What StarTech is selling
StarTech describes it as the company's first dock with smart management and its own management software, giving IT teams a live dashboard view of every unit they've deployed. The companion software surfaces firmware status, lets admins enable and disable connectivity ports, and gives fleet-wide visibility remotely. The target is organizations running hardware across multiple floors, buildings or locations.
The listing also says the installer comes in INF, EXE and MSI formats, which supports both manual setup and automated rollouts. That matters to Windows admins who push software through standard deployment tooling.
Carrasqueira's review adds hands-on detail:
- Management app: Smart Dock Manager runs only on Windows. It manages docks over the network, so the computer plugged into the dock can run any OS.
- Ethernet is required: A dock must be connected to the network via Ethernet. You can't manage it over the USB-C host link alone.
- Controls: The review describes firmware updates, dock power on/off and per-port disabling. In an enterprise setting you can take batch actions, such as disabling all USB ports, display outputs or network connectivity on every dock at once.
- Scope: The review describes this as management over the local network. Nothing in the material I reviewed says cloud-based management is involved.
Price and availability
The review says the dock launched on October 12, 2026, at $249.99. StarTech's own listing data shows the same $249.99 price and an in-stock status. StarTech says it is available at StarTech.com and through partners including CDW, Amazon, Ingram Micro, TD SYNNEX and D&H.
The review put Amazon at roughly $220 at the time of writing. Treat that as a snapshot, not a current offer. Third-party resellers vary widely. One Canadian reseller listing showed a sale price of $345.99, though that is presumably in a different currency or market.
Ports and the 10Gbps ceiling
The review lists these ports:
- Front: one USB-A (10Gbps), two USB-C (10Gbps) and a 3.5mm combo audio jack.
- Rear: two USB-A (10Gbps), two USB-A (5Gbps), two HDMI, two DisplayPort, one 1Gbps Ethernet port and the USB-C host connection (10Gbps).
- Power: 96W Power Delivery, with a 135W power supply included.
- Video: up to two displays at 4K/60Hz.
The four video sockets don't mean four monitors. They work as two groups, each with one HDMI and one DisplayPort, and only one port per group can be used.
The bigger issue is bandwidth. Everything shares a 10Gbps host link. The review notes that most individual USB ports could saturate that link on their own. Adding display traffic and Ethernet makes contention likely. DisplayLink sends video over USB data bandwidth, so the displays draw from the same pool as the rest of the dock.
In practice, a typical office desk with a keyboard, mouse, webcam and two monitors will be fine. A user hanging fast external SSDs off several ports and expecting each to run at full speed will not be.
The reviewer also criticized the layout. The two USB-C ports sit close together, which blocked his wireless microphone receiver. There is no SD or microSD reader. He found the housing light and cheap-feeling. Those are subjective observations. One retailer listing says the housing uses 75% post-consumer recycled plastic, which may explain the plastic feel but is not a quality judgment.
DisplayLink: the real trade-off
The dock uses DisplayLink rather than relying only on native USB-C DisplayPort Alt Mode. That has pros and cons.
Pros:
- It works on basically any USB-C port.
- It bypasses display limits on low-end Macs. The review notes that a base Apple Silicon Mac supports only two displays total, so a MacBook Air would get just one via Alt Mode.
- It works on hosts without Alt Mode support, which is increasingly rare.
Cons:
- It needs a driver or app on the host. In the review, the displays did not work at all out of the box, and only worked after installing the DisplayLink software.
- The display output starts only after sign-in on macOS. Windows doesn't have that problem in the review, though there is a delay before output starts.
The Mac login-screen problem
On the Mac Mini, the reviewer couldn't see the login screen on external monitors. DisplayLink's own support documentation says this is expected when FileVault is enabled. DisplayLink's own macOS documentation lists this as a known limitation: screens won't show the login screen at startup with FileVault on, even with the Login Screen Extension installed.
DisplayLink describes it as a limitation of the macOS boot and security architecture, not of any single dock. The software isn't running until the encrypted startup volume is unlocked. So this is not specific to StarTech. It does matter if you plan to use a Mac desktop with only external monitors.
For macOS setup, DisplayLink's instructions include these steps:
- Install DisplayLink Manager.
- Open it and, optionally, tick "Launch automatically after logging-in".
- Grant Screen Recording permission in System Settings.
- Quit and reopen the app if macOS prompts you to.
DisplayLink says the permission prompt is generated by the OS, and the app doesn't store or record screen content. That prompt often alarms users and security teams, so tell your helpdesk in advance.
To check whether FileVault is on, DisplayLink says to open System Settings, go to Privacy & Security, then select FileVault.
Who should consider it
The review's buy/avoid summary is fairly clear.
It may fit if you:
- need remote management of many docks;
- need dual displays across mixed Macs and PCs, or on hosts without DisplayPort Alt Mode.
It may not fit if you:
- plan to push several ports hard at once;
- want a premium-feeling dock;
- need more than two USB-C ports.
For fleet buyers, the Windows-only manager and the Ethernet requirement are the main planning points. You'll need a Windows machine for administration and a wired network drop at each dock. Hot-desk environments often have both, but home offices and Wi-Fi-only desks won't.
The bottom line
This is a conditional recommendation. The management features are the draw, and the reviewer called them a genuine selling point that works well, though not unique. The weaknesses are the shared 10Gbps link, DisplayLink's software dependence, the Mac login limitation, the physical design and the $250 list price. If you don't need to monitor and update docks centrally, a simpler dock probably gives you better value. If you do, pilot a few units before buying in bulk.
One caution on the evidence: the hardware observations, such as build feel, port spacing and the macOS behavior, come from one reviewer's unit. I didn't test the dock myself. The product listings back up StarTech's management claims and the headline specs, but not the reviewer's performance impressions.
- StarTech's first smart dock has remote management and plenty of ports, but I can't recommend it XDA · 2026-11-10T17:00:21+00:00
- Buy StarTech.com SmartDock 14 Port(s) USB Type C Docking Station for Monitor, Notebook - Charging Capability - Desktop store.four-squares.co.uk
- StarTech Releases Dual-Monitor USB-C Dock, Its First With Smart Management and Dedicated Software techpowerup.com
