The thread begins with a beginner seeking guidance on creating a simple ASP.NET VB.NET program for CRUD operations and search functionality. Most responses suggest using Google and online tutorials for learning, with one user humorously emphasizing the importance of searching. Later, the discussion shifts to troubleshooting a Windows audio issue, with contributors recommending system details, driver solutions, and appropriate forum sections, indicating a helpful community focused on technical support. Overall, the forum provides basic programming advice and troubleshooting support, with a collaborative and welcoming tone.
francemj
hi! everyone i'm new in using asp.net and vb.net, if there someone who can help me how to make a simple program of add, edit, delete and also include search in asp.net. thanks and more blessings...!!!
Hi Prakash and welcome to the forum. Just for future reference..This would have been better posted in the section called 'Support' as you'll get a better response.
Anyhow.. Back to your problem, First of all Prakash can you post some details of what your using( pc spec) and how it came to be that way (how did you lose the audio)
03hdfatboy
Banned
Hey Bios can you move this to the multimedia thread?
Thanks
now back to the issue..yes any USEFUL information is helpful. what brand of sound card are you running and whatever else you can tell us. If it is a sound blaster you can download "Danial's" drivers. I've herd it has helped a lot of people.
I'm sure Kemical knows where you can get it.
The link I posted should still work but I'll wait and see what his card is first and then if need be go find it ( the post)
