Microsoft’s concise wording that “Azure Linux includes this open‑source library and is therefore potentially affected” is accurate — but it is a product‑scoped attestation, not a categorical statement that no other Microsoft product can ever include the same upstream code; customers should treat Azure Linux as the only Microsoft product Microsoft has validated and published so far, and then verify all other Microsoft artifacts in their estates because inclusion of an upstream kernel feature is an artifact‑level property that depends on build configuration and packaging.
Neon cyan infographic of Azure Linux cloud, CVE 2024 47794, and patch notes.Background / Overview​
CVE‑2024‑47794 is a Linux‑kernel eBPF vulnerability that was assigned after maintainers identified an interaction between tail calls and the freplace extension mechanism. In short, a particular chain of eBPF programs can produce an infinite tail‑call loop: entry_tc → subprog_tc → entry_freplace --tailcall→ entry_tc. The bug arises because the tail call counter is reset in the freplace trampoline, allowing the loop to run without the usual termination guard and eventually causing a kernel panic. The upstream fix prevents certain combinations of freplace and prog_array usage and blocks extension programs from being tail‑called. This is an availability‑class vulnerability: the practical impact is denial‑of‑service (host crash), not a direct, documented remote code‑execution primitive. The attack surface is local or limited to environments where untrusted users can load BPF programs (for example, multi‑tenant systems, unprivileged BPF‑loading interfaces, or misconfigured cloud images). Multiple distro and vendor trackers have ingested the kernel commit and published advisories and package updates. Microsoft’s public security guidance for third‑party CVEs now follows a machine‑readable CSAF/VEX model and began publishing attestations starting with the Azure Linux distribution in October 2025. The company uses VEX/CSAF to map upstream components into specific Microsoft product artifacts and to state a product’s status for a CVE (Known Affected, Not Affected, Fixed, Under Investigation). Microsoft has explicitly said that, where it has identified a product that includes an implicated upstream component, it will publish a product‑scoped attestation and will update the CVE entry if it later discovers additional Microsoft products that ship the same component.
What Microsoft’s Phrase Actually Means​
The literal wording​
When MSRC (or the MSRC‑derived machinery that feeds VEX/CSAF) says that “Azure Linux includes this open‑source library and is therefore potentially affected,” that sentence accomplishes three things:
  • It confirms Microsoft completed an internal inventory for the Azure Linux product family and found the upstream component present in those artifacts.
  • It signals that Azure Linux customers should treat their Azure Linux images as in‑scope and follow Microsoft’s remediation guidance.
  • It documents a procedural commitment: Microsoft will update the CVE/VEX entry if it identifies other Microsoft products that ship the component.
Why this is not a blanket “only Azure Linux” guarantee​
Large vendors ship many distinct artifacts — kernels, VM images, container base layers, WSL kernels, managed appliance images, and static binaries. Whether an upstream kernel file or open‑source library is present depends on the artifact’s build configuration (kernel CONFIG flags), packaging and linking choices (static vs. shared), and which kernel version or distro snapshot was used to assemble the image.
Therefore: Microsoft naming Azure Linux is an authoritative signal for Azure Linux alone; it does not prove other Microsoft images, WSL kernels, Marketplace appliances, or vendor‑provided containers are absent of that same upstream code. The correct operational stance is to act immediately on the Azure Linux attestation and to verify other Microsoft artifacts in your estate rather than infer safety from silence.
Cross‑checking the technical facts (independent confirmation)​
Two independent, authoritative feeds corroborate the technical nature of CVE‑2024‑47794 and the patch approach:
  • NVD (US‑government vulnerability database) records the CVE description and summarizes the fix: block the freplace/prog_array combination that allowed the tailcall counter reset and prevent extension programs from being tail‑called.
  • Linux distribution advisories (for example, Ubuntu’s security notice and Debian/OSV entries) repeat the vulnerability description and map it into kernel package advisories, with CVSS/priority markings and timelines for patched packages. These distro trackers are the canonical operational signals for system administrators who run packaged kernels.
Additional vendor trackers (Amazon Linux ALAS, Red Hat/other vendor databases) also list the issue and include package/status mappings — providing further corroboration that the bug is real, has been fixed upstream, and is being rolled into distribution kernel packages.
Is Azure Linux the only Microsoft product that includes the implicated open‑source code?​
Short answer: No — not necessarily in practice. But yes — Azure Linux is the only Microsoft product Microsoft has publicly attested as including the component at the time of the advisory.
