martin100181
Hello, I just bought a new large format epson printer. This printer has 2 current blank inks (photo black and matteclack) but can use only one at the time depending on the paper selected in the driver window.
The problem is that every ink change from one black to another is a waste of ink, and money and is not always needed, but the printer driver decides to change it because is associated to the paper and the option to change the ink type for that paper is always shadowedso I can't change it.
Service support says I have to "cheat"the printer selecting a photo paper even if I'm printing on a matte paper so the printer won't ask for an ink change to matte, but this solutionis not always enough.sometimes I need to select the right paper but changing the default ink type.
Is there any way to change it within the driver? By Ermak the ink type field or changing that restriction?
Than you
When dealing with printers that have restrictions on ink type changes based on the paper selected in the driver window, it can be frustrating to deal with the unnecessary ink and cost waste that comes with it. It's unfortunate that the printer driver doesn't provide an easy way to override this restriction. One workaround you could try involves modifying the driver settings to allow changing the ink type regardless of the paper selected. Here's a general guide on how you might be able to achieve this:
Steps to Potentially Modify Ink Type Field or Override Restriction:​
  • Advanced Settings: Check if there is an advanced settings menu within the printer driver software that might allow you to access more detailed options...
  • Registry Edits: Some printers may have registry settings that control these restrictions. Modifying the registry incorrectly can cause issues, so proceed with caution or seek professional help if needed.
  • Third-Party Tools: There are software tools available that can sometimes provide additional control over printer settings beyond what the default driver offers. These tools are typically more advanced and might require some technical knowledge to use effectively.
  • Printer Firmware Update: Occasionally, printer manufacturers release firmware updates that address specific issues or add new features. Check if there are any firmware updates available for your Epson printer that might address this restriction.
Note:​
  • Caution: Modifying registry settings and firmware updates can have risks, so it's essential to back up any critical data and proceed with caution.
  • Professional Assistance: If you're not comfortable with technical modifications, it's advisable to seek help from a professional. By exploring these avenues, you might find a way to adjust the ink type settings within the driver to better suit your printing needs and avoid unnecessary ink changes. If you encounter any challenges or need further assistance, feel free to provide additional details, and I'll do my best to help.
