What ATX replaced
Before ATX, desktop boards followed IBM's AT and Baby AT conventions. The retrospective describes the problems:
- Full-size AT boards were too big. They didn't fit the smaller desktop cases that were becoming popular, and they could block the drive bays.
- Baby AT shrank the board but not the headaches. Only a keyboard connector was soldered to the board. Serial, parallel and later USB ports hung off ribbon cables.
- Pentium-era parts made it worse. Large heatsinks and longer memory modules got in the way of expansion cards and drive bays.
- Power was fragile. Baby AT used two nearly identical power connectors that could damage the board if swapped. It also couldn't shut the PC down from software.
Intel's fixes were simple. It rotated the layout 90 degrees, which put the CPU beside the power supply and away from the expansion slots. It added a keyed main power plug so it couldn't be inserted wrongly. It also supported soft power-off. The rear I/O panel was part of the board, so ports no longer needed cables.
Why it stuck
The retrospective points to two reasons: the spec was free to implement, and Intel's weight in the CPU, chipset and board markets pushed vendors to adopt it quickly. Intel added the smaller microATX variant in 1997.
The most useful design choice was how little the spec fixed. An Intel-era I/O design guide, hosted by Advantech, says the ATX and microATX specifications describe a back-panel aperture. Within that aperture, any number of I/O connector configurations may be offered. The guide gives the stacked I/O area as 6.25 inches (158.75 mm) wide by 1.75 inches (44.45 mm) tall. That is why the same opening has held PS/2 and serial ports, then USB, and now 40Gbps USB-C. The retrospective adds that vendors choose their own slots, sockets, memory type and headers.
In practice, ATX compatibility covers the case-to-board fit: mounting, rear panel, expansion-slot layout and power connections. It does not promise that every ATX board suits every case, cooler or graphics card.
Not a 1995 time capsule
The original design has been revised since launch. The archived revision that the research located is Version 1.1 from February 1996, and Version 2.01 followed in February 1997. A later revision, 2.03, is dated December 1998. Wikipedia currently lists version 2.2 as the most recent ATX motherboard specification. The accurate claim is that the layout logic has outlasted its original contents. The 1995 board and a 2026 board share a skeleton, not a spec sheet.
The alternatives that didn't win
- BTX was Intel's own successor attempt. At IDF in 2003, Intel said BTX was expected to supersede the ATX family of motherboard form factors over time. Intel's stated goals were better thermal management, system size and shape, acoustics and performance. Wikipedia says Intel discontinued any future development of BTX in 2006. The sources here don't establish why BTX lost, so I won't speculate.
- Mini-ITX is the real survivor. It came from VIA, not Intel. The Mini-ITX.com history records a larger ITX reference board at CeBIT in March 2001. It also records that in November 2001 VIA released the smaller 170mm x 170mm VT6010 Mini-ITX reference design. The same history notes that manufacturers largely ignored the earlier ITX board and built on FlexATX instead.
The pain points
The retrospective lists several modern frictions. These are the author's observations, not measured findings:
- Gaming GPUs can occupy up to four slots, which leaves fewer usable add-in slots on a board built around seven.
- Heavy cards sag, and many ship with support brackets.
- The primary M.2 slot often sits just above the GPU, so an installed card can cover it. Other slots sit between PCIe slots and can run warm.
- The 24-pin connector is bulky, and CPU power connectors sit at the top because PSUs once did.
- Back-connect designs such as ASUS BTF, MSI Project Zero and Gigabyte Project Stealth tidy the cabling. They remain niche because no universal standard exists.
ATX12VO V3: what is confirmed and what isn't
Intel now has an official public record that it updated the ATX12VO specification with a Version 3.0 update. The record is dated 29 May 2026. Intel's blurb calls it simpler, smaller and smarter than other desktop power supply specifications.
Intel's public page doesn't give connector details. The detail reported elsewhere comes from leaked slides, and those reports pre-date the official advisory:
- Tom's Hardware reported an 8-pin, 3 mm connector that Intel claims cuts overall connector size by up to 83% versus the 24-pin.
- The new 8-pin connector reportedly includes four optional PMBus pins.
- TechPowerUp reported that the standby rail is eliminated. It also reported new Low Power and High Power modes.
These details are leak-derived. Treat them as unconfirmed until you can read the full specification.
Adoption is also unproven. The retrospective says ATX12VO hasn't gained traction beyond some OEM PCs, and I found no evidence this week of retail motherboards or PSUs built to V3. Don't wait for a 24-pin-free retail ecosystem when planning your next build.
What this means for builders
- Check clearances, not just labels. "ATX" tells you the board will mount. Measure GPU thickness, cooler height and cable room.
- Plan M.2 placement. Look at where each slot sits relative to the GPU and whether the board includes heatsinks.
- Be careful with back-connect parts. They only work with compatible boards and cases, so check both.
- Don't count on ATX12VO. For now, a standard ATX PSU remains the practical choice.
Bottom line
ATX has lasted because it fixed a few physical things and left the rest to vendors. Intel itself failed to replace it with BTX, and rivals like Mini-ITX complement it rather than displace it. The retrospective's claim that ATX is "by far" the most popular standard fits the evidence qualitatively, but I found no market-share data to put a number on it. The 24-pin connector is the part most likely to change first, and that change is still on paper.
- Intel decided what motherboards look like in 1995, and we're still living with the consequences How-To Geek · 2026-11-03T16:30:16+00:00
- Design Guide for Intel ATX Motherboard I/O Implementations Version 1.1 - Advantech Support - Advantech advantech.com
- ATX12VO Version 3 Public Announcement Technical Advisory intel.com
