What the author did and what went wrong
Aguilar had an old PC and family photos scattered across dead phones, spare drives and cloud accounts. He turned the PC into a server at no hardware cost, and it worked. His regrets fall into three groups:
- Hardware limits. Desktop parts, he says, aren't made to run unattended for months. He also found that his motherboard had a limited number of ports for adding drives.
- Storage planning. He first threw every spare USB drive he owned into the setup. He now wishes he had bought matching drives for the important data. He also bought separate USB drives to hold the operating system. He forgot a password early on and had to reinstall the OS, which was painless only because it happened at the start.
- Running costs. An older add-in card can stop the machine from settling into a low-power idle. He also notes that heat and noise build up when drives are packed into a case built for desktop use. His cooling fan ran off USB power, and he now thinks that was a mistake.
His closing advice is that a purpose-built NAS is the better choice if you have a budget, but a spare PC is a fine, educational option if you plan around its quirks.
These are one person's experiences. His build isn't specified: no motherboard, OS, drive count or add-in card is named. His reported power-cost estimate comes from a third-party site, and it hasn't been checked independently here.
ECC memory: real benefit, easy to overstate
Aguilar says server memory can catch and fix small random errors, and desktop memory can't. That's roughly right as a generalisation, with caveats. Micron describes ECC memory as hardware that detects and corrects single-bit errors while flagging multi-bit errors. The citation is imprecise on my part, so here is the plain version. Micron's own FAQ says ECC doesn't prevent every memory or system problem. It corrects many common single-bit errors and flags the more complex ones.
Three practical points follow:
- ECC support depends on the whole platform: the memory modules, the processor and the motherboard. A "server" label doesn't guarantee it, and a desktop isn't automatically excluded.
- ECC covers one failure class, memory bit flips. It does nothing for accidental deletion, malware, a dying drive or a failed power supply.
- For a photo archive, independent backups matter more than ECC. His habit of keeping spare copies on flash drives is a start. The details matter, though: how many copies, where they're kept, how often they're refreshed, and whether you've ever tested a restore.
Drive ports and bays: check before you buy
The advice to check what the motherboard supports before buying drives is sound. The claim that expansion methods "slow everything down" is too broad to treat as fact. What you can add depends on the board's SATA ports, its expansion slots, how the chipset and CPU allocate lanes, controller compatibility and your workload. Photo storage is mostly capacity and reads, not sustained heavy throughput.
A better procedure:
- List every drive you intend to use, including the OS drive and any backup drive that will be attached to the machine.
- Open the exact motherboard manual and count the SATA ports and M.2 slots. Note whether any are shared, because some boards disable one port when another slot is populated.
- Check that the case has physical bays and airflow for that many drives.
- Decide now where the backup copy lives. Ideally that's a separate device, and separate from the building if possible.
Storage: matching drives, a separate OS drive, and what counts as backup
Matching drives do make capacity planning and replacement simpler, and mixed leftovers are messier. But a matched set isn't a backup strategy. If the server fails, is hit by malware or has files deleted by mistake, everything stored only on it is at risk.
Aguilar's separate OS drive is the better lesson. Keeping the operating system apart from the data means a reinstall, like his password-reset episode, doesn't have to touch your photos. Label the drives clearly so you never reinstall onto the wrong one. His particular choice of USB media for the OS is an anecdote, not a recommendation. Flash media varies a lot in durability and performance, and for a machine that stays on, a small SSD is the more conventional choice. That last point is general industry knowledge, not something his article says.
Power: measure it instead of guessing
Aguilar cites Appliance Run Cost for roughly $60 to $90 a year for a mostly idle desktop. Treat that as a ballpark, not a fact about your machine. Real figures depend on your hardware, hours of use and local electricity rate.
Federal guidance gives a sense of how wide the range is. The Department of Energy's acquisition guidance for ENERGY STAR desktops, using an 11-cent-per-kilowatt-hour federal price, lists annual use of 12 kWh for the best available model and 52 kWh for an ENERGY STAR-certified one. Its least efficient example uses 208 kWh. At that price, those work out to a few dollars up to about $23 a year, well below the author's range. The DOE figures reflect typical desktop use patterns and certified retail models, not an old PC with extra cards and several drives, so don't read them as a prediction either. They do show that "idle desktop" covers a very wide spread.
To get your own number:
- Plug the server into a wall-socket power meter.
- Let it settle into its normal idle state and note the average watts.
- Multiply watts by the hours it runs per year, then divide by 1,000 to get kWh.
- Multiply by your electricity price per kWh.
If the idle draw is higher than expected, Aguilar's finding about older add-in cards is worth testing. Pull the card, re-measure, and see whether the machine settles lower.
Shutting down at night: a trade-off, not a cure-all
Aguilar powers his server off at night and when he's away, and says that is better for the PC. The Department of Energy does recommend shutting computers off during long periods of non-use, and says doing so won't shorten their life. That supports the energy saving. It doesn't make a blanket case that shutdowns extend hardware life. The DOE also suggests timed shutdowns and automatic start-up before backup jobs. The main cost is availability: a powered-off server can't give remote access or run scheduled tasks. Match its hours to what you actually need.
Heat: check the drive's own spec
Aguilar warns that hot drives wear out faster. The temperature numbers are model-specific. Seagate's support page says the operating range for most of its hard drives is 5 to 50 degrees Celsius, and newer models have a maximum of 60 degrees Celsius. It adds that a normal PC case should provide adequate cooling. For an enclosure that can't hold that range, Seagate suggests contacting your system manufacturer about compatible cooling and ventilation hardware.
Seagate's page also notes that whether extra cooling is needed depends on your case environment, and with adequate cooling it's probably unnecessary. This is a vendor page about its own drives, so other makers' limits may differ. Check the datasheet for your exact model.
Aguilar's wall-powered fan advice is also narrower than it sounds. What matters is moving enough air to keep drives inside their rated range, not where the fan's power comes from. A case fan on a motherboard header or fan controller is normal and fine. His USB-powered fan was a poor choice in his setup, but the fix is adequate airflow, not a particular plug.
A practical routine:
- Install a monitoring tool that reads drive temperatures. CrystalDiskInfo is a common free choice on Windows.
- Check temperatures under a normal load, such as a big photo import or a backup run.
- Compare them with your drive's datasheet and add airflow if they sit near the limit.
DIY server or NAS?
Aguilar's verdict is that a NAS is easier, quieter, lighter on power and comes with support, but that the old PC taught him more. That's a reasonable personal conclusion, though his article gives no model, price or power comparison. Not every NAS is quiet or well supported, so compare actual models. The decision comes down to budget, required uptime, how fast your storage will grow, how much maintenance you'll tolerate and your recovery plan.
Pre-build checklist
- Count drives and ports from the motherboard manual before buying anything.
- Keep the OS on its own drive, separate from the photos.
- Buy matching drives for the data pool where you can.
- Decide where independent backup copies live, and test a restore.
- Measure wall power with a plug-in meter instead of trusting estimates.
- Check each drive's rated temperature range and monitor it under load.
- Match the server's running hours to what you need from it.
The old PC works as a photo server. The lessons are mostly about planning: know your limits, separate your data, and keep backups somewhere the server can't take down with it.
- I just built my own server and here are a few things I would do differently How-To Geek · 2026-11-16T16:30:16+00:00
- What is the normal operating temperature for Seagate disk drives? | Seagate US seagate.com
- Purchasing Energy-Efficient Computers | Department of Energy energy.gov
