Hi i am programmer and i noticed this problem due programming all my works i save in one .INI file on Windows7 that worked perfectly now i installed a win 8.1 64 based system and i cannot read/save/saw what is inside .ini file PLEASE FIX IT i need it i dont want to go on win7 again 😀
The thread discusses a programming issue where the user, after upgrading from Windows 7 to Windows 8.1 64-bit, can no longer read or save data in INI files using their scripting setup with Pawno for SA-MP. Responders ask for details about the programming language and file placement to better diagnose the problem. The user explains they use the YINI plugin with Notepad to manage INI files placed next to their game mode on the desktop, indicating compatibility issues may be related to file location or permissions in Windows 8.1.
There are a number of questions that need answered in order to help you.
1) What programming language and method(s) are you using to read/write to the ini file(s)?
2) Where are you placing the ini file(s)? In later versions of windows you should be placing these files in a folder that is completely user accessible, such as AppData (%APPDATA% variable contains this path for the current user), and probably not in the windows folder itself.
- Joined
- Aug 3, 2010
- Messages
- 1,284
