USB-C is only a connector. What a given port or dock can do depends on the host, the dock, the cable and the charger.
First, a wording fix: USB-C is not Thunderbolt
The XDA piece says Thunderbolt docks are a step above standard USB-C docks, and that is broadly right. But the 40Gbps figure needs a qualifier.
- Intel says Thunderbolt 4 certification requires support for power, data, and video with constant 40 Gbps bandwidth.
- Intel also says USB cables, devices and ports may be limited to a variable range of data speeds, with no guarantee of display quality.
- The guarantee is specific to Thunderbolt 4. Newer generations go higher. Satechi's Thunderbolt 5 dock manual lists a host port of up to 120Gbps.
- Even 40Gbps is shared. Intel says Thunderbolt 4 allocates its bandwidth dynamically between data and video. A big file copy and a pair of 4K displays draw on the same pipe.
- A mismatched chain falls back. Intel notes that when devices with different capabilities connect, the link only supports the lowest common data rate.
Use 1: A handheld gaming PC at a desk
The idea is to plug a Steam Deck or ROG Ally into a dock and gain a big monitor, a keyboard and mouse, and wired Ethernet.
What the vendors say
- Valve says the Steam Deck's USB-C port can carry video, audio and input, and that any USB-C hub can expand its options.
- Valve's FAQ is blunt about performance. Docking is more akin to plugging a USB-C hub into a PC, and the Deck already runs at full performance in portable mode. The XDA line about reverting the handheld to its "PC origins" overstates it. The dock adds connections, not horsepower.
- ASUS lists the original ROG Ally's USB-C combo port as USB 3.2 Gen 2 with DisplayPort 1.4 support. That means the Ally can send video through a compatible dock. The same page lists Windows 11 Home, so Windows display settings apply.
Checks before you buy
- Confirm your handheld's USB-C port supports video output (DisplayPort Alt Mode). Not every USB-C port does.
- Check the dock's video outputs and the resolution and refresh rate it supports. A high-refresh monitor only helps if the whole chain can drive it.
- Check that the dock can pass enough power to the handheld while you play.
- Treat wired Ethernet as an improvement over weak Wi-Fi, not a cure for lag. It doesn't remove latency elsewhere in the network or the game.
Windows handhelds get one more benefit. You can use Windows' normal display options to duplicate or extend the screen, and any USB keyboard or mouse works as it would on a desktop.
Use 2: A tidy charging hub
XDA's second idea is to plug a high-wattage dock into one outlet and charge a laptop, phone, headphones and camera gear from its ports.
The power budget is finite. Microsoft's Windows docking guidance treats a dock's power as a total shared between the host and everything downstream.
- Its example is a dock with a 30W host port, two 4.5W USB-A 3.0 ports and a 7.5W charging USB-A port. That dock needs an adapter budget of at least 46.5W.
- When demand exceeds the budget, Microsoft's policy recommends the dock reduce the host's charging power to feed a newly attached device. If it can't, it should leave the new device unpowered.
In practice, plugging in more gadgets can slow your laptop's charging. A "100W" rating on a dock or adapter is a total or host figure. It doesn't mean every port delivers that.
Satechi's manual for its Thunderbolt 5 dock shows what real port specs look like:
- One front USB-C port is rated at 30W.
- The rear USB-C is 7.5W.
- The USB-A ports are 7.5W and 4.5W.
- The manual says the dock adjusts power automatically, and that if your computer needs more, you should disconnect high-power peripherals.
Read the per-port ratings for your dock before assuming it can top up everything at once. The XDA claim that a dock can charge camera batteries also depends on the camera. It works only if the camera or its charger accepts power from a USB port.
One genuine advantage over a plain GaN charger holds up. A dock also moves data, so the port charging a phone can sync it, and the SD card reader can offload photos.
Use 3: A dock with a built-in M.2 SSD
The third idea is a dock with an internal M.2 slot. A spare NVMe drive becomes fast external storage over the same single cable. XDA says few docks offer this, and the vendor manuals show it is a real but narrow product category.
Two documented examples, both from Satechi
| Feature | Thunderbolt 5 CubeDock | Dual Dock Stand |
| SSD support | NVMe (M-key) only, 2230/2242/2260/2280, up to 8TB | M.2 NVMe and SATA |
| Host link | Thunderbolt 5, up to 120Gbps | Two USB-C host connectors |
| Enclosure speed | PCIe 4x4, up to 64Gbps | Not listed |
| Ethernet | 2.5GbE | 1GbE |
The two docks differ in important ways, so check the exact model.
- The CubeDock manual says SATA SSDs will not function in this slot. The Dual Dock Stand lists both NVMe and SATA.
- The Dual Dock Stand manual says both USB-C host connectors must be connected for the dock to work properly. It also says to format the SSD so your host's operating system can read it.
- Both manuals say to eject storage properly before powering the dock off or unplugging it. The Dual Dock Stand warns that skipping this can corrupt or lose files.
- The CubeDock manual says to power the dock off and unplug it before installing or removing an SSD. It also says Windows may require driver installation for full functionality, so check the vendor's support page for your setup.
On speed: the drive's NVMe rating doesn't set the real-world speed. The dock's internal interface and the link to your computer do. A fast drive in a dock on a slower host connection will be limited by that connection. XDA calls the storage "lightning-fast", but I'm not aware of benchmarks in the source or vendor docs. Buyers who care should check the dock's stated host-link speed and the drive's thermal needs. The Satechi manual has you fit thermal pads, which suggests cooling matters.
The convenience argument stands. One box and one cable is tidier than a dock plus a separate enclosure. If portability matters, a standalone enclosure is still easier to carry, as XDA admits.
Quick buying checklist
- Host port: check it's USB-C with video output, USB4 or Thunderbolt, as your use requires.
- Dock outputs: HDMI or DisplayPort versions and supported resolutions and refresh rates.
- Power: adapter wattage, wattage delivered to the host, and per-port wattage.
- Storage: NVMe versus SATA support, form factor, capacity limit and thermal pads.
- Cable: use the cable supplied or one rated for the link speed you expect.
The takeaway
The XDA article's core point holds up: a dock is useful beyond a laptop and a monitor. The vendor documentation adds the limits. Docking doesn't boost a handheld's performance, charging power is shared, and the M.2 trick only works on models built for it. Choose the dock around the specs that matter for your use, not the connector shape.
- 3 clever uses for a USB-C dock that aren't obvious XDA · 2026-10-12T13:30:17+00:00
- What Is Thunderbolt™ 4 and How Is It Different from USB-C? – Intel intel.com
- User Manual - Thunderbolt 5 CubeDock™ with SSD Enclosure | ST-DT5CES-US – Satechi support.satechi.com
