The thread discusses the original poster's search for a reliable digital camera around $100, emphasizing the importance of macro capabilities for close-up photography. The conversation explores the limitations of point-and-shoot cameras for macro use, with advice suggesting they may not be suitable for detailed close-up shots, and recommending considering DSLR options for better macro performance—though at a higher cost. The overall sentiment indicates the poster is leaning towards a Fuji camera based on macro test results but is concerned about warranty issues from non-authorized sellers.
seekermeister
Honorable Member
Since it appears that my old camera has gone partially inop, I'm thinking of buying another. However I used the old one so little, that I didn't learn much that is of use in buying something else. I want one that is reliable as possible with a good warranty of a good name brand, at a price of ~$100.
There are so many variables to consider, I don't know where to start. One thing lacking in my old camera is a release cable, because the camera doesn't have any provision for attaching it...does any digital camera?
After only spending a couple of minutes scanning eBay returns, I came across this one:
http://www.ebay.com/itm/Nikon-CoolP...451550?pt=Digital_Cameras&hash=item51b8b8859e
but can I do better?
EDIT: Another important factor for me is how to determine just how close the camera can be to the subject and focus properly? For instance, getting a clear shot of a small computer component.
seekermeister
Honorable Member
Thread Author #61
I hope that I don't end up regretting it, but for better or worse, I just placed the order for the black XF-1. It should arrive tomorrow.
seekermeister
Honorable Member
Thread Author #62
Camera arrived...glad to say there is no problem with it yet. A question has arisen regarding the battery...the manual says that the battery needs to be fully discharged for extended storage, but doesn't say how to discharge it. Do you know of a safe and practical way to do so? Also while on the battery, I thought it might be good to have a spare, but looking at the listings on Amazon and eBay, it appears that not all NP50 batteries are the same. One ad on eBay has a model selection drop down field, with a variety of models available, but not the XF-1. The pictures all look exactly the same, except some generic ones. Is there really any difference otherwise?
badrobot
I'm looking to buy a 32GB memory card for this camera. I checked the compatibility list:
Cameras | FUJIFILM X Series & GFX - Global
and I don't understand the differences in them, other than size and brand. What is the difference between SD, SDHC & SDXC?
The last 2 letters (**HC & **XC) only corresponds to the capacity. Up to 32GB is SDHC (where **HD simply means "high capacity). Up to 64GB is SDXC (for "eXtra(high) capacity"). XF1 can handle all three. What matters most is the Class # which indicates read/write speed. As much as possible, get a Class 10 which is most suitable for HD videos. If you don't plan do use it for videos, Class 4 is good enough. Taking videos with Class 4 to 6 memory cards often causes a write error.
But before you buy an SDHC or SDXC, make sure that your card reader is capable of reading it. These letters are for card reader classification.Some older card readers are not capable of reading SDXC. If a card reader is marked as SDHC, it means it can read both SD and SDHC but not SDXC. But if it's only marked as SD, it won't read HC and XC.
An image from 'Digital Camera'. Laptop keyboard close-up showing a red arrow pointing to a USB port symbol.
seekermeister
Honorable Member
Thread Author #65
I doubt that I will ever do any videos with it, but then who knows? Still, even with still shots the high speed would shorten the time it takes to shoot a photo...wouldn't it? In any case, it would be nice to be able to transfer photos to the computer quickly en masse. I've been looking at this memory:
A bit expensive, but faster than anything else I've found.
seekermeister
Honorable Member
Thread Author #66
I've run into one problem right off the bat...setting the time and date. This was the first thing that appeared when the camera was first turned on, but I hit the wrong button, and it disappeared. According to the manual, it can be reset at any time via the setup menu, but the only menu I've found access to is the shooting menu. Would you explain where the setup menu is?
seekermeister
Honorable Member
Thread Author #68
That did it, thanks. For some reason I still don't understand, I couldn't reach that portion of the menu selection on the left column, because it was grayed out. But it is set now.
badrobot
I normally use Adobe Sketchbook with stylus pen & graphic tablet on my desktop PC, but this one (above) was done on my Win 8 tablet and I used Paint.
seekermeister
Honorable Member
Thread Author #71
Tools of your trade? BTW, what kind of engineering do you design?
seekermeister
Honorable Member
Thread Author #74
Interesting. Never having even been in a one, I've always thought of subways being nothing more than tunnels with tracks, but those images illustrate that they are much more.
seekermeister
Honorable Member
Thread Author #76
Is your engineering limited to only the design aspect, or do you also deal with the standards with which things are built by?
EDIT: I'm guessing that they go hand in hand...huh?
badrobot
There is a company design standards. There is local standards based on where the project is going to be built. And there is also client standards. Client standards govern. Like on this subway project, our client is the city government. And they have a established standards for building design.
seekermeister
Honorable Member
Thread Author #78
Can you recommend a book or tutorial for a person that is essentially ignorant of the basics of photography? I once knew a lot more than I do now, but have forgotten most of that. The camera's manual is fairly good for learning how to operate the camera, but not on how to decide to operate it.
badrobot
Photography is about light. And depending on the amount of light available, you have to make adjustments between aperture, shutter speed and ISO settings. Here's a 15min video:
seekermeister
Honorable Member
Thread Author #80
Thanks, that brings back some memories. I think I'm just going to have to fiddle around with it to really get a handle on it. My next acquisition is going to be a very small tripod, because I've misplaced the one that I have, and am not inclined to tear the apartment apart to find it. All that I will probably use it for is as a tabletop/desktop stand for macros, so I guess it doesn't really make any difference which one I choose...does it?