Longer answer: Microsoft’s public VEX/CSAF attestation identifies Azure Linux as a product that includes the vulnerable upstream kernel component; that attestation is authoritative for Azure Linux images and should be treated as the canonical signal for enterprises that consume those images. However, the presence of an upstream kernel driver or BPF functionality in other Microsoft artifacts (WSL2 kernel builds, the linux‑azure kernel packages used by some Azure services, Marketplace VM images, curated container images, or statically linked binaries used by internal services) depends on per‑artifact build choices. Until Microsoft expands its VEX mapping or you independently inspect those artifacts, assume uncertainty and verify.
What operators must do right now — practical, verifiable steps​
Treat the Azure Linux attestation as an immediate action item, then broaden verification across other Microsoft artefacts. The following checklist is structured for clarity and repeatability.
1. Patch Azure Linux images immediately​
  • Follow Microsoft’s published Azure Linux kernel and image updates for the CVE; apply patches or rebuild images that include the fixed kernel packages.
  • For managed VMs, apply vendor‑supplied updates or redeploy patched images from Microsoft’s official repos.
If you run Azure Linux in production, treat Microsoft’s VEX/CSAF attestation as a high‑confidence automation input and prioritize remediation accordingly.
2. Inventory all Microsoft artifacts in your estate (images, WSL kernels, Marketplace appliances)​
  • Run one of these approaches:
  • SBOM or SCA scans against container images and VM images.
  • Binary search for kernel symbols or BPF feature strings in packaged kernels and images.
  • For WSL2: inspect the WSL2 kernel source/config that Microsoft publishes on GitHub, or check the kernel version shipped with your WSL2 installation.
  • Example commands to run on a Linux host (or Azure VM):
  • uname -r
  • zgrep CONFIG_BPF /proc/config.gz || grep -w CONFIG_BPF /boot/config-$(uname -r)
  • lsmod | grep bpf || modinfo bpf
  • rpm -q --changelog kernel | grep -i 47794 (or apt changelog equivalent)
  • For container images, use: skopeo inspect / dive / trivy / grype to locate kernel toolchains or suspect binaries.
These per‑artifact checks establish whether a given image contains the vulnerable kernel or an eBPF stack compiled with the affected behavior.
3. Inspect WSL and other Microsoft‑distributed kernels​
Microsoft publishes the WSL2 kernel source and configuration publicly; check the repository for the relevant BPF code presence and the kernel config used to build distributed WSL kernels. If you run custom WSL kernels, verify your custom build does not include the vulnerable combination of freplace and prog_array support that could enable the CVE pattern.
4. Limit exposure while you patch​
  • Restrict BPF loading to trusted administrators. Remove CAP_BPF or restrict who can attach BPF programs in multi‑tenant contexts.
  • Limit access to interfaces that allow untrusted program loading (CI runners, unprivileged runtime sandboxes).
  • Apply pragmatic containment: avoid mounting /lib/modules or /dev into untrusted containers, and restrict container host capabilities.
These mitigations reduce the attack surface until kernels are patched and packaged images are updated.
5. Automate VEX/CSAF consumption​
  • Ensure your vulnerability management pipeline ingests Microsoft’s CSAF/VEX feeds. Microsoft began publishing VEX/CSAF attestations for Azure Linux in October 2025; subscribing to these feeds gives timely product‑scoped attestations as Microsoft completes additional inventories.
Technical verification recipes (commands and checks)​
Below are specific, reproducible commands administrators can use to verify whether a running Linux image (including Azure VMs and WSL instances) carries affected kernel code.
  • Check kernel version and vendor:
  • uname -a
  • Check for BPF and prog_array support:
  • grep -i BPF /boot/config-$(uname -r) || zgrep BPF /proc/config.gz
  • grep -E "CONFIG_BPF|CONFIG_BPF_SYSCALL|CONFIG_BPF_JIT" /boot/config-$(uname -r)
  • Search for the specific selftest that demonstrates the issue:
  • Locate selftests in kernel source or installed debug packages for selftests/bpf/tailcall_freplace.c
  • Confirm package changelog includes the upstream commit or CVE tag:
  • Debian/Ubuntu: apt changelog linux-image-$(uname -r) | grep -i 47794
  • RPM: rpm -q --changelog kernel | grep -i 47794
If the artifact lacks the patched upstream commit or your distro package changelog does not reference the fix, assume the node is unpatched and schedule remediation.
Strengths and weaknesses of Microsoft’s VEX/CSAF approach​
Strengths​
  • Machine‑readable, product‑scoped attestations drastically reduce noisy false positives for customers that run Azure Linux images: enterprises can automate whether a Microsoft product is in scope for a CVE rather than guess from ambiguous advisory text. This reduces triage time and focuses patching effort.
  • Phased rollout starting with Azure Linux provides an operational playbook that is realistic for a vendor with a vast artifact inventory: begin with a known family, publish attestations, and expand as inventories complete.
