The thread asks how to limit battery charging to around 80% on an older Lenovo B50 running Xubuntu, as was possible with the original Windows Lenovo software. The main responder explains that the correct method depends on what the laptop exposes to Linux, suggesting checks for sysfs threshold files, using TLP if supported, or falling back to more model-specific ACPI control if those interfaces aren’t available. Overall, the sentiment is helpful and optimistic, with a neutral “diagnose first” approach and caution about hardware/firmware support and persistence across reboots.
Hat
I am running Xubuntu on a old Lenovo B50. It all works well, but have not managed to find yet how to limit the battery charge at about 80%, as it was possible with the Lenovo software originally installed on Windows. Do you have any idea on how to proceed? Doing it manually is distracting.
thank you
Yes — you can do this on Linux, but the exact method depends on what your B50 exposes to the kernel. Here are short diagnostics + three safe ways to set an automatic ~80% stop threshold (sysfs when available, TLP when supported, and fallback using acpi_call). Follow the checks and then try the method that matches what you find.
Step 0 — quick info I need if you want me to tailor instructions
Please paste the output of these (or run them and tell me what they show):
  • ls /sys/class/power_supply/
  • grep -i charge /sys/class/power_supply/* -R 2>/dev/null || true
  • uname -a
  • sudo dmidecode -s system-product-name (or just tell me the exact model string printed on the laptop label)
Step 1 — check what your kernel exposes (the...
  • uname -a
Step 1 — check what your kernel exposes (the easiest, safest way)
Run these commands:
  • for d in /sys/class/power_supply/*; do echo "---- $d"; ls -1 "$d"; done
Look for files named like any of:
  • charge_control_start_threshold
  • charge_control_end_threshold
  • stop_charge_threshold
  • start_charge_threshold
    If you find them, you can set thresholds directly.
How to set the threshold immediately (if those files exist)
Example (change BAT0 if your battery folder is different):
  • sudo sh -c 'echo 80 > /sys/class/power_supply/BAT0/charge_control_end_threshold'
  • sudo sh -c 'echo 75 > /sys/class/power_supply/BAT0/charge_control_start_threshold'
Verify:
  • cat /sys/class/power_supply/BAT0/charge_control_end_threshold
Make persistent across reboots (systemd service)
Create /etc/systemd/system/battery-threshold.service with content:
[Unit]
Description=Set battery charge thresholds
After=multi-user.target
[Service]
Type=oneshot
ExecStart=/bin/sh -c "echo 75 > /sys/class/power_supply/BAT0/charge_control_start_threshold || true; echo 80 > /sys/class/power_supply/BAT0/charge_control_end_threshold || true"
[Install]
WantedBy=multi-user.target
Then:
  • sudo systemctl daemon-reload
  • sudo systemctl enable --now battery-threshold.service
Notes: adjust BAT0 and numbers as you like. If writing fails, the files are not writable/available and you’ll get an error — move to the TLP/acpi_call methods below.
Step 2 — use TLP (recommended if sysfs is not present and your model is supported)
TLP is the standard power tool for laptops on Ubuntu/Xubuntu.
Install:
  • sudo apt update
  • sudo apt install tlp tlp-rdw
Edit /etc/tlp.conf: find and set (uncomment) lines:
  • START_CHARGE_THRESH_BAT0=75
  • STOP_CHARGE_THRESH_BAT0=80
Then start/restart TLP:
  • sudo tlp start
Check support:
  • sudo tlp-stat -b
    This output shows whether TLP can control thresholds on your machine and which kernel interfaces it will use (tp_smapi, acpi_call, ideapad_laptop, etc.. If tlp-stat indicates it cannot control the battery, move to the acpi_call fallback.
Step 3 — fallback: acpi_call (advanced, but works on many Lenovo/IdeaPad models)
Some laptops do not expose sysfs but can be controlled by writing ACPI calls. This is more model-specific and has a small risk of making ACPI calls that don’t apply — proceed only if you’re comfortable.
Install:
There are scripts and projects (and TLP can be configured to use acpi_call) that attempt the right ACPI method for your model. If you want, share tlp-stat -b and the outputs from Step 0 and I can suggest the exact acpi_call steps for your B50.
Important notes and caveats
  • Not all Lenovo models expose thresholds in Linux. Older/cheap models sometimes don’t.
  • Writing thresholds requires root and the kernel driver/ACPI method to support your hardware.
  • Some BIOS/firmware can override or reset thresholds on a reboot/AC change.
  • Always test with conservative values first (start 75 / stop 80).
  • To undo: remove the systemd service and reset values to 100 (or stop TLP threshold handling).
If you want, I can:
  • walk you step-by-step through whichever method looks available on your machine, or
  • analyze the exact outputs if you paste the results of the Step 0 commands I asked for.
Which would you like to try first?
