The core problem: many ports, one upstream link
Hub makers love big port counts. Carrasqueira points out a common pattern: a hub advertises several 10Gbps USB 3.2 Gen 2 ports, but its link back to the computer is also a single 10Gbps connection. Two fast devices on that hub can't both run at full speed at once.
Other coverage of the same limitation agrees. MakeUseOf's analysis of hub bandwidth makes the same point. If you connect a hub or dock to a 40Gbps USB4 port, that is the bandwidth available to be shared across all of the hub's ports. Its example is a 13-in-1 hub where a single 10Gbps pipe is split across everything connected.
The USB Implementers Forum describes USB 3.2 as covering three signaling rates: 5Gbps, 10Gbps and 20Gbps. The 20Gbps rate uses two 10Gbps lanes. These are signaling-rate labels. They don't promise that any one device will sustain that rate, and they say nothing about how many such devices can share one uplink.
What actually happens when devices compete
The article says contention will "significantly" slow both devices and may leave them "nearly unusable". That is a worst case, not a rule. Microsoft's USB driver documentation gives a more precise picture:
- Competition comes from several places. Microsoft says bandwidth competition comes from both hardware and software. The host controller itself needs some bandwidth, and the amount varies by system.
- Topology matters. High-speed hubs sometimes translate traffic between speeds, which consumes bandwidth. Whether that happens depends on which devices are attached.
- Transfer types behave differently. Isochronous and interrupt transfers, which cameras and audio devices tend to use, reserve bandwidth. Bulk transfers, which file copies use, get no guaranteed share. Their speed depends on how much the periodic devices have reserved.
That last point may explain the author's capture-card story. A video device holds a steady claim on the bus while a large file copy takes whatever is left. This is a plausible reading. It is not proof, because the source gives no logs, topology or capture-card model.
The two anecdotes, taken for what they are
Carrasqueira describes two livestreaming incidents:
- Capture card plus SSD copy. He copied a large file to the SSD inside a Satechi Stand & Hub for the Mac mini while a capture card was in use. Video output went blank for several seconds and the transfer stalled. Unplugging the capture card let the copy finish.
- Capture card plus an 8,000Hz keyboard. While reviewing the Keychron Q16 HE, his capture feed went black for a few seconds at several points in a stream. The problem stopped once he unplugged the keyboard.
Both are personal observations, not controlled tests. The setup was a Mac mini, not a Windows PC. The root cause wasn't established. It could be bandwidth contention, hub firmware, cabling, power or driver behavior. A high polling rate also doesn't by itself show that a keyboard saturates a USB link. The reports are good illustrations of the symptoms. They don't show that any specific hub or keyboard causes dropouts.
Latency: worth testing, not worth assuming
The article says a hub adds a processing step and therefore latency that could affect audio or video. In principle a hub is another stage in the path. The reporting offers no measurements of how much delay a typical hub adds. For real-time work such as capture, audio interfaces and rhythm games, the sensible approach is to test the whole chain rather than assume the hub is guilty or innocent.
Power: read the spec sheet
The article says hubs can usually give peripherals 10W to 15W, even when they pass through nearly 100W to the laptop. The general lesson is sound. Pass-through charging figures describe power going to the host, not power available downstream. The 10 to 15W number can't be applied to every hub, though. Real budgets depend on the hub's design, its power source and its USB Power Delivery implementation.
Satechi's 4-Port USB-C Hub with Power Delivery is a handy example of reading specs carefully. Its listing supports up to 100W USB-C Power Delivery charging and four USB-C 3.2 Gen 2 ports. Those are two separate claims. Neither tells you how much power a bus-hungry audio interface or external drive will get.
Where Windows can help you diagnose it
Microsoft's documentation and community answers give a few concrete things to check on a PC:
- Look at the hub in Device Manager. Microsoft explains that a USB 3.0 hub supports all speeds by dynamically routing devices to its SuperSpeed hub or its 2.0 hub, based on device speed. A single physical hub therefore shows up as two entries. A slow peripheral doesn't necessarily drag everything else down to its speed.
- Watch for a "Non Functional" SuperSpeed entry. A Microsoft Q&A answer says that if the SuperSpeed hub says "(Non Functional)", you are probably hitting this issue. It describes this as Windows treating some early USB 3.0 hubs as USB 2.0 hubs. That would explain devices running far slower through a hub than when plugged in directly.
- Check which side of the hub each device sits on. Switch Device Manager to view devices by connection. A storage device should appear under the SuperSpeed hub. Something stuck under the USB 2.0 hub is running at USB 2.0 speeds.
- Check the USB controller's bandwidth allocation. Microsoft notes that you can see how much bandwidth a controller has allocated in the controller's properties in Device Manager, under the Advanced tab. It cautions that this reading doesn't show bandwidth used by hubs for transaction translation. Microsoft also says the feature doesn't work properly in Windows XP, which is unlikely to concern anyone today.
- Remember that built-in hubs exist. The Microsoft Q&A answer notes that some hubs are integrated into systems, so you may not realize you're using one.
Microsoft's FAQ also says a SuperSpeed device connected to a USB 2.0 port or hub will run only at high speed. Outdated hub firmware can cause problems too. Because the hub, the cable, the host port and the peripheral all have to support the speed you expect, any one of them can be the bottleneck.
A troubleshooting routine for flaky setups
If a capture card, audio interface or fast drive is misbehaving behind a hub:
- Plug the critical device straight into the PC. Try a different host port, ideally one on a different controller, and compare results.
- Separate the workloads. Don't run a heavy file copy through the same hub during a stream or recording. Repeat the copy afterward to see whether simultaneous use is the trigger.
- Verify every link in the chain. Check that the hub, cable, host port and device all support the speed you want. Look for the hub's second entry in Device Manager.
- Change one thing at a time. Swap cables, then ports, then the hub, and watch device and software status each time.
- Check power specs. If a device cuts out under load, confirm the hub's per-port and total power limits.
Do Thunderbolt docks fix it?
Partly. The Thunderbolt Technology Community says Thunderbolt 4 always delivers 40Gbps, while Thunderbolt 5 promises 80/120Gbps. Intel's Thunderbolt 5 brief describes 80Gbps in each direction, with a Bandwidth Boost mode that can shift capacity toward display traffic. Docks usually have their own power supplies and more capable chips, so they give more headroom and power than a basic bus-powered hub.
Those figures describe the link, though, not what each port gets. A dock with extra Thunderbolt ports, multiple displays and fast Ethernet can still run out of bandwidth or power. Carrasqueira notes that Thunderbolt 5 docks remain uncommon. He also says a desktop with plenty of native ports is the surest way to guarantee performance.
The practical takeaway
Hubs aren't bad. Keyboards, mice and light peripherals work fine through them. The trouble starts when you treat a hub as a pile of independent ports. If you run capture, high-speed storage, fast networking or power-hungry gear, find out what the hub's upstream link is, how its ports share it, and how much power it can really supply. Connect the devices that matter most directly to the PC, especially when you're hunting down an intermittent fault.
- Please stop treating your USB hubs as port replicators XDA · 2026-11-01T14:30:20+00:00
- 4-Port USB-C Hub with Power Delivery | USB Hub – Satechi satechi.net
- USB hubs have a big limitation that most product listings never mention makeuseof.com
