Illustration of a spreadsheet coordinating email, task boards, analytics, and automated workflow alerts.
Excel is very good at storing, calculating and tracking data. It is much less good at telling you when something changed, presenting the numbers to a team, or doing the dull checking for you. How-To Geek's Tony Phillips tried four tools on a 40-task Excel project tracker: Zapier, Power BI, Airtable and Power Automate for desktop. His results are firsthand, and they are worth reading alongside the vendors' own documentation. The four tools do very different jobs, and none of them is a simple "live link" to Excel.
Illustration of a spreadsheet coordinating email, task boards, analytics, and automated workflow alerts. Four tools, four different jobs​
ToolWhat it did in the tracker exampleKey boundary
ZapierSent a Gmail notice when a new task row appearedCloud-hosted workbook, polling delay, account requirements
Power BIBuilt linked charts with a slicerRefresh behavior and sharing licenses
AirtableShowed the tasks as grid, calendar, Kanban and List viewsThe import is a copy, not a sync
Power Automate for desktopListed overdue tasks not marked CompleteRuns when invoked; OneDrive-synced files can cause errors
Zapier: let the workbook tap you on the shoulder​
Phillips built a Zap that watches the tracker and emails him the task name whenever someone adds a row. He suggests the same pattern could post to Teams or Slack, or create records in other services.
Free-plan limits. Zapier's documentation says Power BI runs a "OneDrive refresh" and by default checks about every hour whether the file needs synchronizing. That is separate from a manual refresh like the one in Phillips's test. Microsoft also warns that copying a file over the original creates a new item ID and breaks the refresh. Upload-and-replace keeps the ID.
Sharing depends on license. Microsoft's licensing guidance says free users can build content for their own use but can't share or collaborate in shared capacity. Pro users can share with other Pro users. Content in Premium or Fabric F64-or-larger capacity can reach free users. In a Premium Per User workspace, everyone needs a PPU license. "Pay for Pro" is a fair summary, but viewer requirements vary with the workspace and capacity.
Airtable: a friendlier front end, on a copy​
Phillips picked Airtable as his favorite. He imported the tracker into a new base, and all 40 tasks and their fields came across. Repeated options became drop-down fields, and numeric values and number formatting survived. Status values appeared as colored pills. He then switched between grid, calendar, Kanban and List views. Dragging a card in Kanban changed the record's status, and the change showed up in the grid.
How the import works. Airtable's help documentation says you can import an Excel file into a new base, an existing table or a new table. The import wizard lets you choose which fields to include and toggle automatic field types and "first row as headers." Each worksheet becomes its own table, and the first row supplies the field names. The documentation also lists a 5MB limit for Excel imports.
The caveats.
  • The import is a copy. Edits in Airtable don't flow back to Excel, and Excel edits don't flow into Airtable.
  • Airtable's plans overview lists a 1,000-record cap per base on the Free plan.
  • Treat Phillips's clean import as one example, not a guarantee for every workbook.
Power Automate for desktop: the overdue-task check​
Phillips built a flow that reads each task's status and due date, collects the overdue tasks not marked Complete, and shows them in one message. His tracker produced 12 tasks. He suggests the same idea for unpaid invoices, outstanding orders or records needing updates.
Microsoft's Excel actions reference confirms the building blocks. A flow launches Excel or attaches to a running instance, then uses "Read from Excel worksheet" to pull a cell or a data table. It can also write values back.
OneDrive-synced files. This is the catch for anyone whose workbook lives in OneDrive. Microsoft says files in folders synchronized through OneDrive or SharePoint can cause the flow to fail, because Power Automate for desktop uses COM objects to interact with Excel and OneDrive and SharePoint don't fully support Excel instances launched that way. You might see a "file not found" error. Microsoft's suggested workarounds are:
  1. Make a local copy of the workbook, run the flow against it, then replace the synced file with the updated copy.
  2. If Launch Excel fails, use "Run application" to open Excel, wait long enough for it to load fully (including add-ins), then use "Attach to Excel."
Reading dates and text. Microsoft also notes that the Read from Excel worksheet action can return typed values, plain text or formatted text. For a date-driven check like overdue tasks, typed values keep dates as real dates. Plain text returns what is displayed, which can include "###" when a column is too narrow.
What the example is. It is a flow you run by hand, not a continuously running alert. It's also a different kind of tool from Zapier. It acts on files and desktop apps rather than waiting on a cloud trigger.
Which one fits which job?​
  • You want to be told when a row is added: Zapier, if your workbook is cloud-hosted and your Microsoft account qualifies.
  • You want shared, interactive reporting: Power BI, after checking how refresh will work and who needs which license.
  • You want people to work on the same records in different layouts: Airtable, as long as you accept that it's a snapshot unless you add your own sync.
  • You want a repeatable check on worksheet data: Power Automate for desktop, ideally against a local file.
The bottom line​
Phillips's piece is a sensible nudge: when Excel feels overloaded, add a tool around it rather than another formula. The catch is that these are four different integrations with four different rules. Zapier polls on a schedule and is fussy about workbook structure. Power BI's freshness depends on how the report was built. Airtable's import is a one-time copy. Power Automate for desktop runs when you run it and can trip over OneDrive-synced files. Check those limits against your own setup before you hand a tracker over to any of them.
  1. Connecting Excel to these 4 tools saved me from doing the busywork myself How-To Geek 2026-11-02T15:30:15+00:00
  2. How to get started with Microsoft Excel on Zapier – Zapier help.zapier.com
  3. Airtable plans overview | Airtable Help Center support.airtable.com
