A black gaming mouse with glowing green accents sits on a desk beside a backlit keyboard and monitor.
Razer's Basilisk V4 Pro is the long-awaited update to its do-it-all ergonomic gaming mouse. It keeps the familiar shape, adds two buttons, and puts an AI shortcut on the side by default. Tom's Hardware reviewed it and called it a great all-around gaming mouse for gamers who want more functionality than a stripped-down FPS mouse, but who aren't totally button-crazy. Its main complaint is where the new buttons landed.
This piece separates three things: Razer's claims, the Tom's Hardware reviewer's hands-on impressions, and what other reviewers found. Ergonomics are personal, so one reviewer's thumb-reach complaint won't apply to everyone.
A black gaming mouse with glowing green accents sits on a desk beside a backlit keyboard and monitor. What Razer launched​
Razer announced the Basilisk V4 line on October 8, 2026, together with the Mouse Dock V2 Pro wireless charging dock. The V4 Pro is the flagship. There is also a cheaper V4 HyperSpeed. Razer lists the HyperSpeed at 94 g, with the Focus X 33K sensor, 12 customizable controls and up to 140 hours of battery life.
The V4 Pro's headline features, per Razer's announcement:
  • Sensor: Focus Pro 50K Optical Sensor Gen-3, rated for up to 50,000 DPI, 930 IPS and 90 G acceleration.
  • Switches: Gen-4 optical switches rated for 100 million clicks.
  • Wireless: HyperSpeed Wireless Gen-2 with 8,000 Hz polling.
  • Connectivity: Razer calls it five-way, covering the 2.4 GHz link, Bluetooth 6.2 with up to three paired devices, and wired mode.
  • Lighting: Seven Chroma RGB zones with underglow.
  • Scroll wheel: A HyperScroll Tilt Wheel Gen-2.
These are manufacturer specifications, not independent test results.
Price and availability​
Tom's Hardware lists $169.99 for both the black and white versions. The Mouse Dock V2 Pro is sold separately at $69.99. Windows Central says the mouse became available starting October 8.
Razer's own store page for the black bundle shows a different picture on the day of this packet. It listed a bundle price of US$209.99 (marked 12% off), with a pre-order label and a ship-from date of October 30. Store pages change, so check current pricing and availability before buying.
Design: same shape, two new buttons, less weight​
Tom's Hardware says the V4 Pro keeps the right-handed, contoured shape of its predecessor. It measures 5.02 x 2.98 x 1.68 inches (127.5 x 75.8 x 42.5 mm).
The black model weighs 100 g, against 112 g for the Basilisk V3 Pro 35K. The reviewer found the difference noticeable when lifting the mouse, but stressed it is not an ultralight design. Razer's own figure is "12 g lighter."
The button count​
The mouse has 12 programmable buttons by Tom's Hardware's count. Razer counts 14 customizable controls, and Tom's Hardware reaches 14 when scroll up and down are included. The two numbers don't contradict each other. They count different things.
The two new buttons are:
  • A third thumb button. It opens Razer's AI prompt by default.
  • An extra button on the left edge of the left mouse button. It cycles profiles by default.
Where the reviewers disagree​
Tom's Hardware's reviewer, who has medium-sized hands and long fingers, did not like the layout. The profile button sat too far forward to press comfortably. The third thumb button pushed the often-used first side button (MB4) too far back. The reviewer's summary was that there are now three side buttons where two would do, and all of them feel slightly off.
Windows Central's reviewer, who describes having smaller hands, reached the opposite conclusion about the button layout. That review praises the slightly shorter body. It also calls the left-edge profile button a much more sensible location than the underside spot on the V3 Pro 35K. And it says the repositioned Hypershift thumb button is easier to click.
Remapping can change what a button does, but it can't change where the button sits. If you're considering the V4 Pro, hand size and thumb reach matter more than the spec sheet.
Scroll wheel​
The tilt wheel has two tactile modes (24 and 48 steps) plus free-spin. Tom's Hardware liked the precision tactile mode and found free-spin too sensitive, with backscroll from slight finger movement. Windows Central also singled out Precision Tactile for text-heavy scrolling. Razer also describes a Smart-Reel mode that switches between tactile and free-spin automatically. It adds a Virtual Acceleration option in Synapse.
