Blue-backlit wireless keyboard on a white desk by a window.
Logitech’s new K980 Signature Slim Solar+ keyboard shifts a familiar office peripheral into a near–maintenance-free device by relying entirely on ambient light for power, promising a decade-long battery lifespan and a $99.99 street price that places solar charging firmly into mainstream accessory territory.
Background​
Logitech has introduced the Signature Slim Solar+ K980, a full-size wireless keyboard built around a slim solar strip and a low-power design marketed under Logi LightCharge. The company says the K980 can operate for up to four months in complete darkness once fully charged and that its rechargeable cell is engineered to last up to 10 years, removing—or at least radically reducing—the need for user charging on a daily or weekly basis. The keyboard ships with a full-size layout, a number pad, and dual Windows/macOS legends, and it supports pairing with up to three Bluetooth devices as well as enterprise-friendly Logi Bolt connectivity in certain SKUs. Logitech’s announcement arrives in a year where designers and vendors are experimenting with low-energy inputs and sustainability-focused peripherals. The K980 joins a short but visible trend of solar-powered keyboards from major vendors, and it aims to balance everyday ergonomics and shortcut keys with a near‑permanent power source—so long as the keyboard sees light.
What Logitech says the K980 delivers​
  • Power by light only: The K980 charges exclusively through its integrated light-harvesting strip—there’s no USB charging port on the consumer model. Logitech’s guidance states the keyboard needs a minimum of about 200 lux of ambient light (sunlight or artificial) to maintain a charge. When fully topped off, the internal battery will keep the keyboard functional for months in darkness.
  • Long battery life spec: Logitech claims the battery is designed for up to 10 years of service before it should be replaced, positioning the K980 as a multi‑year investment rather than a disposable pane of plastic and cells. The company also notes the battery is user-replaceable in a limited sense: the battery is inside a plastic housing and Logitech says spare parts will be available (iFixit is mentioned as a supplier of replacement parts). Industry coverage urges caution and notes the replacement process requires disassembly.
  • Form and function: The K980 is a slim, laptop-style scissor-switch keyboard with a full-size layout and a numpad. It includes dedicated mic mute and camera toggle keys, an Action key configurable via Logitech’s Options+ app, and a new AI Launch key which defaults to launching Microsoft Copilot on Windows (and ChromeOS Gemini on Chrome devices) but can be remapped to other services including third‑party assistants.
  • Connectivity and management: The K980 supports pairing with up to three Bluetooth devices and can be used with Logitech Bolt for more secure wireless usage—Logitech’s Business SKU comes with Bolt and remote management via Logitech Sync. The consumer SKU appears to rely on Bluetooth only, with Logi Bolt compatibility noted as an option for enterprise buyers.
  • Sustainability: The device’s plastic parts (at least in the graphite SKU) include up to 70% post‑consumer recycled plastic, part of Logitech’s broader sustainability messaging for 2025 accessories.
Deep dive: the power system and the practical implications​
How Logi LightCharge is described​
Logitech’s marketing calls the K980’s power system Logi LightCharge, which combines a light-absorbing strip with a low-power architecture and a rechargeable battery intended to minimize maintenance. The headline physics are simple: a photodiode strip converts light (sunlight or indoor illumination) into energy that trickle-charges the internal cell while the keyboard is exposed to light. Once the cell is full, the keyboard draws from stored energy in the dark. Logitech’s claim of four months in complete darkness is a storage endurance figure—that is, how long the battery will keep the keyboard alive without fresh light.
Practical expectations vs. marketing claims​
Marketing numbers are idealized. The four-month in-darkness figure and the 10-year battery lifespan are plausible in low‑drain keyboard designs, but both depend heavily on usage patterns, light exposure, and environmental conditions. Independent reviews and early hands‑on reporting point out two important caveats:
  • The keyboard needs a minimum light level (Logitech cites ~200 lux) to reliably reclaim or maintain its charge; desks far from windows or in dimly lit offices can drop into “insufficient lighting” which will slowly draw down the battery over time. Reviewers found the companion app’s light-level indicator useful, and Logitech’s power LED switches color to warn of low light.
