A monitor displays an AI-powered document workflow with automated checks, human approval, and secure database storage.
An AI agent can read an invoice it has never seen before. That doesn’t mean it should be allowed to post it. The distinction is at the heart of TechHQ’s comparison of robotic process automation (RPA) and AI agents: choose the tool for each step, not for the workflow as a whole. For a Power Automate team, that might mean using AI to interpret a supplier’s PDF, fixed rules to check the result, and a desktop bot only where the accounting system lacks a suitable connector or API.
The adoption forecasts make that distinction worth getting right. In June 2025, Gartner predicted that 33% of enterprise software applications would include agentic AI by 2028, up from less than 1% in 2024. It also predicted that more than 40% of agentic AI projects would be canceled by the end of 2027, citing rising costs, unclear business value, and inadequate risk controls. Those forecasts measure different things: more software can ship with agents even as companies abandon individual deployments. Neither forecast tells you whether an agent belongs in your invoice queue.
A monitor displays an AI-powered document workflow with automated checks, human approval, and secure database storage. Score the step, not the department​
Start with three questions: How predictable is the input? Can the decision be written as a rule? What happens if the system gets it wrong? The answers can change several times in a single workflow.
  • Use fixed rules when the answer is knowable in advance. Matching structured records, uploading a payroll file, and generating a scheduled report don’t require a model to decide what to do. If a supported connector or API can perform the operation, evaluate it before building a bot that clicks through screens. Desktop RPA is particularly useful when the application exposes the necessary operation only through its interface.
  • Test AI where interpretation is the hard part. Free-text service requests, scanned forms, and invoices with unfamiliar layouts are candidates for classification, extraction, or summarization. If the only job is to turn a document into fields or draft a reply, don’t assume you need an agent that can choose and execute actions. Give it that authority only if the workflow actually needs it.
  • Separate interpretation from permission. A customer-service agent can identify a refund request and assemble the case history without being able to move money. A fixed policy can govern routine refunds, while disputed or out-of-policy cases go to a person. Gartner separately forecast in March 2025 that agentic AI would resolve 80% of common customer-service issues without human intervention by 2029, with a 30% reduction in operating costs. That’s a forecast, not a reason to give every service agent the same permissions.
Put the controls at the handoff​
Consider an invoice arriving as a PDF in an unfamiliar layout. Let the AI propose structured fields: supplier, invoice number, purchase-order reference, currency, and total. Then check those fields against the purchasing system. Missing values, duplicate invoice numbers, mismatched totals, and supplier bank-detail changes should have explicit exception paths. A confidence score can help prioritize review, but a model that confidently extracts the wrong amount has not passed validation.
Only after validation and any required approval should a connector or bot post the record to the enterprise resource planning system. Design the retry path before going live: if a bot loses its connection after clicking Save, it should check whether the invoice already exists rather than post it again. Keep a record of the original document, the extracted values, the checks and approvals, and the resulting transaction ID. That gives an operator enough information to investigate a disputed posting without asking the model to explain itself after the fact.
This split is already reflected in commercial tooling. UiPath put Maestro into public preview on March 27, 2025, and made it generally available on April 30, 2025. UiPath describes it as an orchestration layer for agents, software robots, and people. That establishes what the product is designed to coordinate, not whether adding an agent will improve a particular workflow.
The Windows constraint a demo can miss​
Microsoft lists Power Automate Process at $150 per bot per month, paid yearly, in the U.S. That’s a list price, not the total cost of running a workflow. Microsoft says applications used by an unattended bot can require additional licensing, and its capacity documentation says each unattended bot can run one desktop flow at a time. Budget separately for the machine, any AI consumption, and the people who will handle exceptions and maintain the automation.
There’s also a practical trap for Windows admins: Microsoft says unattended desktop flows on Windows 10 and Windows 11 can’t start while an active Windows user session is present, even if it’s locked. Locking the office PC is not the same as signing out. Power Automate creates a Remote Desktop session for the run, and Microsoft warns that a different screen resolution can affect which controls a flow finds. If a bot works under supervision but fails overnight, check the session state and test under the unattended account at the intended runtime resolution before rewriting the business logic.
For a pilot, run the AI on representative cases without letting it write to the production system. Compare its output with human-verified results, track how often cases need review, and count correction time alongside licensing and run costs. Give the write step to the simplest mechanism that can enforce the policy and leave an audit trail. If AI earns its place only at intake, that’s a successful design—not an unfinished one.
Correction (November 27, 2026): An earlier version of this article said UiPath put Maestro into public preview on March 28, 2025. UiPath's March 2025 release notes date the public preview to March 27, 2025. The article has been updated.
  1. RPA vs AI agents: Which processes belong to which? - TechHQ TechHQ 2026-11-27T16:36:17+00:00
  2. Gartner Predicts Over 40% of Agentic AI Projects Will Be Canceled by End of 2027 gartner.com
  3. Run unattended desktop flows - Power Automate | Microsoft Learn learn.microsoft.com
