The thread discusses issues with opening and running an old VirtualBox virtual machine (.vdi file) after installing VirtualBox via Ubuntu's snap store. The user initially struggles to access the virtual disk, but later resolves the issue, although they encounter a problem starting the VM due to a virtualization support message. The helpful responses suggest enabling hardware virtualization in the BIOS or firmware, with clarification that BIOS and UEFI are both firmware types, and the main concern is whether the host system supports virtualization. Overall, the conversation is constructive, with the user seeking guidance on compatibility and setup.
anotherwindowsuser
Well-Known Member
I just installed virtual box from the ubuntu repository as part of the snap store selection however when I go to open up an old saved .vdi virtual box file it won't let me select it, its as if it wont recognise that file type in the directory in which it is stored, has VB changed in the last few years? Anyway I can access my old saved virtual box? Thanks in advance.
If the host OS is 64-bit then it should be able to run 32 or 64-guests. As the one message states, you will need to enable AMD-V in the firmware since the 64-bit version of virtualbox requires hardware virtualization enabled in firmware
anotherwindowsuser
Well-Known Member
Thread Author #5
Well, my joy was short lived, it wont let me start the virtual box based on the below message, not sure what to do because i cannot find the setting it is asking me to disable and what i can see it is not enabled in the first place.
An image from 'Has virtual box saves filesystems changed?'. VirtualBox system settings show hardware virtualization enabled but unsupported, causing invalid settings.
Neemobeer
Windows Forum Team
The VM was probably setup with hardware virtualization, so you will need to enable it in the firmware provided it's supported by the motherboard.
anotherwindowsuser
Well-Known Member
Thread Author #7
Thanks however the message reads its not supported by the host system, is this meaning i cannot do this virual box? I have changed computers since the virtual machine was saved. Thank you for your help.
Neemobeer
Windows Forum Team
It's kind of misleading message. The easiest fix would be to look in the firmware and enable virtualization. Almost all but the cheapest of systems should support it.
anotherwindowsuser
Well-Known Member
Thread Author #9
Looking into firmware sounds like programming to me? Is there not a bios option then? The irony is the computer I switched to is like 8+ times better than the older one.
anotherwindowsuser
Well-Known Member
Thread Author #11
I have just gone to create a new virtual machine in virtual box on my new computer which I thought would eliminate the problem but it is still throwing up the same error message, I have clearly got no settings on here for acceleration, what is going on? I am looking at the right section???
I'd like to remind people I am running this thread in the Linux section just in case that matters..
When I went to start the machine with it reading optical drive first, it gave this error:
AMD-V is disabled in the BIOS (or by the host OS) (VERR_SVM_DISABLED).
Result Code:NS_ERROR_FAILURE (0x80004005)
Component:ConsoleWrap
Interface:IConsole {872da645-4a9b-1727-bee2-5585105b9eed}
anotherwindowsuser
Well-Known Member
Thread Author #12
Wait a minute, why is it when I go to make a virtual machine of a linux distro it only lists 32 bit versions, can you only run 32bit on a virtual box or is something up? I was pretty sure my ubuntu installation was 64bit only so I would have thought it could run a 64 bit machine? Thanks in advance.
anotherwindowsuser
Well-Known Member
Thread Author #14
Someone just told me you can get old versions of xp as virtual machines can i get one to run on my windows 8.1 laptop? If so how do I get it? Thanks in advance
Neemobeer
Windows Forum Team
anotherwindowsuser
Well-Known Member
Thread Author #16
If I gave you my pc board number would you be able to assist? I looked around but couldnt see anything about hardware virtualisation. can we not make it a software only thing?
anotherwindowsuser
Well-Known Member
Thread Author #18
I eventually got vbox running on both Linux computer and the laptop, Linux could do it after changing a setting in the bios which had an obscure name I could only do it on the laptop by updating the bios in that. Curiously I could not update to the latest bios, only the second latest. The latest bios update software would not run in either the Windows 8 or xp installation. Anyway I wish to say thanks to all for the responses to this thread.
