An Xbox console and controller sit beside an open gaming PC, with price tags showing $499.99 and about $740.
Engadget's Max Miller asked a question that would have sounded silly two years ago. How much does a PC cost if it has to do the Xbox Series S's job? Engadget's answer is about $740 before tax, using a new-parts AMD build. The console's price has also moved a lot, so the gap is worth a closer look.
An Xbox console and controller sit beside an open gaming PC, with price tags showing $499.99 and about $740. The console side of the comparison​
The 512GB Xbox Series S went up $100 to $499.99, and the 1TB Series X and Series S models went up $150. The changes took effect on August 1, 2026. That puts the entry model more than $200 above its original launch price. The original launch price was US$299.99.
Engadget treats memory and component costs as the driver. It says AI demand for computer hardware keeps pushing consumer prices higher, and that even old GPUs are now valuable. Geek Vibes Nation's coverage of the August hike also attributes it to rising component costs.
Engadget's ground rules​
Engadget set three rules for the build:
  • It had to beat the Series S at native 1080p, or at 1440p with reduced settings and upscaling.
  • It could use only parts still sold by major retailers.
  • It could not use refurbished parts, because those deals may vanish.
Engadget also warns that PC part pricing has never been this volatile. Read the total as a snapshot, not a durable shopping guide.
Engadget points out that the Series S uses custom hardware, so no current PC part is an apples-to-apples match. Engadget lists the console's specs this way:
  • An eight-core Zen 2 CPU at 3.6GHz, dropping to 3.4GHz in multithreaded work.
  • An RDNA 2 GPU with 20 compute units at 1,565MHz.
  • 10GB of unified GDDR6 on a 128-bit bus.
One caution: Engadget's memory line gives the raw throughput as "2.4GB/s". That figure looks like a typo and is far too low for GDDR6, so don't repeat it.
The parts list​
Engadget picks AMD for both CPU and GPU to match the console's all-AMD design. Here are the choices and the prices as reported in the article.
ComponentPickReported price
CPURyzen 5 5600 (flex pick: Ryzen 5 5600X3D)About $160 (X3D often on sale near $175)
MotherboardASRock B550M Phantom Gaming 4B550M boards run $80–$90
MemoryLenovo 2×4GB DDR4-3200$40
GPUASRock Challenger Radeon RX 7600 8GB$330
CoolerThermalright Peerless Assassin 120 SEAbout $35
Storage512GB SSDAbout $100
Power supply600W Thermaltake Toughpower GX2 (80+ Gold)Not stated
CaseZalman Cubix-G micro-ATX$35–$45
Engadget puts the total at roughly $740 before taxes, using the lowest prices at the time of writing. Some entries are ranges or unstated, so I won't try to add the column up to an exact figure.
Engadget's reasoning behind a few picks:
  • AM4 over AM5: The older socket saves money on the board and lets the build use DDR4. It still gives a better CPU than the console's Zen 2 part.
  • Motherboard: The B550M Phantom Gaming 4 was chosen for its VRM heatsinks and to avoid PCIe bottlenecks. Engadget warns it may need a BIOS update before it will boot the Ryzen 5 5600.
  • GPU: The GTX 1060 is the closest old equivalent, but Engadget says it is too old for newer titles. It also doubts the roughly $250 RTX 3050's 6GB of VRAM is enough for modern games.
  • GPU alternatives: Engadget lists a single-fan RTX 5050 at around $300 and an Intel Arc B570 at about $290 with 10GB of VRAM. It picks AMD partly to avoid possible driver or support headaches with Intel. That is the author's judgment, not a demonstrated fault.
  • Case: The Cubix-G may need a cheap adapter for its front USB-C cable.
What the $740 doesn't tell you​
The headline gap is about $240, from $740 versus $499.99. That is simple subtraction of two figures that don't cover the same things. Several caveats apply.
  • Missing items. The console includes a controller. Engadget's total doesn't price a controller, a Windows license, a display, peripherals or shipping.
  • Only 8GB of system RAM. Engadget argues the 8GB of VRAM on the GPU, plus system RAM, beats the console's 10GB of unified memory, and it chose two 4GB sticks for dual-channel operation. In my view this is the weakest choice in the build. System RAM and VRAM do different jobs. Modern Windows games and a background OS can strain 8GB. If the buyer later upgrades to 16GB, the real cost rises. Engadget gives no game-by-game tests to back the 8GB choice, so treat it as an assumption.
  • No performance testing. Engadget says the build outperforms the Series S "on paper." Console games are tuned for one fixed hardware target, and PC games are not. Frame rates, image quality and compatibility could differ in either direction.
  • Time-sensitive prices. The component prices are Engadget's snapshot, and I haven't checked them against retailers.
  • Affiliate disclosure. The article says Engadget may earn a commission on purchases from its links. The parts choices read as reasoned, but the disclosure is worth knowing about.
Why this matters to Windows users​
The Series S used to be the cheap way to play modern games. Engadget's conclusion is that the PC route now costs substantially more, though the PC does more than play games. A Windows gaming PC can also handle work, browsing, creative apps and storefronts beyond Xbox's.
Even so, I'd treat the build as a template. The sensible adjustments are:
  • Move to 16GB of RAM.
  • Budget for a Windows license and a controller.
  • Recheck every price before buying.
Engadget's own point stands: a cheaper PC would mean trade-offs, and a faster one would cost more. The Series S's price advantage has narrowed, but it hasn't vanished.
Correction (November 1, 2026): The console spec list originally repeated Engadget's figure of 12 compute units for the Xbox Series S GPU. Microsoft's official specification is 20 compute units at 1.565 GHz, so the figure has been corrected.
  1. How Much Would It Cost To Build A PC Similar To The Xbox Series S? - Engadget Engadget 2026-11-01T18:15:00+00:00
  2. Xbox Series X And Series S Prices Jump Again As Microsoft Blames Rising Component Costs geekvibesnation.com
  3. Xbox Series global price increase announced - Gematsu gematsu.com
