Illustration of a browser with selected webpage text, a context menu, and an AI assistant sidebar.
Microsoft has dropped plans to add Copilot-powered summarize, translate and cite actions to the Microsoft Edge menus you get after selecting text on a webpage. The feature had been on the roadmap for well over a year, and its target date moved several times before Microsoft ended it with a short note.
This doesn't take Copilot out of Edge. Summarizing a page is still a documented feature. What's gone is a planned one-click shortcut, and the roadmap history shows a feature that kept getting pushed back before it was cancelled.
Illustration of a browser with selected webpage text, a context menu, and an AI assistant sidebar. What Microsoft cancelled​
The roadmap item is RM497135. Neowin reported that Microsoft will no longer be adding Copilot-powered summarization, citation, and translation abilities to contextual menus in Edge. The idea was that users can simply highlight text in the browser, and then right-click to perform these functionalities through the power of Copilot.
Microsoft's own wording for the item said that menus in Edge where the user has highlighted content in the browser will soon support a summarization, translation, and citation with Microsoft Copilot and Microsoft 365 Copilot Chat. That covers both consumer Copilot and the work-focused Microsoft 365 Copilot Chat, so the cancellation affects home users and business users.
The roadmap record lists:
  • Products: Microsoft Edge and Microsoft Copilot (Microsoft 365)
  • Platform: Web
  • Cloud instance: Worldwide (Standard Multi-Tenant)
  • Status: changed from "In development" to "Cancelled"
The cancellation note reads: "We have made the decision to cancel this planned release. We apologize for any inconvenience this may cause." Microsoft gave no reason.
Summary: The planned menu shortcuts for summarize, translate and cite are cancelled for both Copilot and Microsoft 365 Copilot Chat in Edge. Microsoft hasn't said why.
A long run of delays​
Neowin wrote that the feature was added to the public roadmap way back in June 2025, and has been updated a couple of times since then. A copy of the original listing on the M365 Admin tracking site backs up the June date. It shows the entry was Created 2025-06-23 with a first target of August CY2025.
Third-party roadmap trackers then logged one delay after another:
When the change was loggedTarget date moved
Mid-August 2025 (CloudScout, week 33)Old Value: August CY2025; New Value: September CY2025
September 2025 (CloudScout, week 38)Old Value: September CY2025; New Value: October CY2025
October 2025 (CloudScout, week 43)Old Value: October CY2025; New Value: November CY2025
February 19, 2026 (Microsoft timestamp, per MicrosoftRadar)Still "In development," target February 2026
November 26, 2026, 00:16 UTCStatus changed to "Cancelled"
In February 2026, the SharePoint Stuff weekly roadmap roundup still had the item IN DEVELOPMENT. The February 2026 general availability date was only a target, and nothing suggests the feature ever shipped. The roadmap-history site MicrosoftRadar shows Microsoft's last change on November 26, 2026, which switched the status to Cancelled and added the apology text.
That makes four target dates in about eight months, then a long wait, then cancellation. We can't say what happened inside Microsoft, but repeated delays usually mean something wasn't working, whether that was engineering, product fit or priorities. That reading is our interpretation of the pattern. Microsoft hasn't confirmed it.
Summary: The feature was added in June 2025 for August 2025. It slipped to September, October, November and then February 2026, and was cancelled in late November 2026.
Copilot still does most of this through other routes​
Neowin also found that these functionalities still seem to be available in Edge via different Copilot entry points. In its test, Neowin selected text on a page, right-clicked, and chose Send to Copilot. That opened the Copilot chat on the right with the selected text already filled in. From there it could ask Copilot to summarize, translate, or generate citations for it, all of which it did fairly easily and correctly.
That was one publication's test. Your Edge build, account type or region may give different results. Microsoft's support documentation does confirm the broader page workflow. It describes Copilot in Edge as an assistant that can summarize web pages, videos and PDFs, and it gives these steps:
  1. Sign in to Edge with your personal Microsoft account.
  2. Open the webpage, video or PDF you want to ask about.
  3. Select the Copilot icon in the upper-right corner of Edge.
  4. Type a request such as "summarize this," "translate this into Spanish" or "give me a citation for this article," or pick a suggested prompt.
