A custom translucent green Xbox Series S case conversion sits beside a white controller and a display placard.
A YouTube modder has put a standard Xbox Series S inside a custom X-shaped, translucent-green shell modeled on the original Xbox prototype. The shell is a case-and-display conversion, not a new Xbox model, and Microsoft isn't involved. It is a fun Xbox hardware story with some practical details worth sorting out.
A custom translucent green Xbox Series S case conversion sits beside a white controller and a display placard. What was built​
Tito, who runs the Macho Nacho Productions channel, announced the build on November 13. Foro3D reports that it uses a translucent green shell that recreates the original Xbox prototype from 2000, plus an ESP32-driven LCD screen showing 25th-anniversary animations. Tito's own post framed it this way: Xbox turns 25 and the official anniversary console is sold out, so he turned a Series S into the "perfect anniversary Xbox." He added that viewers can build one too. That is his stated motivation. The sources don't independently verify the sell-out.
The prototype it copies is the famous one Microsoft showed before the retail console launched. It was a huge block of machined aluminium with a glowing green orb in the middle.
How the conversion works​
Reported details differ in depth between sources, so here is what each one says.
  • Shell: Foro3D says PCBWay made the shell in transparent green, with internal rails that hold the Series S board and redesigned ventilation channels. TechEBlog adds that it uses copper threaded inserts and a clear center lens. It says the color matches Pantone 2259U.
  • Why the Series S: TechEBlog says the smaller board and footprint fit the X-shaped shell much better than a Series X would.
  • Assembly: According to TechEBlog, the process involves removing the console's outer casing, bottom plate and upper RF shield. The board then slides into the new shell on custom rails. A custom top cover has exhaust passages for the fan.
  • Display: The ESP32-powered LCD replaces the prototype's glowing jewel. TechEBlog attributes it to Dark One Customs and says it draws power from the Series S front USB-C port. It also says the display can be adjusted wirelessly from a phone.
  • Finish: The build ends with the front and rear frames bolted together and an anniversary sticker. TechEBlog says the finished console functions like a standard Series S, with hardware and software unchanged.
What isn't established​
  • Cooling: Neither source gives temperatures, airflow measurements or a thermal test. The shell was designed with ventilation features. Nobody has shown that it cools as well as the stock case.
  • Performance: "Works like any other Series S" means the internals are unchanged. No benchmarks have been reported.
  • Warranty and safety: The sources don't say whether Microsoft approves of this, whether a modified console keeps its warranty, or whether the shell has had any durability or safety testing. Opening a console and removing its RF shield is at the builder's own risk.
Files, cost and caveats​
Nacho Engineering lists a "25th Anniversary XBOX Series S PROTOTYPE Shell." It is described as designed to fit Series S hardware inside the X-shaped enclosure. The listing offers two sizes:
  • Large: This matches the build in the video and can accommodate the DVD drive for physical games.
  • Original size: This is true to Microsoft's original and smaller than the video build, so it can't take the DVD drive.
That drive note matters if you own a disc-based console. The listing text I could see doesn't explain how the two sizes relate to the Series S in particular, so check the product page before buying. Foro3D calls the files public. The listing appears to be a product page, so don't assume the files are free or open-source.
On cost, TechEBlog says a resin print runs roughly $2,400. It also says builders can print the shell themselves in cheaper filament. That figure is the outlet's estimate. It isn't an itemized all-in cost, and it's unclear whether it includes the console, display or shipping.
Context​
This isn't Tito's first prototype project. Last year he built a metal replica of the original Xbox prototype with real Xbox hardware inside. Developer StuckPixel wrote custom code for a Raspberry Pi Pico 2 to drive a circular screen in the center. The Series S build is the cheaper, plastic-shelled follow-up. It trades the mirror-polished aluminum for a see-through shell that shows off the board.
As Foro3D's closing quip puts it, the console still just plays games and generates heat. That is a fair summary. Nothing changes in how it runs, but now the heat comes with anniversary animations.
If you're tempted, treat it as a serious enclosure conversion rather than a skin:
  1. Read the exact product listing and parts list first.
  2. Confirm which console revision and drive configuration the files support.
  3. Plan for airflow and avoid blocking the vents.
  4. Accept that opening the console may affect your warranty.
  1. Xbox Series S transformed into the original Xbox prototype from 2000 - Foro3D Foro3D 2026-11-18T14:06:09+00:00
  2. Tito Builds the Translucent Green Xbox 25th Anniversary Series S Microsoft Never Released - TechEBlog techeblog.com
  3. 25th Anniversary XBOX Series S PROTOTYPE Shell - nacho engineering nachoengineering.com
