A man studies an open, RGB-lit gaming PC packed with cooling fans and high-performance components.
A PC builder has just publicly sworn off AIO liquid coolers for good. That's the headline, and the reasoning is more useful than the drama. XDA-Developers writer Tanveer Singh says the AIO in his current rig was the most pointless part he has bought in recent builds. He fitted it for looks. His 65W Ryzen 7 5700X didn't need liquid cooling, and in his words the cooler didn't do a great job anyway. After more than three years with it, he plans to use air coolers in every future build.
This is one person's experience, not a lab test. The piece names no cooler model and gives no benchmark numbers. It is still a good excuse to ask whether your next build needs a radiator.
A man studies an open, RGB-lit gaming PC packed with cooling fans and high-performance components. The author's case, in brief​
Singh's argument rests on a few points:
  • Most people don't buy flagship CPUs. He says the popular chips are budget and mid-range parts, such as today's six-core processors. He thinks a $35–$50 air cooler handles them fine.
  • Exceptions exist. He carves out Core i9, Core Ultra 9 and Ryzen 9 systems, plus overclocked enthusiast builds. Outside those, he calls liquid cooling "strictly optional" and mostly an aesthetic choice.
  • He knows his own habits. Gaming is his main use, and he expects his next CPU to be a six-core, possibly Zen 6 or Zen 5.
  • Air is simpler to live with. An air cooler has no pump and no coolant to leak. A bad fan can often be swapped on its own. A dead AIO usually means replacing the whole unit. Installing and removing an air cooler is also easier, because there is no radiator or tubing to protect.
  • Looks aren't a differentiator. He points out that RGB and display-equipped air coolers exist.
What the specs say​
The processor numbers in the piece hold up. AMD lists the Ryzen 7 9700X as an eight-core, 16-thread Zen 5 chip. Its default TDP is 65W, and its maximum operating temperature (Tjmax) is 95°C. An eight-core chip at 65W TDP is a real change from the previous generation. TechSpot's comparison table shows the older Ryzen 7 7700X at a 105W TDP. The newer chip's rating is lower.
Two caveats matter before anyone treats "65W" as the amount of heat to cool.
TDP is not power draw. CpuTronic cautions that a 65W TDP should not be read as exact maximum power consumption. Hardware Busters' spec table lists a default socket power (PPT) of 88W for both the 9700X and the 9600X. That is the figure to keep in mind when sizing a cooler. Boards can also raise the limits. CPU-Monkey notes a 105-watt mode can be enabled in the BIOS. LTT Labs found the 9700X would readily draw 140W once its power limit was removed, and that still stayed within its Tjmax.
AMD itself doesn't say "any cooler will do." AMD's product page lists "Premium air cooler recommended for optimal performance" for the 9700X. That backs the author's air-cooling preference. It also shows that "budget cooler" and "premium air cooler" are different things, even at 65W.
Is "high temperatures are fine" safe advice?​
Singh says high CPU temperatures are acceptable as long as the chip isn't throttling. That is broadly consistent with how modern Ryzen chips are designed. TechSpot reports that AMD describes Tjmax as the maximum safe operating temperature, not an absolute limit, and that these processors are designed to run at Tjmax around the clock without damage. Hardware Busters lists typical loaded temperatures of 70–90°C for the Ryzen 9000 chips.
A sustained 90°C reading can still look alarming on a monitoring overlay. It doesn't automatically mean your cooler is failing. The sensible test is whether the system holds its expected clocks and stays quiet enough for you.
Where an AIO still makes sense​
The piece is explicit that liquid cooling suits some users, and the data supports that. Some reasons a buyer might still want an AIO:
  • High-power CPUs. The author's own exceptions are the Core i9, Core Ultra 9 and Ryzen 9 tiers, and overclocked systems.
  • Clearance problems. Large tower air coolers can crowd tall RAM or tight cases. A radiator moves the bulk to a case panel.
  • Looks. If you want the pump block and radiator as part of the build, that's a legitimate reason, as long as you're honest about it. The author says he was.
  • Layout preferences. Some builders want the area around the socket clear for access.
The author's claim that "today's air coolers can easily handle" around 200W is a generalization. Cooler capacity varies by model, case airflow and noise target. Treat it as a reason to read reviews of the exact cooler and CPU you're considering, not as a guarantee.
Practical buying checklist​
  1. Find your CPU's real power behavior. Look up its default power limit (PPT) in reviews, not just the TDP.
  2. Check your cooler's rating against that load. Prefer a model with reviews for a similar chip.
  3. Measure physical clearance. Check cooler height against your case, and RAM height against the cooler.
  4. Set a noise goal. Fan curves matter on both cooler types, and an AIO adds pump noise as another variable.
  5. Run a sustained test after building. Use a long all-core load and a long gaming session. Watch clocks, not just temperature.
  6. Budget for the failure mode. A fan on an air cooler is a cheap swap. An AIO pump failure usually means replacing the unit. The author makes this argument, but no failure-rate data was provided to quantify it.
The takeaway​
The article is a personal verdict, and it's a reasonable one for a gaming-first builder who buys mainstream CPUs. The verified context makes it more useful. Current 65W-class Ryzen chips pair a modest rated TDP with a recommendation for a quality air cooler. High temperatures near Tjmax are within AMD's design intent. The real decision should come from your exact CPU, case, noise goal and budget, not from the assumption that every modern PC needs a radiator.
If your build lands in the mainstream six- or eight-core tier, the author's logic is sound. A good air cooler saves money and removes a pump from the list of things that can break. Buy an AIO because you want one, not because a forum thread said you need one.
  1. The one PC component I've blacklisted from my future builds XDA 2026-11-21T14:30:20+00:00
  2. AMD Ryzen 7 9700X: Detailed Specifications and Benchmark Ratings - CpuTronic cputronic.com
  3. AMD Ryzen 7 9700X Review: Zen 5 Arrives - TechSpot techspot.com
