What the writer actually did
The author's reasons were simple. He has long working days, a lot of dense text on screen, and a desk that can only take so much monitor. By his account, his 43-inch panel was also stuck at 60Hz.
His reported experience with the IRIS Ultra Max:
- Scalable image: The optical zoom lets him shrink or enlarge the picture. He says he has gone as large as 120 inches and found it "tack-sharp".
- Motorized gimbal: After work he can swing the projector around to throw a large image on the wall behind him for streaming. He says it remembers positions for different spots, so switching takes seconds.
- Window-lit study: He says the 6,500-lumen rating holds only under specific conditions, such as a pure white screen. Real-world brightness is noticeably lower but still usable. Ambient light also affects perceived contrast.
- 120Hz mirroring: He says he mirrored his MacBook Pro's display at 120Hz without trouble. He doesn't name the model, cable or settings.
- Bare white wall: He doesn't have room for an ambient-light-rejecting screen, so he uses a blank wall and adjusts the projector's dual iris to get better contrast.
He is also upfront that this isn't for monitor purists or serious gamers. In his view, casual gamers and entertainment fans will be satisfied, and so will anyone who just wants a lot more screen real estate. He calls it a pricey upgrade.
Note that these are one person's impressions. The piece includes no measured luminance, contrast, latency or text-clarity figures, so treat "tack-sharp" as an opinion rather than a benchmark.
What JMGO says the hardware does
Spec claims here come from JMGO and from outlets repeating them, not from independent testing.
- Brightness and contrast: JMGO rates the Max at 6,500 ISO lumens with 10,000:1 native contrast. A trade outlet noted this is a manufacturer claim, and independent testing is needed to see how the dual-iris system performs across brightness settings.
- Placement: Forbes lists a 0.88–1.7:1 throw ratio, four-way lens shift, and an AI gimbal with 360° pan and 150° tilt. It also lists a feature that saves and recalls projection positions for different walls. That matches the quick-switch behavior the author describes.
- Price: JMGO's US store listed the Max at $2,999, down from $3,499. XDA's own product box also shows $2,999. Prices and promotions change, so check the current listing before buying.
- Launch timing: Preorders opened on September 4, with shipments scheduled to begin on October 19. That is the same day the XDA piece ran.
The chip story needs a correction
The XDA piece credits Texas Instruments' DLP472TP chip for making cheap 4K/120Hz projectors possible. It also says the projector uses two of those chips. The supporting documents tell a more precise story.
- A 1080p mirror array: The DLP472TP has a 0.47-inch diagonal and a physical matrix of 1,920 × 1,080 mirrors, not 3,840 × 2,160. The full 4K image comes from pixel shifting. The same first-look report says a four-phase process uses a high-speed optical actuator to shift the projected pixels in four slightly offset directions.
- The DMD alone tops out at 4K/60Hz: TI's own listing says the DLP472TP supports 4K UHD at 60Hz and 1080p up to 240Hz.
- Two controllers get it to 120Hz: TI's DLPC8545 page describes a 4K UHD, 120Hz controller for the DLP472TP, and says dual DLPC85x5 controllers support up to 4K UHD at 120Hz. JMGO's own FAQ says the IRIS series uses two DLPC8545 controllers, and that this dual-controller design enables 4K@120Hz.
- A faster actuator: Forbes says JMGO's "HyperPulse Actuator" shifts the mirrors 480 times per second so the image keeps full 4K detail at 120Hz.
So the accurate description is one 0.47-inch DMD driven by two controllers and a fast pixel-shifting actuator. It is not two imaging chips. This matters because it explains why 4K/120Hz projectors weren't common before, and why the capability isn't simply "built into" the chip.
Pixel-shifted 4K is also not the same as a native 4K panel. The author says the result looks practically the same as native 4K. That is his impression, and nobody has run a side-by-side text-clarity comparison in the material reviewed here.
Can this work as a PC display?
Here is how I would think about it as a PC user. This is general analysis, not test data.
- Check the whole signal chain. 4K/120Hz needs a GPU, cable and projector input that all support it. JMGO lists two HDMI 2.1 inputs on the Max, and the HDMI 2.1 spec includes 4K/120Hz and VRR. Your graphics hardware and cable still have to match.
- Don't confuse refresh rate with latency. JMGO lists 1ms input latency, but doesn't give the measurement method in the material reviewed. 120Hz alone doesn't tell you the end-to-end response time.
- Treat frame interpolation separately. The Max also offers 4K/120Hz motion interpolation (MEMC) for video. A native 120Hz desktop signal doesn't depend on it, and you will probably want it off for work.
- Plan for the room. Throw distance, wall space and window light matter more than the lumen number. The author says he had to accept lower contrast near his window.
- Watch for rainbow artifacts. Single-chip DLP projectors can show red, green and blue striping on bright highlights. Forbes says the high-refresh architecture reduces this rainbow effect. Sensitive viewers should still try one before committing, especially for long text-heavy sessions.
- Mind the desk, not just the wall. JMGO lists the Max at 7 kg and 300W, so it needs a stable, ventilated spot. The vendor's noise figures are up to 26 dB at one meter, and 17 dB in standard picture mode, under specified conditions.
Where it falls short
The weak points are fairly clear:
- The evidence is thin. This is one writer's setup, on a Mac, with no measurements.
- The price is high. At about $3,000 it costs far more than a good 4K monitor. A 4K 144Hz or 240Hz monitor will beat it on pixel density, brightness in daylight and input response.
- Text on a wall is a compromise. Even sharp projection depends on focus, wall flatness and ambient light.
- Vendor claims stay vendor claims. Brightness, contrast and latency are JMGO's numbers.
Bottom line
The most interesting part of this story is not that a projector beat a monitor. It is that 4K at 120Hz is now available in a projector priced in the same range as a premium display setup. The author's case is flexibility: one device that gives a huge workspace by day and a wall-sized entertainment screen by night.
For Windows users who want precise text, strong daylight performance and the lowest latency, a monitor is still the safer buy. For anyone with a dedicated room and a taste for oversized desktops, this is worth watching as independent reviews arrive.
- I ditched my monitor for a 4K 120Hz projector, and it completely changed my setup XDA · 2026-10-19T22:00:19+00:00
- JMGO Iris Ultra Max Is World’s First 4K/120Hz ‘Smart’ DLP Projector forbes.com
- JMGO Unveils World-First 4K/120Hz Projector forbes.com
