The short version
| Question | Tool | Where to find it |
| Which apps used the battery over time? | Battery usage | Settings > System > Power & battery > Battery usage |
| What is drawing power right now? | Task Manager | Ctrl + Shift + Esc > Processes |
| Has the battery itself worn out? | Battery report | powercfg /batteryreport |
| Is something blocking power savings? | Energy report | powercfg /energy |
| What can I change safely? | Energy recommendations | Settings > System > Power & battery > Energy recommendations |
These tools give clues, not verdicts. The original piece is a how-to and reports no measured results or specific laptop model. Its 50,000 mWh and 35,000 mWh capacity figures are an illustration only.
Step 1: Battery usage, to see the pattern over time
Open Settings > System > Power & battery > Battery usage. You get a battery-level graph and a per-app breakdown. How-To Geek says you can view the last 24 hours or the last 7 days.
Microsoft's guidance on background activity adds a useful detail. Apps can keep working when you aren't looking at them. Some apps let you manage background activity. Microsoft's support page says the control is available only for supported apps.
To change an app's background behavior:
- In Battery usage, find the app and select More options > Manage background activity.
- Under Let this app run in the background, pick one of three options.
- Always lets the app receive info, send notifications and stay current. This may use more power.
- Power optimized (recommended) lets Windows balance power savings against periodic updates and notifications.
- Never stops the app running in the background when you aren't using it. You get no notifications or updates from it, but it saves the most power.
Don't assume the app at the top of the list is misbehaving. A video editor mid-render or a container platform like Docker will naturally rank high. Compare the usage against what you were actually doing when the battery dropped.
Step 2: Task Manager, to see what is happening now
Press Ctrl + Shift + Esc and open Processes. Look for the Power usage and Power usage trend columns.
If they are missing, they may be hidden. Windows Central and XDA-Developers both describe right-clicking a column header to enable them. Winaero says the Power usage value is calculated from the disk, GPU and CPU resources the app is using. That means it is a rough estimate, not a wattage reading.
The two columns work together:
- Power usage is a snapshot. XDA-Developers lists the labels as Very low, Low, Moderate, High and Very High.
- Power usage trend is a longer-running average. A process can read "high" during a brief spike while its trend stays "low" because it normally uses little power.
Pay attention when both columns stay high while the laptop is nearly idle. A single spike is usually just a process doing its job.
Before ending a process:
- Identify it. If you don't recognize the name, look it up. Don't kill unknown Windows processes on sight.
- Close apps you don't need, check for updates, or restart the misbehaving program.
- In a browser, expand the process list. XDA-Developers describes finding that one tab was responsible for a jump in browser power usage, not the whole browser.
Step 3: Battery report, to check whether the battery is worn
Sometimes nothing is misbehaving and the battery has simply aged. Windows can generate a report for this. Microsoft's instructions for Windows 11 are:
- Search for Command Prompt, right-click it, choose Run as administrator, and select Yes. How-To Geek says Windows Terminal also works.
- Type
powercfg /batteryreportand press Enter. - Note the file location Windows prints in the window. The report is an HTML file.
- Open File Explorer, go to that folder, and double-click the file to open it in your browser.
Microsoft suggests starting with the Installed batteries, Recent usage and Battery usage sections.
Within Installed batteries, compare two figures:
- Design Capacity is what the battery could hold when new.
- Full Charge Capacity is what it can hold now.
If the full-charge figure is well below the design figure, no setting will bring the lost capacity back. How-To Geek's example is a 50,000 mWh design capacity against 35,000 mWh now. That works out to 70% of the original, a 30% loss. It is only an example, and neither How-To Geek nor Microsoft gives a replacement threshold, so treat it as an illustration and not a rule.
Microsoft also notes that lithium-ion capacity falls with charge-and-discharge cycles and age. Its care advice includes:
- Keep the charge roughly in the 20%–80% range where possible.
- Avoid heat.
- For storage, leave the battery at about 40–60%.
- Turn on Smart charging if your device supports it.
- If a battery visibly swells, stop using the device.
Microsoft's Learn documentation also lists optional switches for the battery report: /output <file_name> to choose where it is saved, /xml for XML format, and /duration <days> to limit the period analyzed.
Step 4: Energy report, to find system-level snags
Open PowerShell or Command Prompt as administrator and run powercfg /energy. Windows watches the system for about 60 seconds, then writes an HTML report.
Microsoft's documentation adds a condition. Run it when the computer is idle with no programs or documents open. If you run it mid-workload, the report may flag activity you caused yourself. This is worth knowing because the How-To Geek article doesn't mention it.
The report sorts findings into errors, warnings and informational items. They can include devices that block power-saving states, high processor use and USB power-management issues.
Don't panic over a long list of warnings. Look for the ones that repeat or match how your laptop actually behaves. Sensible follow-ups are:
- Unplug a flagged USB device when you're on battery.
- Check for driver updates if the report points at a device.
A warning in the report doesn't prove it is the cause of your battery drain. It is a lead to follow up.
Microsoft's documentation also lists /output to pick a save location and /duration seconds to change the monitoring time.
Step 5: Energy recommendations, then apply only what fits
Go to Settings > System > Power & battery > Energy recommendations. Each suggestion has its own Apply button, so you don't have to accept them all.
Microsoft says what you see depends on your device type and on whether it is plugged in or on battery. Some items are missing on certain hardware. Items Microsoft documents include:
- Power mode set for best energy efficiency, described as a balance between efficiency and performance.
- Screen brightness. The brightness recommendation isn't yet enabled for external displays.
- Sleep and screen-off timers set to three or ten minutes, depending on the system.
- Content-adaptive brightness and contrast, which Microsoft says you can turn off if the changes distract you or you do color-critical work.
- Ambient-light adaptive brightness.
- Presence-based sleep and dimming, which need a presence sensor.
- Turning off the screen saver.
- Stopping USB devices while the screen is off.
Be selective if you do demanding work. A more restrictive power mode can cost performance, so choose settings that match your workload.
A sensible order of operations
- Check Battery usage. Look for patterns, not a single culprit.
- Use Task Manager to see whether a process is high on both power columns while you're idle.
- Run the battery report to rule the battery itself in or out.
- Run the energy report on an idle machine and look for repeated findings.
- Apply energy recommendations that suit how you work.
- Revisit Battery usage now and then. New apps, services and updates can change consumption over time.
If Design Capacity and Full Charge Capacity are far apart, the battery is the likely culprit and no setting will fix it. Otherwise, one of the earlier steps usually points to a fixable cause before you spend money on a replacement.
- I checked Windows 11's built-in tools to see what was draining my laptop battery - How-To Geek How-To Geek · 2026-11-13T13:00:16+00:00
- Customize Windows 11 Task Manager Columns and Settings winaero.com
- Find the app responsible for draining your laptop battery with my Windows 11 tips windowscentral.com
