Hi everyone,
I’m exploring ways to streamline complex operational workflows in Dynamics 365 Business Central without relying too much on custom extensions. With every update, maintaining heavy customizations becomes harder, so I’m looking for smarter, future-proof approaches.
For those who’ve already implemented advanced process automation in BC:
  • What built-in features (like Power Automate, workflows, or AL events) are you using effectively?
  • How do you balance standard capabilities vs. extensions?
  • Are there any best practices to reduce technical debt during upgrades?
  • Any real examples of optimizing manufacturing, sales, or finance workflows using standard BC tools?
Would love to hear your experiences and recommendations.
Thanks!
Hi Allen,
This is exactly the right question to ask for Business Central SaaS. In practice, the most sustainable approach is:
standard configuration first, orchestration second, light event-driven extensions third, heavy custom code last.
That approach lines up with what consistently reduces upgrade pain in BC: minimize bespoke code, prefer standard capability where possible, and govern automation like a product, not a one-off project. The strongest recurring guidance in the BC migration and operations material is to do a formal keep / replace / rebuild / retire review, aim to minimize custom code going into SaaS, and treat telemetry, governance, and release control as part of the solution—not an afterthought. tsing...
Hi Allen,
That approach lines up with what consistently reduces upgrade pain in BC: minimize bespoke code, prefer standard capability where possible, and govern automation like a product, not a one-off project. The strongest recurring guidance in the BC migration and operations material is to do a formal keep / replace / rebuild / retire review, aim to minimize custom code going into SaaS, and treat telemetry, governance, and release control as part of the solution—not an afterthought. tsing hard before writing extensions
1) Standard BC workflows and approvals​
These are still the cleanest place to start for:
  • purchase approvals
  • sales discount approvals
  • payment or vendor master approvals
  • document release / posting controls
If the process is mainly status, approval, and routing, keep it in standard BC workflow logic as long as you can.
2) Power Automate for orchestration outside the transaction core​
Power Automate works best for:
  • notifications
  • approvals outside BC
  • document movement
  • Teams / Outlook / SharePoint integration
  • lightweight CRM or service follow-up actions
Where teams get value is using Power Automate to handle the workflow around BC, not to replace BC’s core posting logic. The common advice pattern is to remove friction by reverting to standard BC functionality where possible and automate repetitive work with Power Automate or only a minor AL extension behind the scenes.
3) AL events and event subscribers ide changes​
If you do need code, event subscribers are usually the sweet spot:
  • validate data before posting
  • enrich documents with metadata
  • push events to queues or downstream systems
  • insert lightweight logic without rewriting standard objects
That gives you extension points without building a giant customization layer that becomes painful every update.
4) Job queues, scheduled reports, and standard background processing​
A lot of “advanced automation” is really just:
  • scheduled posting checks
  • recurring imports/exports
  • nightly reconciliations
  • exception reports
  • queue-driven housekeeping
These are much safer than embedding everything in UI-driven custom logic.
5) Microsoft 365 / SharePoint / Teams as the document and collaboration layer​
A lot of workflow pain comes from trying to force ERP to be a document management platform. Teams that keep document-heavy work inside familiar Microsoft 365 boundaries tend to get better governance and lower technical debt than those who overbuild inside ERP. The recurring Microsoft ecosystem theme is to use SharePoint/OneDrive/Teams for document-centric work and keep ERP focused on transactions and business rules.
2. How I’d balance standard capabilities vs extensioondard BC configuration handle it?**​
  • If not, can BC workflow + approvals handle it?
  • If not, can Power Automate orchestrate it without touching the posting core?
  • If not, can a small AL event subscriber solve it cleanly?
  • Only then consider a larger extension or ISV.
That “minimize custom code” posture is exactly what shows up in the BC fit/gap and migration guidance: review each customization and decide whether to keep it, replace it with standard BC capability, rebuild it as an extension, or retire it entirely.
A practical rule:
  • Use standard BC for business rules and transactional integrity.
  • Use **Power Auttion, approvals, and cross-app orchestration.
  • Use small AL extensions only where the business rule truly belongs inside BC.
3. Best practices to reduce technical debt during upgrades​
1) Create a lightweight BC CoE / release board​
This should own:
  • automation standards
  • extension review
  • regression test scope
  • update readiness
  • telemetry and issue triage
The strongest operational guidance is to treat BC as a product you operate: define telemetry, detect issues, triage, remediate, and continuously improve.
2) Use a “keep / retire” review before every major build-up of automation​
Before adding automation, ask:
  • is this compensss?
  • is this already in standard BC now?
  • is the business requirement durable enough to justify code?
3) Separate core transaction logic from collaboration logic​
This is the biggest debt reducer.
  • Keep posting, costing, dimensions, and inventory logic in BC.
  • Put alerts, reminders, approvals, and file movement in Power Automate / Teams / SharePoint.
4) Keep extensions small and event-based​
Heavy customization is exactly what becomes harder to maintain with each update. That is the user pain you’re trying to avoid, and it is the same reason the BC guidance consistently recommends minimizing custom code and controlling release cadence.
5) Build regression tests around business-critical flows​
For SaaS BC, the practical governance pattern is:
  • preview / sandbox validation
  • prosmoke tests
  • critical path regression
  • controlled production scheduling
That is the safest way to keep cloud agility without letting updates surprise operations.
6) Instrument telemetry and exception reporting​
Track:
  • failed automations
  • queue depth
  • approval bottlenecks
  • posting failures
  • data quality exceptions
That utomations instead of just accumulating them.
4. Real examples of workflow optimization using standard BC tools​
Manufacturing​
The most sustainable pattern is not “build a custom manufacturing cockpit,” but:
  • standard production / inventory transactions in BC
  • scheduled exception reports
  • Power Automate alerts for shortages, delayed orders, or approval needs
  • Power BI for visibility
Where teams go wrong is embedding too much synchronous custom logic into operational screens. The guidance around BC stability and performance is consistent: heavy customizations and complex logic in the core path increase risk and support burden.
Sales​
A good practical example is order intake automation with human approval still in the loop. The glass365 example shows a BC-based order process where AI/Copilot helps convert emhes into draft sales orders, checks inventory, and generates quotations, while humans remain the approval gate. That is a strong model because it accelerates the front end without turning the posting core into an uncontrolled automation experiment.
Finance​
Finance is often where standard-plus-automation works best:
  • standard posting and reconciliation in BC
  • Power Automate for approvals, reminders, and document routing
  • embedded analytics / Power BIupport and variance review
The recurring finance automation message is that AI and automation are most useful when they shave time off reconciliation, close, and exception handling—not when they replace accounting controls.
5. What I would avoid​
I would be cautious about:
  • using Power Automate for high-volume transactional writes into BC
  • replacing core approval or posting logic with external flows
  • building “temporary” large custom extensiyd yet
  • creating parallel data logic outside BC for inventory, costing, or dimensions
That is how teams end up with shadow automation, brittle integrations, and upgrade friction. Governance matters here just as much as capability.
6. My practical recommendation​
If your goal is future-proof automation with low upgrade pain, use this pattern:
  • Standard BC first
  • Workflow/approvals second
  • Power Automate for collaboration and orchestration
  • Small AL event subscribers fs rules
  • Telemetry + sandbox regression + release governance
  • Quarterly review to retire automations that no longer justify themselves
If you want, I can turn this into a decision matrix like:
  • Use standard BC
  • Use Power Automate
  • Use AL event subscriber
  • Use full extension
  • Use ISV
for common scenarios in manufacturing, sales, and finance.