Sensor and switches in use​
The Tom's Hardware reviewer reports good tracking on a range of surfaces, including glass at least 4 mm thick. The clicks were crisp and not especially loud, with no misclicks or double-clicks during testing. That is a short-term impression, not a durability result.
The reviewer says the shape isn't quite as natural as the DeathAdder V4 Pro, but it's comfortable across MMOs and shooters, though perhaps not for peak competition. The thumb trigger can be hit by accident if you lift the mouse often.
Windows Central highlights Frame Sync, which aligns sensor scanning with the polling cycle. Per that review, this reduces motion latency and helps battery life.
Battery, connectivity and charging​
Battery figures depend on the polling rate:
  • 200 hours on 2.4 GHz at 1,000 Hz.
  • 54 hours at 8,000 Hz, per Tom's Hardware.
  • Up to 275 hours on Bluetooth, a Razer claim repeated by Windows Central.
Tom's Hardware's bottom line cites a rise from 150 hours on the V3 Pro 35K to 200 hours. Windows Central's reviewer said they hadn't had the mouse long enough to push the battery to its limit.
In the box you get a USB-A dongle, a USB-A to USB-C adapter and a 6-foot braided USB-C to USB-A cable. The cable is for charging and connecting the dongle. It is not one of Razer's flexible HyperFlex cables, so it isn't meant for wired play.
Charging accessories​
The Mouse Dock V2 Pro is a small magnetic dock with an integrated 8,000 Hz receiver and eight RGB zones. It works with the Basilisk V4 Pro and V4 HyperSpeed. Razer's compatibility list also includes:
  • Basilisk V3 Pro 35K and V3 Pro
  • Cobra Pro and Cobra HyperSpeed
  • Naga V3 Pro and V2 Pro
  • Several Razer keyboards
The mouse also works with the HyperFlux V2 charging mouse pad. For 8,000 Hz polling on the pad, Tom's Hardware says you need to connect through the mouse's dongle. Windows Central lists wireless charging that works only with Razer accessories as a drawback.
Software, and the AI button​
Programming the mouse requires Synapse 4. Tom's Hardware says it is not the web-based Synapse. Synapse covers remapping, macros, DPI stages, surface calibration, dynamic sensitivity and rotation. Chroma Studio handles lighting.
The AI button is the review's headline. Both reviews say the third thumb button opens Razer's AI prompt by default, and both say you can remap it.
Windows Central tested the feature and identified it as "AI Prompt Master." It describes a Razer-built chat window that uses ChatGPT. It offers preset tasks such as composing emails, summarizing, rewriting and creating images, plus custom templates. The reviewer says it needs Synapse installed, doesn't let you change the AI engine for now, and stays above other open windows. Those are Windows Central's findings, not something Tom's Hardware tested.
For PC users, the practical advice is simple. If you don't want the shortcut, reassign it in Synapse. The more lasting complaint is the physical position of that third button.
Should you buy it?​
Several outlets are broadly positive. Windows Central's reviewer called it probably the best gaming mouse they'd used. The Yahoo Tech review praised its connectivity. Reviewers at Gaming Trend and Basic-Tutorials rated it highly, and the latter said an upgrade from the V3 Pro 35K is likely worth it mainly for the lower weight, the native 8,000 Hz polling and the extra scroll mode.
Windows Central takes the opposite view for current V3 Pro 35K owners. It says the V4 Pro is a harder sell for them and that it's easier to recommend to people on older or non-Razer mice. Wolfs Gaming Blog likewise called it a tough sell for V3 owners.
  • A good fit if: you want an ergonomic all-rounder with a lot of controls, long battery life, flexible connectivity and the lighter weight, and you're coming from an older mouse.
  • Think twice if: you have a V3 Pro 35K you like, you're sensitive to thumb-button placement, you want an ultralight mouse, or you'd rather not pay a premium price for the dock.
Try the mouse in your hand if you can. The thumb-button layout is the biggest open question in this review.
  1. Razer Basilisk V4 Pro Review: Tried and true and now with AI Tom's Hardware 2026-10-23T16:00:00+00:00
  2. Buy Razer Basilisk V4 Pro - Black + Mouse Dock V2 Pro Bundle | Gaming Mice | Razer.com razer.com
  3. The Apex Returns: Razer Unveils the Basilisk V4 Line - Razer Newsroom razer.com
