The roadmap lists the change as In development, headed for General Availability, with an estimated date of December 2026. Microsoft says roadmap dates are estimates and can change. Nothing has shipped yet, and Edge administrators should not change their policies based on this entry alone.
What the roadmap says
Here is what entry 573291 covers:
- New name, new defaults. Energy Saver, formerly called efficiency mode, is getting new defaults and different setting options.
- One mode. The separate savings levels go away and Energy Saver works as a single mode.
- Two triggers. It turns on either on low battery or when unplugged.
- Default: low battery. Unless someone changes it, Energy Saver waits until the battery is low.
- Automatic migration of existing settings:
- Users on Balanced savings will get Energy Saver on low battery.
- Users on Maximum savings will get Energy Saver when unplugged.
- New policy name. Edge will support, and Microsoft will recommend, a policy called
BatterySaverModeAvailabilityfor managing the feature.
The entry lists the cloud instance as Worldwide (Standard Multi-Tenant) and the platform as "Web." It gives no Edge version number, no low-battery percentage and no rollout start date. It also makes no claim about battery-life gains.
How it works today
Edge's current setup has more options. In Settings today, users turn on Enable energy saver under Power. On a device with a battery, they can choose Balanced (the default) or Maximum savings, and separately decide whether to turn On or Off (default) Use energy saver even when connected to power.
The difference between the two levels matters. Microsoft's EfficiencyMode policy documentation says that with BalancedSavings, Edge takes moderate battery-saving steps when the device is unplugged, then extra steps once the battery is low. MaximumSavings uses the extra steps whenever the device is unplugged.
Microsoft's support documentation describes what those steps involve. Energy Saver minimizes power usage by reducing resource usage through modifying background tab activity and some foreground activity, as well as putting inactive background tabs to sleep after 30 minutes or less of inactivity. It also says it puts background tabs to sleep after 30 minutes of inactivity when your device is taking moderate steps to save your battery (if Automatically put tabs to sleep is on) and five minutes of inactivity when additional steps are taken to maximize savings.
Windows also has a say. Microsoft notes that on Windows devices, it follows Windows Battery Saver mode. Digital Citizen has reported that the Maximum savings stage kicks in when you enable Battery saver in Windows 10 (usually when your battery reaches 20%), or when Energy saver is activated in Windows 11 (when the battery reaches 30%). Those numbers describe current behavior as reported by a third party. They do not tell us what "low battery" will mean under the new design.
In short: today, Energy Saver has two intensity levels and can switch between them as the battery drains. The roadmap describes a simpler choice about when it turns on.
What changes for each group of users
The migration rules have practical effects, and they are easy to miss.
Balanced savings users (the default group). Today, Balanced already starts moderate savings as soon as you unplug. After the change, these users will get Energy Saver only on low battery. That likely means fewer background-tab limits during normal unplugged use, and fewer complaints about choppy video or sleeping tabs. The trade-off is that the browser may save less power in the early part of a battery cycle. Microsoft hasn't published figures either way, so this is our reading of the mapping, not a measurement.
Maximum savings users. These users will get Energy Saver whenever they are unplugged, which is close to what they have now. What's not clear is how aggressive the new single mode will be. The roadmap doesn't say whether it matches today's "extra steps" level, the "moderate" level or something new.
Plugged-in desktops. The roadmap names only two triggers, low battery and unplugged. It doesn't say what happens to the current "use energy saver even when connected to power" option. Last year, Windows Report spotted a related test in Edge Dev that offered System default — Edge's Efficiency mode follows Windows 11's Energy Saver (or Battery Saver on older builds) state. and Always enable efficiency mode — Edge keeps Efficiency mode active at all times, regardless of the PC's power state. It's not known whether any of that survives the simplification. Anyone who uses Energy Saver on a plugged-in machine should look again once the change arrives.
The policy-name mismatch admins should watch
This matters most to IT teams. The roadmap names BatterySaverModeAvailability as the recommended policy. Microsoft's published Edge policy documentation doesn't list a policy by that name. It documents EfficiencyMode, described as the setting to Configure when energy saver (previously named efficiency mode) should become active, which lives under Administrative Templates/Microsoft Edge/Performance in MSEdge.admx.
EfficiencyMode currently accepts six values:
| Value | Option | Documented behavior |
| 0 | AlwaysActive | Always on |
| 1 | NeverActive | Never on |
| 2 | ActiveWhenUnplugged | On when unplugged |
| 3 | ActiveWhenUnpluggedBatteryLow | On when unplugged and battery low |
| 4 | BalancedSavings | Moderate steps unplugged, extra steps at low battery |
| 5 | MaximumSavings | Extra steps whenever unplugged |
Microsoft's documentation lists support for options 0 through 3 on Windows: 96-109. Options 4 and 5 are listed as supported from version 106 onward. Since the Balanced and Maximum options are the ones the roadmap is replacing, existing policy values may need to change. The separate EfficiencyModeEnabled policy is still the on/off switch. Microsoft documents that EfficiencyMode has no effect when that policy is disabled.
BatterySaverModeAvailability is a Chromium-family policy name. Samsung's developer documentation lists it as supported in Chrome on Windows since version 108. In that version of the policy, the "on battery" value is deprecated as of M121 and handled as "enabled below threshold," meaning low battery only. That sits awkwardly next to Microsoft's roadmap, which still promises an "unplugged" trigger. Microsoft may add its own value, map the setting differently or correct the roadmap text. The available evidence doesn't say which.
Practical guidance for admins:
- Don't deploy
BatterySaverModeAvailabilityto Edge yet. Wait until Microsoft's Edge policy reference documents it with values and supported versions. Don't copy Chrome's values or registry paths. - Check your current
EfficiencyModeassignments now. Note which devices use BalancedSavings (4) or MaximumSavings (5), because those are the options being remapped. - Read the Edge release notes and the updated MSEdge.admx when new Edge versions arrive around the December target. Look for deprecation notes on the old policy.
- Test on pilot laptops first. Confirm when Energy Saver actually turns on, low battery or unplugged, before rolling out widely.
- Keep site exclusions in place. The current documentation still uses
SleepingTabsBlockedForUrlsto keep specific sites out of Energy Saver.
Our take
Cutting down a confusing set of options is a reasonable goal. "Balanced" versus "Maximum" never made it clear that one option quietly ran two stages. Choosing between "when low" and "when unplugged" is easier to understand, and it brings Edge closer to how other Chromium browsers handle the same setting.
Still, simpler isn't automatically better. The default group, Balanced, appears to be losing its moderate savings on unplug, and Microsoft hasn't published data on the battery-life cost. The policy name in the roadmap also doesn't match Microsoft's own Edge documentation yet. Until that's resolved, admins should read entry 573291 as a preview of the plan, not as configuration instructions.
Bottom line: if you manage Edge, plan for the change and watch the policy documentation. If you're a home user on a laptop, expect Energy Saver to turn on later in the battery cycle unless you choose the "when unplugged" option.
- Microsoft Edge: Simplified Energy Saver Microsoft 365 Roadmap · 2026-10-21T23:02:10.327394Z
- BatterySaverModeAvailability | Samsung Developer developer.samsung.com
- Microsoft Edge Browser Policy Documentation EfficiencyMode | Microsoft Learn learn.microsoft.com
