Two wireless computer mice, one black and one white, sit beside a charging dock on a dark desk.
SteelSeries has a new pair of flagship wireless mice, and they're built around two ideas. One is a radio technology that skips the crowded 2.4GHz band. The other is a battery you swap instead of waiting for it to charge. AOL UK's Nathan Bliss reviewed the Rival Pro and Sensei Pro and gave both 5/5. The details below show what the mice offer, which claims are the manufacturer's, and what to check before you spend about $180 on a mouse.
Two wireless computer mice, one black and one white, sit beside a charging dock on a dark desk. What was announced and when​
SteelSeries unveiled the series on September 29, 2026, as part of its 25th-anniversary push. Preorders opened on September 29th, and retail availability began on October 13th. The line has four models: Rival Pro, Sensei Pro, and a Mini version of each. Each comes in black or white.
All four models cost the same: $179.99, £169.99, or €199.99. These are launch list prices, not guaranteed street prices. SteelSeries also lists a separate wireless travel dongle at $24.99 / £24.99. The company says it is exclusive to its own website.
Rival Pro vs Sensei Pro: it's all about shape​
The internals are shared, so the choice comes down to shape.
  • Rival Pro: ergonomic and built for right-handed use.
  • Sensei Pro: symmetrical.
SteelSeries support suggests the Sensei Pro for aggressive-claw or fingertip grips and the Rival Pro for palm or relaxed-claw grips. It also says every model can be used with any grip. Treat that as a fit suggestion, not a rule.
One caveat for left-handers. SlashGear describes the Sensei Pro's symmetrical design as perfect for either left- or right-handed use. Gaming Trend's review, however, notes that the extra thumb buttons are on the left side. Symmetrical shell and symmetrical buttons are not the same thing, so left-handed buyers should check the button layout first.
Dimensions differ slightly. SlashGear measured the Rival Pro at 4.95 x 2.69 x 1.66 inches, whereas the Sensei Pro measures 4.94 x 2.62 x 1.52 inches. The Rival is taller and a bit wider.
The headline specs, and who is making each claim​
FeatureClaimed specNotes
SensorTrueMove 42K Pro, 42,000 DPI, 800 IPS, 70GSteelSeries support says it is a custom version of PixArt's PAW3955
Frame capture20,000 fpsIn Max Performance mode, per SteelSeries
Polling8,000Hz, with 9K over-pollingThe sensor runs at 9,000Hz and adds a spare packet after every eighth one
WirelessUltra-Wideband, 6.4–9.056GHzSteelSeries claims about 20x the bandwidth of 2.4GHz
WeightAbout 53g full-size, 49g MiniSee the note below
SwitchesOptical, rated for 100 million clicksSteelSeries quotes 0.35ms click latency
All of these are manufacturer specifications. 42,000 DPI is a ceiling, not a setting most people will use. Root-Nation put it bluntly: no human hand will find the ceiling. The figures also sit slightly below the newest Razer and Logitech flagships.
On weight, AOL and SteelSeries' press release say 53g and 49g. SteelSeries' own product pages have shown slightly different numbers in places, so expect roughly 53–54g and 49–50g. SlashGear's measured figure for both mice is approximately 1.86 ounces, which is about 53g.
Ultra-Wideband: the real pitch​
SteelSeries argues that 8K polling is only as good as the wireless link carrying it. Its press material says the 2.4GHz band is congested with headsets, keyboards, phones and other devices, and that UWB sidesteps that. Root-Nation notes SteelSeries claims these are the first gaming mice to talk to your PC purely over ultra-wideband.
The benefit is plausible, but nobody outside SteelSeries has demonstrated it in this coverage. Bliss said SteelSeries showed him cursor-trace comparisons against rivals. He was also candid that he has never knowingly noticed interference on other mice, and that he isn't an esports-level player. In a similar vein, an AOL UK review of the same mice (an earlier piece) said that as a very average Counter-Strike and Overwatch player the reviewer couldn't feel the difference between polling rates.
So "effectively immune to interference" is marketing language. If you play in a cramped, wireless-heavy setup, UWB may help. In a typical home office, you may never find out.
"Infinite battery" means swapping, not magic​
Each mouse uses two swappable battery pucks. One powers the mouse while the other charges in the base station. SteelSeries rates each battery at up to 16 hours at 8K polling or 60 hours at 1K. Using both in turn gives 32 and 120 hours.