Weaknesses / risks​
  • Phase‑in leaves a window of uncertainty for other Microsoft artifacts. Until Microsoft completes inventory across all product families, customers must not assume un‑attested Microsoft SKUs are safe. The attestation is a map of what Microsoft has checked, not an exclusion proof for what it hasn’t checked.
  • Artifact diversity in cloud vendors — many kernel builds, image variants, and static binaries — means a one‑line vendor statement cannot substitute for artifact‑level verification in high‑assurance environments.
  • Static binaries and embedded toolchains are a special class of risk: a static Go/other runtime or a vendor‑built binary can carry the vulnerable behavior even after the base distribution is patched. Rebuilding static artifacts is required to be certain they are safe.
Risk analysis for WindowsForum readers and enterprise operators​
CVE‑2024‑47794 is a medium‑severity, local/host DoS issue in the kernel eBPF subsystem. The immediate blast radius is highest for multi‑tenant systems that allow untrusted users to load BPF programs. For most single‑tenant, well‑hardened systems where unprivileged BPF loading is restricted, the practical exploitability is low; nevertheless, a kernel crash on a host in a cloud environment can impact availability for many tenants and services, so cloud operators must respond quickly.
Microsoft’s attestation that Azure Linux includes the implicated open‑source library is an authoritative, actionable signal for those who run Azure Linux. It is not an assurance that WSL2, linux‑azure kernels used in managed services, Marketplace images, or other Microsoft‑distributed artifacts are free of the same upstream code. Operationally, treat the Azure Linux VEX as a high‑priority triage input and perform artifact‑level verification for other Microsoft artifacts in your estate.
When vendor attestations are insufficient: a short checklist​
  • Do not assume a vendor‑published product list is exhaustive — treat it as authoritative for items named only.
  • For any Microsoft artifact you run, perform one of:
  • Artifact inspection (unpack images and search for kernel versions, installed modules or binaries),
  • SBOM/SCA scan,
  • Review vendor kernel/package changelogs for the upstream commit or CVE number.
  • Where static linking is used, plan rebuilds with patched upstream toolchains to eradicate lingering vulnerabilities.
  • Subscribe to VEX/CSAF feeds and automate their ingestion into your vulnerability management pipeline.
What we verified and where uncertainty remains​
Independent sources (NVD, Ubuntu, Debian/OSV and multiple vendor trackers) confirm the technical description and the upstream patch strategy for CVE‑2024‑47794. Microsoft’s broader transparency program and the VEX/CSAF rollout — which started for Azure Linux in October 2025 — explain the procedural reason Microsoft can state Azure Linux is “potentially affected” and commit to updating the CVE/VEX record if additional Microsoft products are discovered to ship the component. Those are verifiable facts. What remains a live question for each operator is whether their specific Microsoft‑supplied artifacts (WSL kernels, Marketplace images, custom Azure Marketplace appliances, Databricks runtime images, or internal Microsoft‑built images) also contain the upstream code that could trigger CVE‑2024‑47794. That is an artifact‑level fact that requires either Microsoft to expand its VEX attestations or you to inspect the artifacts yourself. Microsoft has promised to update VEX/CSAF entries when new product mappings are discovered; until then, absence of an attestation is not evidence of absence.
Conclusion — clear operational guidance​
  • Treat Microsoft’s Azure Linux attestation as authoritative for Azure Linux and remediate accordingly. Apply the kernel updates Microsoft lists and rebuild or redeploy patched images promptly.
  • Do not assume other Microsoft products are unaffected merely because they are not listed. Instead, perform artifact‑level verification (SBOM/SCA, kernel config checks, package changelog inspection) for every Microsoft‑provided image, kernel, or appliance you run.
  • Restrict BPF loading to trusted principals and apply compensating containment measures while you complete remediation.
  • Ingest Microsoft’s CSAF/VEX feed into your automation pipeline so you receive machine‑readable attestations as Microsoft expands coverage beyond Azure Linux.
Microsoft’s decision to publish VEX/CSAF attestations for Azure Linux is a material step forward for supply‑chain clarity; it gives operators a deterministic, automatable way to triage Azure Linux images. The important caveat is that the VEX/CSAF approach is phased and product‑scoped — it speeds triage for attested products, but it does not eliminate the need for per‑artifact verification across the rest of the vendor’s diverse image and kernel portfolio.
If immediate verification shows other Microsoft artifacts in your estate include the upstream kernel files (BPF, freplace/prog_array support) tied to CVE‑2024‑47794, treat those artifacts as in‑scope and apply the same remediation pattern as for Azure Linux (patch or rebuild with a patched kernel). If you cannot quickly patch, apply the containment actions listed above and escalate to your platform provider or vendor contacts for prioritized updates.
