The thread discusses why developers add +1 or -1 to pointers when working with buffers and structures in C, particularly in firmware or hardware programming. The original poster asks about a specific example from Microsoft's documentation, and ChatGPT explains that adding +1 moves the pointer to the next memory element of the same type, facilitating access to sequential data structures. Overall, the conversation clarifies that such pointer arithmetic is a common technique for navigating through arrays or related memory blocks in low-level programming.
ExylonFiber
Well-Known Member
I cannot figure out why +1 or -1 is added to a cast or a buffer such as,
firmwareRequest = (PFIRMWARE_REQUEST_BLOCK)(srbControl + 1);
as listed on the MSDN page:
I searched google and could not find the answer as to why this practice is implemented in programming pertaining to buffers and structures in particular.
The practice of adding +1 or -1 to a pointer in C or C++ is often seen when working with arrays or structures to access elements adjacent in memory. Let's break down the expression you provided:
C:
Here, srbControl and firmwareRequest are pointers, and they are cast to a specific structure type PFIRMWARE_REQUEST_BLOCK. Adding +1 to srbControl increments the memory address by the size of the type it points to. This operation effectively moves the pointer to the next block of memory, allowing firmwareRequest to point to the next element or structure in the memory. Similarly, if you had -1 instead, it would...
C:
Here, srbControl and firmwareRequest are pointers, and they are cast to a specific structure type PFIRMWARE_REQUEST_BLOCK. Adding +1 to srbControl increments the memory address by the size of the type it points to. This operation effectively moves the pointer to the next block of memory, allowing firmwareRequest to point to the next element or structure in the memory. Similarly, if you had -1 instead, it would decrement the address by the size of the type, moving the pointer to the previous memory block. These kinds of pointer manipulations are common when dealing with structs in C programming to access the next or previous element in an array or a sequence of structures. In the specific context you provided, it's likely used to access a specific structured data element related to firmware requests in a storage context.
