What Logitech says it is
TechRadar's launch report says Logitech G released the Yeti 2 as a successor to the 2009 Blue Yeti. It keeps the pill shape and moves to a redesigned array of three capsules.
Retailer B&H Photo repeats Logitech's pitch that the mic adjusts gain, EQ and pickup pattern automatically in real time. B&H lists it as a USB computer microphone for Windows or macOS.
Logitech's own product page makes these claims:
- Blue VO!CE processing tools run on the mic with no computer software needed. You can adjust them with the onboard display and dial, or go deeper in G HUB.
- The 1.3-inch screen shows level information and tips. It also supports a customizable 8-bit avatar set up in G HUB.
- The AI de-noiser is meant to suppress keyboard clacks, notifications and PC fan noise.
- The mic connects over USB-C with no mixer or preamp needed.
Treat the noise and tracking claims as marketing until independent measurements exist. TechRadar's review gives no quantified results.
Specs
| Item | Detail |
| Capture | 24-bit / 48 kHz |
| Frequency response | 20 Hz to 20 kHz |
| Maximum SPL | 129 dB (Logitech Japan) |
| Signal-to-noise ratio | 77 dB (Logitech Japan) |
| Weight | 995 g |
| Connection | USB-C; the box includes a USB-C to USB-A cable |
| Requirements | USB 2.0 or later port, Windows or macOS |
| Pickup options | Automatic, supercardioid, cardioid, bidirectional, omnidirectional, stereo, custom |
| Warranty | Two years (Logitech Japan) |
Logitech Japan says some advanced features may need G HUB, which is a separate download. A Logitech support page lists G HUB as the software supported at release. Nothing I found names specific Windows versions, so don't assume support for every release.
What the reviewer found
Sound. Blake found the Yeti 2 crisper and clearer than the original Yeti he has used for years, while saying the original was not bad. He credits the move from 16-bit to 24-bit capture and the added noise cancellation. He did not publish controlled measurements or blind tests.
Auto Tracking. The automatic pickup pattern was effective enough that he expects most people to leave it on. He says the auto gain keeps your level steadier as you lean in or away, which he rates above the first Yeti, where you simply got quieter. He also noticed more room echo as he moved away, and he describes the feature as imperfect.
Controls. The display and a single push-in dial replace the old volume, mute, gain and pattern controls. You can change settings and watch levels without opening G HUB. Two drawbacks:
- The dial sometimes didn't register a press.
- Folding several controls into one dial makes scrolling through settings slower than dedicated knobs would.
Logitech Japan also describes a touch-style mute control, so this is not purely a single mechanical button.
Software. G HUB offers presets for interviews, singing, speech-to-text and instruments. It also has manual EQ, gate, compressor and input gain controls. You can save settings to the app or to one of five onboard profiles, and profiles can switch automatically when specific games launch. Blake calls it adequate for beginners but not especially deep. Logitech Japan says settings saved to the mic work even when G HUB isn't running.
Build. The reviewer describes a metal body and metal stand, with a padded base and rubberized lugs to reduce bumps. There is a thread for a boom arm, and the display can be flipped 180 degrees for that setup. He puts the weight at 995 g against 1.4 kg for the original, which he calls almost 50% lighter. Logitech confirms the 995 g figure but not the original's weight.
Price and availability
Logitech's US store lists the Yeti 2 at $159.99. TechRadar gives £139.99 and AU$249.95 for the UK and Australia. These are regional prices, and retailers and promotions will vary.
In Japan, Logitech's release date was October 15, 2026. The Logitech online-store price is ¥28,930 including tax. Logitech Japan calls it an open price, so other retailers may charge differently.
TechRadar says the original Yeti last sold for $139.99 and was on sale for $109.99 on Logitech's site when the review was written. Recheck that before relying on it.
Who it suits
Good fit: people who want plug-and-play USB audio with on-device controls. Streamers, gamers and call-heavy home-office users who move around at a desk will get the most from the automation.
Look elsewhere if you need:
- XLR connectivity. The reviewer says it has none and suggests pro-oriented mics for studio use.
- Dedicated physical controls for every setting.
- The lowest price. The original Yeti is cheaper.
TechRadar names the Elgato Wave:3 and Razer Seiren V3 Pro as alternatives. The Razer model offers 32-bit float recording and XLR, but the review did not test them head to head.
Practical tips
- Plug it into a USB port and see how it sounds in the default auto mode first.
- Install G HUB only if you want deeper EQ, gate, compressor, custom avatars or per-game profiles.
- Save your preferred settings to an onboard profile so they follow the mic.
- Test the auto gain at your normal working distance, because the reviewer heard more room echo when he moved farther away.
- If the dial doesn't respond, try again before assuming a fault. The reviewer saw presses occasionally fail, but there is no evidence of a widespread defect.
Bottom line
The Yeti 2 looks like a substantial upgrade on paper: 24-bit capture, a three-capsule array and a proximity sensor that automates gain, EQ and pickup pattern. TechRadar's hands-on testing supports better clarity than the original, with caveats about the dial and echo. TechRadar scored it 5/5 for features, performance and design and 4/5 for value because of the price increase. Those are one reviewer's scores. Wait for more independent testing and recordings if you want firmer evidence on the noise-cancelling and tracking claims.
- Logitech Yeti 2: A worthy successor to a legendary mic TechRadar · 2026-10-27T12:10:50+00:00
- A legendary streaming microphone is back after 17 years — the Yeti 2 has new AI-powered features and a built-in screen | TechRadar techradar.com
- ロジクールG、プロレベルの高音質を発揮するYetiシリーズより、 高解像度ディスプレイを搭載した 「YETI 2 アダプティブマルチパターン USB マイク」を新発売 press.logicool.co.jp