"Infinite" therefore describes the swapping routine, not unlimited capacity. You'll never be stuck waiting on a charge, provided you swap before the second battery also drains.
Per SteelSeries support, the swap procedure is:
  1. Press down on the battery in the mouse and twist it counterclockwise until it lines up with the unlock icon.
  2. Line up the dot on your charged battery with the unlocked icon on the mouse.
  3. Press down and turn clockwise until it locks.
  4. Put the depleted battery in the base station by rotating it counterclockwise to the unlocked icon, inserting it, then turning it clockwise to the locked icon.
SteelSeries warns against forcing the battery. Make sure it's lined up before you twist.
Bliss found the twist-and-pop mechanism a good solution, and power returns instantly after a swap. He added that it works less well on a mouse than on a controller or headset. Tom's Guide notes that the Rival and Sensei batteries are different to the shared battery used by SteelSeries headsets and its Aeon Pro controller, because that battery is too heavy for a competition mouse. Don't assume your headset batteries will fit.
The AOL review also says there's no USB-C port, so you can't use the mouse wired. That is the reviewer's observation, not a manufacturer statement. It means the base station and battery routine are the only way to keep it running.
Software and platform notes​
  • GG and GG Web: SteelSeries offers its desktop GG suite and, for the first time, a browser-based app. Tom's Guide calls out web app support as a first for the company. The web app may not cover every desktop feature.
  • Features that need GG running: support lists Sensitivity Matcher, Angle Snapping, Rotation Settings, and Acceleration/Deceleration. Settings that need GG show a "GG Required" badge.
  • Max Performance mode: SteelSeries says this mode keeps the sensor in its 8K state, with full 20K frame capture and 800 IPS/70G. You'll find it under the Performance tab in the mouse settings.
  • Compatibility: SteelSeries lists Windows 10 and later for PC. It says PlayStation and Xbox Series S|X support may not include every feature.
  • Extras: the software includes aim training, a sensitivity finder and a settings converter. SteelSeries claims the Max Performance mode removes the sensor throttling that other mice show below 8K.
What reviewers agree on, and where they differ​
Praise is broad. Gaming Trend says the 8KHz implementation is flawless and that the mice hold up against the best others it has used. Tom's Guide calls out the UWB, the zero-downtime battery and the responsiveness. Complaints are small and fairly consistent:
  • Scroll wheel: Bliss calls it decent but not the best. Gaming Trend says it doesn't feel as precise. Root-Nation calls it mushy.
  • Fingerprints: Tom's Guide says the black model is a fingerprint magnet.
  • DPI button: Gaming Trend dislikes that SteelSeries has moved the DPI/power button to the bottom of the mouse.
  • Stripped-back design: Root-Nation notes there's no RGB, no thumb rest, no free-spinning scroll wheel, no extra button cluster.
Value: where $179.99 sits​
Bliss compares the price with rivals. By his figures, it matches the Logitech SuperStrike V2 Pro and Razer DeathAdder V4 Pro (the latter at $169). It undercuts the newer SuperStrike V3 Pro ($199), and the Razer Viper V4 Pro ($159) is cheaper. He says SteelSeries' mice are 53g, against 49g for the Viper V4 Pro, so the lightest option isn't SteelSeries. He gave value 4.5/5.
My read, from general industry knowledge, is that you're paying for the UWB-plus-swappable-battery combination, not for raw numbers. If you don't care about either, a cheaper flagship does the job.
Who should buy​
  • Buy it if: you hate charging cables, play competitively, and want a pared-back shape in the Sensei or Rival mould.
  • Think twice if: you're left-handed and want thumb buttons on your side, you want a wired fallback, or you want RGB and extra buttons.
  • Check first: the size, the grip recommendation, and whether you'll use GG-dependent features that need the desktop app running.
The reviewer's 5/5 is one person's judgment, backed by weeks of use. The UWB advantage is the part most worth testing in your own setup before you commit.
  1. SteelSeries Rival Pro and Sensei Pro review - Infinite battery, top-tier performance - AOL.co.uk AOL.co.uk 2026-10-21T10:31:54+00:00
  2. SteelSeries Sensei Pro X Rival Pro Review: 8K Wireless Mice With 'Infinite' Battery Life - SlashGear slashgear.com
  3. SteelSeries Unleashes Ultra-Wideband (UWB) for Un… | SteelSeries steelseries.com
