What the Cat8 standard actually is
Cat8 is a real standard. The Telecommunications Industry Association (TIA) released TIA-568-C.2-1 in July 2016. The addendum covers shielded Category 8 balanced twisted-pair cabling and components for use in data centers, equipment rooms and other spaces that need high-speed applications. That is the first clue to its purpose. It was written for server-to-switch links, not for the run from your living room to the home office.
Fluke Networks' Cat8 fact sheet gives the numbers that matter:
- Cat8 is shielded only. There is no unshielded variant, so shield terminations need careful attention.
- Earlier categories had a 90 m permanent link and a 100 m channel. For 25 and 40 Gbps, Cat8 is limited to a 24 m permanent link and a 30 m (about 100 ft) channel.
- Cat8 supports 10 Gbps and lower rates over a full 100 m channel.
- Field testing runs from 1 MHz to 2000 MHz, versus 500 MHz for Cat6A.
So a Cat8 cable is not a faster cable for everyday use. It is a cable that unlocks 25GBASE-T and 40GBASE-T over short distances, and only if the switch and network card at both ends support those speeds. Your router, your PC's network adapter and your internet plan still set the ceiling.
Where the Cat6 case holds
Fluke's comparison table lists the main categories like this:
| Category | Max frequency | 10GBASE-T support |
| Cat5e | 100 MHz | No (Gigabit is supported) |
| Cat6 | 250 MHz | Shortened runs only (35 m max in Fluke's table) |
| Cat6A | 500 MHz | Full 100 m channel |
| Cat8 | 2000 MHz | Full 100 m channel; 25/40GBASE-T limited to 30 m |
Fluke also notes that the NBASE-T specifications define 2.5 and 5 Gbps at up to 100 m over Cat5e, Cat6 and Cat6A. It adds a caution: not every Cat5e installation can support them, so certification is recommended. For a house with a 2.5 GbE motherboard port and a multi-gig router, an ordinary Cat6 run does the job.
Gigabit-only homes can stay on Cat5e. Fluke's table lists Cat5e as supporting 1000BASE-T. Cat6 adds headroom, and in most homes it costs little more.
The "10 Gbps up to 55 meters" caveat
The XDA piece says Cat6 handles 10 Gbps up to 55 m. That figure is real, but it comes with conditions. The standards guidance is TIA TSB-155-A. ICC, a cabling vendor, summarizes it this way: 10GBASE-T can operate over Cat6 channels up to 37 m, and should operate between 37 and 55 m depending on the alien crosstalk environment. Alien crosstalk is interference from neighboring cables, and it gets worse when cables are tightly bundled.
Treat 55 m as a best case rather than a guarantee. ICC also states plainly that Cat6 is not recommended for new installations meant to support 10GBase-T, and that Cat6A is the choice for 10GBase-T copper. Fluke's table gives a more conservative 35 m limit for Cat6 and 10GBASE-T. Vendor and standards summaries differ slightly, but they agree on the direction: Cat6 is conditional at 10 Gbps, and Cat6A is not.
Most homes never get near these lengths. A typical in-wall run to a bedroom or office is well under 37 m, and 10 Gbps over Cat6 is very likely to work there. The risk grows in large houses, outbuildings, and bundles of many cables pulled through the same conduit.
Cat6A: the better in-wall bet
If you are pulling cable through walls for the first time, the XDA argument for Cat6A is the strongest part of the piece. Cat6A is specified to 500 MHz and supports 10GBASE-T over the full 100 m channel. One vendor guide describes Cat6A's larger diameter as the main cost driver, through conduit fill and bend radius, rather than its per-foot price. That trade-off is worth knowing before you buy. Cat6A is bulkier, so it takes more care in tight conduit and at sharp turns.
The labor involved in opening walls dwarfs the price gap between cable types. If you are doing it once, spend a little more for the cable that standards say will carry 10 Gbps to every room.
Where the XDA piece goes too far
Several claims in the original are stated more firmly than the evidence supports:
- "No one needs Cat8 at home." Better phrased as "most households don't." A home lab with a 25/40 Gbps switch and short runs between a server rack and a workstation is a legitimate Cat8 use case.
- Connectors. The article says Cat8 needs specialized grounded connectors. Fluke says the TIA Cat8 solution uses the familiar 8-position modular connector, commonly called RJ45, and was designed to be backward compatible with connectors used from Cat5e through Cat6A. The shield does still need proper termination, which matters if you crimp your own ends. The standards also define an ISO/IEC Category 8.2 variant whose connector interfaces are not backward compatible with RJ45. That is rare in home gear.
- Cat7. The article says Cat7 was never recognized by TIA and needs GG45 or TERA connectors. One reference page I found does say Cat7 isn't a TIA category, but I could not confirm the connector claims here, so I'd treat them as unverified. The practical lesson stands either way: a cheap "Cat7" patch cable with plain RJ45 ends is a label, not a certification.
- Prices and broadband figures. The article cites roughly $10 for 100 ft of Cat6 and $20 for Cat8, plus a US median broadband figure of about 300 Mbps. I found no dated, like-for-like sourcing for either, so don't rely on those exact numbers. Prices vary widely by seller, and cheap cable of any category may be copper-clad aluminum (CCA) instead of solid copper.
- Flexibility and PoE. Cat8 is generally shielded and heavier, so it is likely stiffer than typical Cat6. The standards sources don't compare products, though, so the specific build matters. On Power over Ethernet, Fluke warns that not every cable supports every power level, and that cables which deliver power only intermittently are hard to troubleshoot. Cable quality and testing matter more than the category printed on the jacket.
A practical buying guide
- Check the ports first. Look at the switch, router and PC adapter. A 1 GbE network gains nothing from Cat8.
- Measure the run. Under about 37 m, Cat6 will normally handle 10 Gbps. For longer runs, or any new in-wall installation that should support 10 Gbps, choose Cat6A.
- Use Cat8 only for short, fast links. Think 25/40 Gbps equipment and runs within 30 m, with matching hardware at both ends.
- Buy solid copper, not CCA. Check the packaging for copper specifications and certification marks.
- Test what you install. Fluke notes that a link counts as certified only if the cable and connecting hardware meet their standards, the installation is done correctly, and it passes a compliant field tester. Home users rarely buy certification gear. At minimum, run a speed test and watch the error counters on your switch.
The bottom line
Cat8 is a genuine standard with a narrow job. For ordinary home networks, Cat6 is a sensible default and Cat5e covers Gigabit. For new in-wall wiring where 10 Gbps matters, Cat6A is the safer choice. Spending extra on Cat8 in a typical house buys frequency headroom that your equipment cannot use.
- Cat8 cables are a waste of money for your house, and Cat6 does everything you need XDA · 2026-10-13T18:30:17+00:00
- TIA issues New Balanced Twisted-Pair Telecommunications Cabling and Components Standard, Addendum 1: Specifications for 100 Next Generation Cabling Standard | Telecommunications Industry Association standards.tiaonline.org
- Cat 8 Ethernet Cable Fact Sheet | Fluke Networks flukenetworks.com
