The short answer: No — Azure Linux is not necessarily the only Microsoft product that could include the open‑source Bootstrap code at issue, but it is the only Microsoft product Microsoft has publicly attested (so far) as including that component and therefore being “potentially affected.” Microsoft’s attestation model and the subsequent rescinding of CVE‑2024‑6531 create a precise but nuanced operational reality: treat Azure Linux as an authoritative inventory hit, treat other Microsoft artifacts as unverified until they are explicitly attested or you verify them yourself, and apply artifact‑level checks rather than relying on absence‑of‑mention as a guarantee of safety.
Background / Overview
CVE‑2024‑6531 was originally assigned to a reported cross‑site scripting (XSS) issue tied to Bootstrap’s carousel handling of certain HTML attributes. Many mainstream trackers documented the original report and assigned medium severity scores while vendors and packagers began triage. Over time the maintainers and several downstream brokers concluded the reported behavior fell outside Bootstrap’s security model: Bootstrap’s JavaScript is not intended to sanitize unsafe or intentionally dangerous HTML. The CVE record was therefore marked rejected/rescinded. Multiple vendor pages and aggregated vulnerability feeds now show the “rejected” or “withdrawn” status for CVE‑2024‑6531. At roughly the same time Microsoft published a machine‑readable VEX/CSAF attestation for the same CVE identifier. That Microsoft attestation explicitly states Azure Linux (CBL‑Mariner / Azure Linux lineage) includes the implicated component and lists specific product entries (CBL Mariner 2.0, Azure Linux 3.0 and related package build artifacts) in the product tree. Microsoft’s VEX payload also records the rescinded nature of the CVE and flags the attested products as “known_affected” within Microsoft’s inventory mapping. In other words, Microsoft has checked and declared certain Azure Linux artifacts as carriers — and it documented that inventory in a machine‑readable way. Those two facts — (1) the CVE was rescinded at the upstream/assigner level, and (2) Microsoft’s product‑level inventory named Azure Linux as carrying the component — are the root of the user question and of the operational ambiguity many administrators now face.
What Microsoft actually declared (and what that means)
The mechanics of Microsoft’s VEX/CSAF statement
Microsoft’s CSAF/VEX entry for the CVE is not a general pronouncement that “only Azure Linux contains this code.” It is a product‑scoped inventory attestation: Microsoft inspected specific Azure Linux builds and found the upstream component (or packages derived from it), then published that result in a VEX/CASF document so downstream automation and customers can make deterministic decisions. The VEX payload includes a product tree naming Azure Linux and CBL‑Mariner artifacts and maps several product IDs as “known_affected.” That mapping is authoritative for those named Azure Linux artifacts.
Product attestation ≠ exclusivity
An attestation that some product includes a component is not logically equivalent to a guarantee that no other products include it. Large vendors ship many artifacts assembled from common upstream source code; whether a given artifact includes a specific upstream file depends on build provenance, packaging choices, and configuration. Microsoft’s public messaging explicitly recognized this: the company began publishing VEX/CSAF attestations starting with Azure Linux in October 2025 and committed to update the CVE records if additional Microsoft products are identified as carriers. That phrasing is procedural — it says what Microsoft has checked so far, not what it has exhaustively excluded.
Why the distinction matters for defenders
- Automation and triage rely on positive signals. A machine‑readable VEX entry is a powerful automation input: if a vendor lists a product as KnownAffected, a SOC or patch orchestration system can automatically prioritize updates. Microsoft’s VEX attestation provides exactly that for Azure Linux.
- Absence of an attestation is not proof of absence. If a Microsoft product (for example, WSL2 kernels shipped to Windows clients, linux‑azure kernels used in some Azure VM SKUs, Marketplace appliance images, or partner images) has not been listed in Microsoft’s VEX output, that should be read as “not yet attested” rather than “not affected.” The same upstream source file or compiled component can appear across multiple artifacts depending on build pipelines and packaging choices.
- Rescinded CVE creates a different kind of risk. When a CVE is withdrawn or rejected because the reported behavior falls outside the vendor’s security model, downstream vendors and packagers may still have to reconcile inventory, legal, and support implications. Some downstream scanners will continue to flag records until their databases are reconciled; others may remain in stale state. That inconsistency can create noise and lead to incorrect prioritization if automated systems are not tuned to account for rescinded statuses.
Independent cross‑checks and verification
To be robust, a security answer should be cross‑checked against multiple independent sources. The following independent threads converge on the same operational facts:
- Microsoft’s VEX/CSAF JSON shows a product tree naming Azure Linux/CBL‑Mariner artifacts as known_affected and documents the VEX publication. That payload is authoritative for Microsoft’s internal inventory mapping.