  5. For a quick summary, choose Create a Summary or Expand on this topic in the Copilot pane.
The first time you open Copilot in Edge, Microsoft says it will either tell you or ask your permission, depending on your region, before it uses information from the browser.
Microsoft's documentation specifically covers summaries. It doesn't name a supported method for translating or citing selected text through Copilot. If you need translations you can count on, Edge's built-in page translation is still there. Treat any citation Copilot produces like any other AI output and check it against the source page before it goes into a paper or report.
Summary: Page summaries in Copilot are documented and supported. Translation and citation through the Copilot pane worked in Neowin's test, but Microsoft doesn't document them as menu features.
Privacy: chatting with Copilot isn't the same as a one-click action​
The workaround works differently from what a single menu click might have done. Microsoft's documentation says that, depending on your prompt, Copilot in Edge may use the current page, the page title, your open tabs and your browsing history to answer.
If you don't want that, go to More (…) > Copilot and AI in the Edge toolbar and turn off Allow Copilot to read context clues on the web. Microsoft also suggests closing tabs and clearing browsing history to remove information from that context.
We don't know whether the cancelled menu actions would have handled browsing context any differently. The roadmap entry didn't say. In business environments, admins usually find menu-level AI actions harder to explain to users than a side pane they have to open on purpose. That's a general observation, not anything Microsoft said about this decision.
Summary: The Copilot pane can use your tabs and history. Check the "context clues" setting if that matters to you.
Why cancel it? Open questions​
Neowin suggested Microsoft may not have wanted to bloat the Edge context menu as it had done with Windows 11 in the past. That's a reasonable guess. Windows 11's crowded right-click menu has been a long-running complaint. It's still speculation, because Microsoft hasn't explained the decision.
Another possibility: a separate roadmap entry had planned something overlapping for business users. In August 2025, Planet Technologies' roadmap digest listed an item stating that Microsoft Edge for Business plans to introduce a Microsoft 365 Copilot Chat summarization menu item to our context menu. If a simpler summarize entry, or the existing Send to Copilot option, already covers most of what people need, a three-action menu might have looked redundant. We didn't verify that separate item's current status, so take this as a possible explanation, not a confirmed one.
Still unanswered:
  • Will Microsoft bring any part of the feature back in a different form?
  • Does the cancellation apply differently to consumer Edge and Edge for Business?
  • Will translation and citation be formally documented as Copilot-in-Edge features?
What this means for Windows users and IT admins​
  • Home users: You lose nothing that ever shipped. You don't get a quicker shortcut. Use the Copilot pane or Send to Copilot instead.
  • IT admins: If change-management plans or user training mentioned RM497135, remove it. If you rely on roadmap dates, this is another reason to treat "In development" as a statement of intent. Microsoft Learn describes the Copilot Roadmap, formerly the Microsoft 365 Roadmap and AI at Work Roadmap, as a planning resource. You can follow individual items through RSS, so a cancellation like this one doesn't surprise you.
  • Privacy-minded users: Check the context-clues setting before you start using the Copilot pane in place of the cancelled menu shortcuts.
This follows Microsoft's other recent cleanup of Copilot entry points, such as dropping the COPILOT function in Excel. Microsoft is still adding Copilot to its apps, but it is also cutting back some of the places you can launch it from.
  1. Microsoft cancels several Copilot features for Edge Neowin 2026-11-27T12:12:04+00:00
  2. Roadmap 497135: Microsoft Edge: Summarization, Translation, and Citation will soon be supported by Microsoft… – MicrosoftRadar microsoftradar.com
  3. Microsoft Edge: Summarization, Translation, and Citation will soon be supported by Microsoft Copilot and Microsoft 365 Copilot Chat in our menus - M365 Admin m365admin.handsontek.net
