What holds up is narrower and still good news. The 0.102 release added two mouse utilities, an optional quick-access shelf for Command Palette, ZoomIt snip dictation and new command-line tools. Microsoft's documentation also describes the suite as free and open source. So this is a toolbox with several tools that have nothing to do with window layouts.
Below are the three tools XDA singles out. Each section covers what it does, how to start using it, and where the limits are.
Command Palette: a keyboard-first launcher with a Dock
Command Palette is the successor to PowerToys Run. Microsoft documents it as a way to launch apps, run commands, search files, browse the web and reach Windows tools from one place.
Getting started
- Open PowerToys Settings and make sure Command Palette is enabled. It has to be running in the background.
- Press Win+Alt+Space and start typing. That's the default shortcut, and you can change it in Command Palette settings.
- If you want a smaller window, set "How Command Palette opens" to the compact search box.
What it can do beyond launching apps
- Typing
>followed by a command runs it. ??followed by a query searches the web in your default browser.$followed by a settings page name jumps to that page in Windows Settings.- It also handles calculator math, window switching, clipboard history and Windows services.
- It can query the registry, open Terminal profiles, start Remote Desktop sessions and show performance metrics.
- WinGet search lets you find and install apps from inside the palette. XDA's author likes this one.
The quick-access shelf (0.102)
- In compact mode, a shelf shows your pinned commands below the search box.
- Alt+1 through Alt+9 run those items.
- Alt+Shift+number selects an item without running it.
Extensions
- The built-in Extension Gallery lets you browse, install, update and uninstall community extensions.
- XDA's author uses an Everything search extension so one launcher covers file search. It's an add-on you install, not something that ships in the box. If you only launch apps, you probably don't need it.
The Dock
- The Dock is a toolbar on the edge of your screen. It gives one-click access to pinned commands without opening the full palette.
- Microsoft's documentation says you can enable it in Command Palette settings.
- You can anchor it to the left, top (the default), right or bottom edge. You can leave it pinned or set it to auto-hide.
- On multi-monitor setups, each display gets its own Dock and its own pinned items.
- By default, Home and WinGet sit at the start. Performance Monitor, Network Speed and Date/Time sit at the end.
- Win+Alt+J moves keyboard focus to the Dock.
XDA compares the Dock to a taskbar. That's a fair shorthand, but it is not a replacement for the Windows taskbar. Microsoft's documentation describes it as a pinned-command toolbar.
Reality check: XDA says Command Palette feels faster than Start search. That is a personal impression, not a benchmark. Try it next to Windows Search before you decide.
Mouse Without Borders: one keyboard and mouse, several PCs
Microsoft says the utility controls up to four computers from one machine. The name undersells it. Besides mouse and keyboard, it also shares the clipboard and can transfer files.
Setup, per Microsoft's documentation
- Install PowerToys on each PC.
- On the first computer, open Mouse Without Borders in Settings and select New Key.
- On the second computer, enter that key and the first computer's name, then select Connect.
- Move your cursor past the screen edge to cross to the other machine.
- Drag the device icons in the layout to match your desk.
Limits and gotchas
- File transfer through the clipboard is capped at 100 MB.
- Copy/paste and drag/drop work with a single file only. For folders or several files, zip them first.
- Drag/drop does not work with network files.
- If a full-screen Remote Desktop or virtual machine window has focus, the keyboard may not follow the mouse. Microsoft suggests enabling "Hide mouse at screen edge" or switching focus to another window first.
- A machine with no physical mouse attached may show no pointer.
- Some settings may not sync and may need matching by hand on each machine.
Security notes
- Options include "Same subnet only" and reverse-DNS validation of remote IP addresses.
- Running the utility as a service lets it control elevated apps and the lock screen. Microsoft warns that this adds security risk, so think about your risk tolerance first.
If it won't connect: check that all machines are on the same network and that the key and host name are correct. Also check whether the firewall is blocking traffic. There is a setting to add a firewall rule. If a connection drops, use Refresh connections.
This is not remote desktop software. It passes input between PCs you are sitting in front of, so each machine still needs its own display. XDA's author says it replaced Chrome Remote Desktop for his two-laptop desk. That's his workflow, not a general rule.
Power Display: monitor controls with caveats
Windows has long handled external monitors unevenly. Power Display puts monitor controls into one flyout. It uses DDC/CI to adjust brightness, contrast, volume, input source, rotation, color temperature and power state. Which controls appear depends on what each monitor reports.
Useful features
- Save profiles that combine brightness, contrast, volume and color temperature across monitors, then apply them from Settings or the flyout.
- Link brightness across two or more brightness-capable monitors. You can exclude individual displays.
- Adjust brightness with the mouse wheel on the tray icon. Choose Off (the default), Primary display or All displays. The default step is 5.
- Pair profiles with Light Switch so monitor settings follow the Windows light and dark theme.
- Use the included command-line tool,
PowerToys.PowerDisplay.CLI.exe, to read or set values from scripts. A--jsonoption produces output for automation.
Read this before enabling it
- On a small number of monitors with malformed capability strings, Microsoft says the startup read can trigger a Windows kernel bug and a blue screen. Microsoft attributes the underlying problem to Windows, not Power Display.
- If a crash is detected, Power Display disables itself the next time PowerToys launches. It shows a warning and adds the monitor to an exclusion list.
- Input source, color temperature and power state controls are off by default per monitor. Enabling them brings up a confirmation dialog. The changelog for the stable line notes that disruptive controls including Input Source, Color Temperature, and Power State are now disabled by default with a confirmation dialog.
- Switching to an input with no signal can leave the screen black. Software control may not return until you change inputs with the monitor's physical buttons.
- Max compatibility mode is for monitors that don't show up. It ignores the capabilities string and probes features directly. Microsoft warns the screen may go black and the monitor may behave unpredictably. Use it only as a last resort.
XDA notes that some users have reported BSODs and says the author hasn't seen any. Microsoft's own documentation shows the risk is real for certain monitors. The sensible approach is to save your work first, start with the default controls, and leave the risky ones off unless you need them. Laptop panels are detected separately, so Microsoft says they aren't polled for capabilities they don't expose.
The wider picture
PowerToys keeps shipping. Microsoft's Windows Command Line blog describes 0.102 as bringing a set of new command-line tools for automating PowerToys. A third-party changelog tracker lists v0.102.2933.0, October 21, 2026 as the latest stable feature release. Check the official GitHub releases page for the current build before you install.
The suite's own documentation also lists many tools XDA doesn't cover. These include File Locksmith, Registry Preview, Environment Variables, Hosts File Editor, Workspaces, Text Extractor, ZoomIt and Advanced Paste. Each is optional, and you can turn off whatever you don't use.
Bottom line
You don't need to agree that PowerToys is the best free app on Windows to see the point. Command Palette, Mouse Without Borders and Power Display each fix a specific annoyance. Start with one that matches your setup.
- One PC, lots of apps: try Command Palette.
- Two PCs on one desk: try Mouse Without Borders.
- Multiple external monitors: try Power Display, but save your work first and keep the risky controls off.
- PowerToys has quietly turned into the best free app on Windows, and most people still only use it for FancyZones XDA · 2026-11-01T19:30:20+00:00
- PowerToys 0.102 is here: new mouse utilities, Command Palette improvements and much more - Windows Command Line devblogs.microsoft.com
- Releases · microsoft/PowerToys · GitHub github.com
