gitano
- Joined
- Aug 3, 2015
- Messages
- 7
I have an old (2002) Dell Latitude running XP Professional (Build 2600). This computer was used for writing and testing proprietary software and has NEVER been connected to the internet. I need to connect it to the internet. I bought a NetGear WNDA3100 that says it supports XP, but it does NOT support mine. NetGear support says it must have at least Service Pack 1 or 2 in order for their device (USB WIFI adapter) to work.
I'm fine with downloading the service packs for XP, but as you should be able to see, I have a Catch-22 - the computer that is running XP is not connected to the internet. Therefore, I can't download the software that I need in order to get on the internet.
HERE'S THE QUESTION:
Can I download the service packs for XP on another computer and transfer them via some storage device (SD card, "thumb drive", etc.) to the old computer and still have that software install correctly?
Thanks,
Paul
Thanks,
Paul
