The thread discusses a user seeking a solution to match and transfer data between two large text files containing codes, names, and coordinates. After multiple attempts and questions, a respondent provides a PowerShell script that successfully merges the data by matching 8-digit codes. The user tests and confirms the script's effectiveness on smaller data sets, and later proceeds with processing the full files, expressing gratitude for the help. The overall sentiment is positive, with collaborative problem-solving leading to a functional solution.
Polycount
After searching everywhere I'm still unable to find a solution. I have two text documents, one is a list of names the other is coordinates.
both documents start each line with an 8 digit code.
I want to lookup 8 digit line code from File1 and copy the line contents to only code matches in File2.
(File1) Only one occurence of Code / Name.
136667ED ap1_01_a_ap1_01_rails_07
035B337C ap1_01_a_arrows_005
79546F82 ap1_01_a_centreline_010
0E1D31E7 prop_bush_med_02
(File2) Some have multiple Code copies, like 0E1D31E7. With different coordinates.
136667ED -1294.6945,-2376.0317,21.8279
035B337C -1314.6719,-2721.7378,12.9467
79546F82 -1283.1066,-2529.9771,12.9635
0E1D31E7 1919.4160,-1814.3889,160.5210
0E1D31E7 1919.9885,-2628.2529,0.7537
0E1D31E7 192.0235,-2603.1790,4.9978
0E1D31E7 192.1050,4950.3540,389.4736
(Result) The 8 Digit code / name, copied into any code line match in file 2. The name only added to any match would suffice.
136667ED -1294.6945,-2376.0317,21.8279           136667ED ap1_01_a_ap1_01_rails_07
035B337C -1314.6719,-2721.7378,12.9467           035B337C ap1_01_a_arrows_005
79546F82 -1283.1066,-2529.9771,12.9635           79546F82 ap1_01_a_centreline_010
0E1D31E7 1919.4160,-1814.3889,160.5210           0E1D31E7 prop_bush_med_02
0E1D31E7 1919.9885,-2628.2529,0.7537             0E1D31E7 prop_bush_med_02
0E1D31E7 192.0235,-2603.1790,4.9978              0E1D31E7 prop_bush_med_02
0E1D31E7 192.1050,4950.3540,389.4736             0E1D31E7 prop_bush_med_02
There are 75,000 names in File1, 370,000 lines of coordinates in File2.
Also I've converted them in excel, In hope there was a way to lookup and update all with names.
I did it in powershell, it's pretty basic, but it lets you specify Input1 (Unique entry file), Input2(Multiple instances file) -Output (merged output txt file) and -Index # the index for the column you want to match by. You would just need to save the code in a <Filename>.ps1 file and open an elevated Powershell promtp and type Set-ExecutionPolicy Unrestricted so you can run the script.
An image from 'Copy lines of text between two files, Using list / string matches.'. A PowerShell command merging three text files into one with a specified index.
param(
[string]$Input1,
[string]$Input2,
[string]$Output,
[int]$Index)
# Read in the file content
#unique entry file
$file1 = Get-Content -Path $Input1
#multiple instances
$file2 = Get-Content -Path $Input2
# create an empty array to hold the merged data
$merged = @()
# Index should start at 1, but we need to normalize it since arrays start at...
Neemobeer
Windows Forum Team
So are the input files text or excel and what do you want the output file to be text or excel?
Neemobeer
Windows Forum Team
param(
[string]$Input1,
[string]$Input2,
[string]$Output,
[int]$Index)
#unique entry file
#multiple instances
$merged = @()
# Index should start at 1, but we need to normalize it since arrays start at 0
if ($index -eq $null)
    $index = 0
} else
    $index--
ForEach ($line In $file2)
    $parsedLine = $line.Split(' ')
    ForEach ($uniqueLine In $file1)
        $parseUniqueLine = $uniqueLine.Split(' ')
        If ($parsedLine[$index] -ieq $parseUniqueLine[$Index])
            $merged = $merged + @("$parseUniqueLine `t$parsedLine")
            break
Out-File -InputObject $merged -FilePath $output
Polycount
Thread Author #5
Tested it on a small section of data. It worked nicely
I'm processing the entire files now. It has been 30 mins so far. Blinking cursor
Thanks for the code Neemobeer.
Found a tutorial, for excel which worked