  • The battery-life and longevity claims are manufacturer projections. Real-world degradation—temperature effects, cell chemistry aging, and cumulative charge cycles—can shorten effective life. When the older generation of Logitech solar keyboards (for example the K750 line) aged, batteries were reported to need replacement after a few years despite functional solar panels. Logitech’s statement that spare parts will be available is encouraging but doesn’t entirely eliminate long‑term risk.
No port, no wired fallback​
The consumer K980 sacrifices a wired fallback: there is no USB port on the consumer model to charge or use it while charging. That makes the solar panel the single path for energy input. If the solar strip is damaged or the internal cell fails and a replacement is not immediate, the keyboard cannot be temporarily powered via USB—unlike many rechargeable peripherals that include a Type‑C port. This design choice simplifies the desk but increases single‑point-of-failure risk. Industry reviewers flagged this as the most significant practical downside.
Features that matter to Windows users and IT departments​
AI Launch key and productivity integration​
The K980 introduces an AI Launch key that is preconfigured to open Copilot on Windows devices. This is part of Logitech’s broader focus on Smart Actions and deep remapping through the Logi Options+ app, which also supports customizable macro‑like workflows. For Windows-centric setups, the key makes invoking Copilot immediate, and IT or power users can reassign it to other assistants or productivity tools (e.g., ChatGPT or Perplexity) through Logitech’s software. That level of customization is aligned with how many organizations are now embedding AI into daily workflows.
Manageability and the Business SKU​
Logitech positions a Signature Slim Solar+ K980 for Business variant as a managed device: it supports Logi Bolt, can be monitored through Logitech Sync, and includes enterprise deployment considerations such as always-on charging states and firmware status reporting. For IT, the appeal is lower maintenance at scale—if the solar system behaves as advertised, fleet keyboards would theoretically need less attention than rechargeable or battery‑powered alternatives. That said, large-scale rollout relies on the product’s long-term reliability, and procurement teams should weigh maintenance‑and‑WARRANTY options carefully.
Multi-device and multi‑OS compatibility​
The K980’s consumer SKU supports three-device Bluetooth pairing and has a multi‑OS printed layout (Windows/macOS/ChromeOS). That fits the modern, mixed-device desktop, where a user might switch between a Windows desktop, a Mac laptop, and a tablet or phone. The Logi Options+ app enables deeper remapping across platforms, though some platform-specific features—like the AI Launch key—are limited or configured differently on Mac SKUs.
Strengths — why this keyboard matters​
  • Sustainability narrative with built-in practicality: Using light as the primary power source reduces the need for disposable AAs, constant charging, or cable clutter. In environments with adequate lighting, power becomes effectively invisible.
  • Low‑maintenance promise for consumers and IT: If the 10‑year battery design proves accurate, the K980 could substantially lower lifecycle maintenance and support calls for keyboards in homes and offices. The Business SKU extends that idea into fleet management by leveraging Logitech Sync and Logi Bolt.
  • Modern, productivity-first feature set: Dedicated mic and camera toggles, an Action key, and the AI Launch key reflect the peripherals market’s shift from mere input devices toward workflow tools optimized for hybrid work and AI-augmented productivity.
  • Reasonable price for the package: At $99.99 for the consumer universal SKU, Logitech prices the K980 in a sweet spot where sustainability features are accessible to mainstream buyers rather than remaining premium niche items. That pricing, combined with recycled plastics, helps make the sustainability message tangible.
Risks and shortcomings to consider​
  • Single power input is a single point of failure: No USB charging port means the solar strip and the internal battery are the only ways to get the keyboard working. If either fails and a replacement part is not immediately at hand, the device will be unusable. Reviewers stress that the lack of temporary wired operation makes reliability critical.
  • Real-world battery life will vary: The 10‑year lifespan and four‑month in‑darkness claims are manufacturer figures. Users should expect real‑world degradation, and environmental conditions (heavy shade, dim offices, or covered desks) will reduce practical battery life. The available app light indicator helps, but conservative buyers should not assume perfection.
  • Typing feel and build tradeoffs: Early hands‑on reviews describe a laptop-like scissor-switch typing feel that some testers found "squishy" or less premium than Logitech’s MX Keys family. Buyers who prioritize premium tactile feedback over sustainability features should compare models before buying.
