A laptop and ultrawide monitor display a financial spreadsheet and photo gallery at a modern office desk.
HP's new 34-inch ultrawide, the Series 3 Pro 334wp G2, is a USB-C docking monitor aimed at office desks. It has a curved panel, up to 90W of laptop charging and a built-in KVM switch, and it costs less than most monitors with that feature set. It also has a refresh-rate discrepancy that buyers should know about before they order.
A laptop and ultrawide monitor display a financial spreadsheet and photo gallery at a modern office desk. What HP has announced​
Notebookcheck reports that the 334wp G2 is listed on HP's official store for $329. It has a 34-inch curved VA display with WQHD resolution, a 120Hz rating and 300 nits of brightness. The same report says it can't be bought yet. Treat the price as a snapshot from October 31, 2026. Pre-launch listings often change.
HP's own regional product page describes the monitor as a curved 34-inch ultrawide WQHD monitor. It is pitched at focused work and simple, scalable deployment. That is IT-department language for buying a lot of them and not having to think about it.
Specifications​
  • Panel: 3440 x 1440 resolution on a 34" 1500R curved monitor. The panel is VA with LED backlighting.
  • Contrast and brightness: HP lists a 3500:1 contrast ratio and, per its Thai product page, brightness of 300 nits.
  • Response time: HP quotes 5ms GtG with overdrive. That is a manufacturer figure, not a measurement.
  • Color: HP's regional spec sheet lists 85% NTSC. TechPowerUp adds that there is no webcam or HDR support, and the color gamut is modest. It concludes that image or video retouching is possible but not recommended.
  • USB-C: One USB Type-C port at 5Gbps signaling, with up to 90W USB Power Delivery and DisplayPort 1.2 Alt Mode.
  • Other ports: Three USB-A 5Gbps ports, a USB-B upstream port, one DisplayPort 1.2, one HDMI 2.0 and an audio jack.
  • Audio and stand: Notebookcheck reports two 5W speakers. HP lists the stand as height adjustable, with tilt and swivel.
  • In the box: A USB-C to USB-C cable (1.8 m), an AC power cable, a warranty card and a quick setup poster.
  • Warranty: Three years.
The 120Hz question​
Most coverage, including the reports behind this story, repeats HP's headline claim of 120Hz at 3440 x 1440. HP's own pages don't fully agree with each other on this.
HP's New Zealand spec sheet lists a maximum resolution of 3440 x 1440 @ 120 Hz. Its list of supported timings, in the part I could read, ends at 3440 x 1440 @ 100 Hz. I could not verify the full timing table or any footnotes about cable types. My research notes suggested 120Hz may be limited to a lower resolution or to HDMI and DisplayPort connections, but I couldn't confirm that.
What this means in practice:
  1. Expect at least 100Hz at native resolution. HP's own timing list supports that much.
  2. Don't assume 120Hz at 3440 x 1440, especially over USB-C. DisplayPort 1.2 Alt Mode over a 5Gbps USB-C link is a modest pipe for a high-refresh ultrawide.
  3. If 120Hz matters to you, wait for the full datasheet or an independent review. Check the exact resolution, refresh rate and cable type.
One cable, with caveats​
The pitch is that a single cable can carry video, data and up to 90W of power to a laptop. That works well for many thin-and-light business laptops, but check a few things first:
  • Video over USB-C: the laptop's port must support DisplayPort Alt Mode. Some USB-C ports are charge-only or data-only.
  • Power: 90W is the monitor's maximum output. A workstation or gaming laptop that wants more will charge slowly or not at all under load.
  • Hub bandwidth: the USB-A ports and USB-C data link run at 5Gbps. That suits keyboards, mice, webcams and flash drives, not high-speed external SSD workloads.
KVM and two computers​
Notebookcheck says users can keep two hosts connected at once and switch between them with the built-in KVM. The sources I found don't describe how switching works. They don't say which upstream connections each host needs, or whether the USB-B upstream port has to be used. Check the user guide before planning a two-PC desk. Typically a KVM needs a USB upstream link from each computer as well as a video input.
Who it suits​
  • Good fit: offices standardizing on USB-C laptops, hybrid workers who want a cheap docking display, and anyone who wants a big workspace for spreadsheets and documents.
  • Weaker fit: color-critical work, HDR content, and anyone who wants proven 120Hz at native resolution.
HP's marketing says the monitor is suitable for gaming. For a 5ms GtG VA panel with no HDR, I'd wait for independent measurements, since VA panels can smear in dark scenes. That is general industry knowledge, not a test of this monitor.
Bottom line​
At $329, the 334wp G2 packs a lot of docking features into an affordable ultrawide. Confirm the real refresh rate and the KVM behavior before you buy, and note that the monitor wasn't purchasable as of October 31.
  1. HP Series 3 Pro 334wp G2 brings 90W USB-C charging to a 34-inch monitor - Mezha.net Mezha.net 2026-10-31T13:58:32+00:00
  2. HP Introduces Series 3 Pro 34-inch 120Hz Ultrawide Professional Monitor with 90W USB-C Power Delivery techpowerup.com
  3. New 34-inch HP Type-C monitor debuts with 90W PD support and USB-A hub - Notebookcheck News notebookcheck.net
