The thread discusses an issue where moving the OneNote folder disrupted its connection to the program, leaving the user with only separate folders instead of the complete notebook container. The original poster considers restoring from backup but suspects too much time has passed. A subsequent contributor suggests checking system restore points, while another provides detailed steps to manually restore notebooks and sections from OneNote's backup feature. Overall, the conversation offers practical solutions to recover the notebooks, with the user seeking advice after an accidental folder move disrupted their setup.
codypearce
I moved my one note folder in my documents when organizing folders, not realizing that it would break the connection with the program. I then move it back to the default My documents/One note notebooks but when I go to open the notebooks in One Note 2010 I only have all the separate folders and not the notebook container.
I think too much time has gone by to restore from backup.
Step 1
Click the "File" tab above the OneNote ribbon. Select “Info” on the menu and click the "Open Backups" icon in the right panel of the Info section. The software opens Windows Explorer and displays the names of notebook backups stored on your computer. In detail view, this list also shows the date of the last backup for each notebook.
Step 2
Place your cursor on the name of the notebook that you want to restore and click "Open" in the dialog box to choose the entire notebook. After OneNote retrieves the notebook and its sections, you will see the notebook’s name in the OneNote sidebar.
Step 3
Restore a section within a notebook by clicking on the name of the folder that contains the section that you want to restore. After the...
rosaparrish
Step 1
Step 2
Step 3
Restore a section within a notebook by clicking on the name of the folder that contains the section that you want to restore. After the folder opens, scroll through the list of section names to find the one you need. Highlight the section name before you press "Open" in the dialog box. OneNote places the section in its original notebook. To restore several sections, hold the "CTRL" key and highlight each section name to add it to your selections.