  • Serviceability uncertainty: Logitech says spare parts will be available via iFixit and that the battery is “safely user-replaceable” because of the plastic casing, but replacing the battery still requires partial disassembly and is not as trivial as swapping standard AA or AAA cells. For non‑technical users, this introduces friction.
How the K980 compares to existing options​
  • Logitech MX Keys / MX Keys S:
  • MX Keys offers a heavier build and a more premium typing experience but uses conventional rechargeable batteries/USB charging (not solar).
  • Users who prefer the MX Keys tactile profile might prefer it over the K980 even if they sacrifice the solar feature.
  • Lenovo and other solar entrants:
  • Other vendors have started shipping solar keyboards and comparable sustainable designs; competition is emerging and prices are converging.
  • The K980’s $99.99 price makes it competitive versus similar solar or low-power keyboards.
  • Traditional wireless/wired keyboards:
  • Wired keyboards eliminate battery concerns entirely; they still require cable management but offer predictable, always-on operation—an important consideration for professionals in critical workflows.
Buying guidance: who should consider the K980?​
  • Users who value desk minimalism and sustainability will see the K980 as an attractive option: no cables, recyclable plastics, and a projected multi‑year battery life.
  • Hybrid workers and multi-device users benefit from the Easy-Switch Bluetooth pairing for up to three devices, and the AI Launch / Action keys give immediate utility in modern workflows.
  • IT teams considering fleet deployment should evaluate the Business SKU for Logi Bolt and Sync support, but they must also include contingency plans for long‑term servicing and part replacement should a solar strip or battery fail after several years.
  • Users prioritizing typing feel above all else—or requiring wired fallback—should compare MX Keys and other premium keyboards before committing. Early reviews caution that the K980’s typing feel is not universally loved.
Practical setup and tips​
  • Place the keyboard in a well‑lit area—ideally near a consistent light source or window—to keep the solar strip harvesting efficiently. Even indirect indoor light at or above 200 lux will help maintain charge.
  • Install Logi Options+ to customize the Action key and to monitor the keyboard’s light‑level indicator. The app improves the operational experience and provides warnings when the keyboard needs more illumination.
  • For enterprise deployment, consider the Business SKU with Logi Bolt and Sync to enable remote device monitoring and secure wireless connectivity. Confirm compatibility with existing endpoint management and wireless security policies.
  • If you plan long‑term ownership, record the device’s serial number and check Logitech/iFixit availability for spare parts in your region; replacing the internal battery requires partial disassembly and a bit of manual work.
Final analysis — is the K980 a meaningful step forward?​
The Signature Slim Solar+ K980 is a pragmatic blend of sustainability features and everyday productivity functionality. Logitech’s engineering and marketing position it as a low‑maintenance keyboard that can feel like part of the desk instead of another gadget to charge. At $99.99, the price point signals Logitech’s intent to mainstream solar charging rather than keep it as an expensive niche.
However, the product’s value ultimately depends on two linked factors: real-world reliability of the LightCharge system and user tolerance for the absence of a wired fallback. If the solar strip and internal battery perform as Logitech projects, the K980 will reduce friction for users tired of battery swaps and charging cables. If those components fail prematurely—or if end users work in chronically dim environments—the K980’s single‑input power model becomes a liability.
Buyers should balance sustainable appeal and convenience against the practical risk profile: for many home and hybrid workers, the advantages will outweigh the downsides; for mission‑critical office work or users who prefer a guaranteed wired option, the K980 should be considered alongside other Logitech offerings and competitive keyboards.
Logitech has put an accessible price on a solar-first keyboard and backed it with enterprise management options for business buyers. The next year of real-world usage and third‑party durability testing will determine whether LightCharge is a long-term pivot in peripheral design or an interesting but limited experiment.
Logitech’s K980 Signature Slim Solar+ is a bold commercial push toward light-powered peripherals that blends sustainability, smart shortcuts, and multi‑device convenience at a mainstream price. The engineering tradeoffs are clear: you gain a largely maintenance-free power model and eco-minded materials in exchange for reliance on a single power canal and a different tactile feel than some premium models. For many Windows users—especially those embracing AI-assisted workflows and minimal desks—the K980 is a compelling, modern keyboard. Conservative buyers and IT teams should conduct short-term trials to validate reliability and serviceability before wide-scale deployment.
