubes.
    • Offers a pumpless liquid cooling system that dissipates heat by boiling water in microchannels.
    • Concept of wicking away heat with small copper spheres and nanotubes.
    []Performance:
    • Capable of handling approximately 10 times the heat dissipation of traditional computer chip designs.
    • Achieves an impressive heat dissipation rate of 550 watts per square centimeter.
    ]Advancements:
    • Enables the use of higher frequency CPUs, GPUs, and more energy-efficient electronics.
    • Combines computer models with physical experiments for validation and refinement.
    []Collaboration:
    • Led by Suresh V. Garimella at Purdue University.
    • Involves university researchers, industry experts, and companies like Raytheon Co., Thermacore Inc., and Georgia Tech Research Institute.
    • Funded by a Defense Advanced Research Projects Agency (DARPA) grant.
      Implications:​
    ]Commercialization:
    • Expectation to bring the technology to the market within a few years.
    • Involvement of commercial cooling companies enhances the credibility of the timeline.
  • Research Publication:
    • The research is published in the International Journal of Heat and Mass Transfer. This innovative cooling solution addresses the increasing heat dissipation challenges faced by current chip designs and holds promise for enabling more powerful and efficient computing systems in the future. If you're interested in reading more details or have specific questions about this topic, feel free to ask!