- Major distribution trackers and vulnerability databases show CVE‑2024‑6531 as rejected/withdrawn because the Bootstrap maintainers and reporters concluded Bootstrap JS was not intended to sanitize deliberately unsafe HTML. That rescind status appears in Ubuntu’s advisory page and in circulating CVE mirrors.
- Aggregators and security vendors (Rapid7, Debian trackers, Aqua, CVE feeds) retain records of the original report and the subsequent resolution state; many of these pages indicate “rejected” or show the rescind date in their metadata. These mirrors explain the reconciliation process downstream of the CNA/CVE assignment.
Taken together, these sources validate both the rescinded status of the CVE itself and Microsoft’s product‑level attestation naming Azure Linux as a product that includes the component Microsoft inspected.
Practical technical analysis — why Microsoft checked Azure Linux first
Microsoft began its CSAF/VEX rollout with Azure Linux (CBL‑Mariner lineage). That rollout is pragmatic: the company first inventories and publishes attestations for the product families it maintains and ships itself. Azure Linux is the internal Linux distribution Microsoft maintains for many cloud images and is therefore a natural starting point for supply‑chain attestations. The VEX mapping shows the specific package builds and product versions Microsoft inspected as components of Azure Linux, which allows operators to triage their Azure images deterministically. This does not mean other Microsoft artifacts (WSL, linux‑azure kernels, some Marketplace images) are incontrovertibly clean. Those artifacts can be built from different source trees, include different compiled modules, or even embed third‑party userland bundles that carry the same upstream components. Whether an artifact is affected is a per‑artifact fact, and only artifact‑level verification (SBOM, binary inspection, or a vendor attestation) yields a definitive answer.
Strengths of Microsoft’s approach — and why they matter
- Machine‑readable attestations (CSAF/VEX) solve real automation problems. Publishing VEX files lets enterprises build automated triage rules: KnownAffected → schedule patching; NotAffected → skip; UnderInvestigation → escalate. That determinism greatly reduces investigation time for administrators who run the attested product. Microsoft publishing these attestations for Azure Linux is a positive operational step.
- Transparent change history. The VEX JSON includes revision history entries and product mappings. That lets auditors and automation know exactly which product versions were inspected and when the inventory occurred — useful for compliance and incident response.
- Commitment to expand coverage. Microsoft publicly committed to update VEX/CSAF entries when additional product impact is identified, which indicates a planned, phased inventory program rather than a one‑off notice. That helps large customers plan for downstream updates.
Risks, gaps, and practical caveats
- False sense of security for un‑attested products. Administrators that see Azure Linux in Microsoft’s VEX and assume all Microsoft artifacts are safe will be at risk if other artifacts include the same component. Treat a VEX omission as “unknown,” not “safe.”
- Rescinded CVE vs. insecure application logic. The rescind reason is procedural: Bootstrap maintainers say the library is not intended to sanitize intentionally dangerous HTML. But the underlying class of risk (unsafely rendering user‑controlled HTML) is still a real application risk and will remain relevant. Applications that use Bootstrap in unsafe ways can still be vulnerable to XSS because of application‑level choices, even if the CVE against the library itself is rescinded. Operators must still review application logic and data handling.
- Scanner noise and DB lag. Different vulnerability databases may take time to reflect the rescinded state. Some automated scanners will still flag the original CVE until feeds are refreshed, causing alert fatigue. Teams should validate scanner alerts against authoritative sources before escalating.
- Package vs. embedded code. Even when a packaged library is patched or rescinded, a copy of the same code can be statically embedded into an application, a container image, or a firmware bundle. Inventory must include searching for embedded code, not just OS package versions.
Recommended operational steps (actionable checklist)
Follow these prioritized, practical steps to both respect Microsoft’s attestation and to protect non‑attested artifacts in your environment.
- Immediate triage for Azure Linux assets
- Treat Azure Linux / CBL‑Mariner images listed in Microsoft’s VEX as authoritative inventory hits. Validate which VM images, AKS node images, or Marketplace images in your estate use those Azure Linux builds and prioritize their remediation or verification.
- Verify the rescind status and reconcile alerts
- Update your vulnerability scanner feed state with the rescind information; suppress or reconcile duplicate alerts that are resolved by the “rejected” classification. Use multiple sources (vendor VEX/CSAF + distro advisories) to confirm the rescind.
- Artifact‑level inventory for other Microsoft artifacts
- Do not assume WSL, linux‑azure kernels, Marketplace appliances, or partner images are safe. Run binary inspections, SBOM checks, or runtime package listings on:
- WSL kernels shipped to Windows endpoints
- linux‑azure kernel packages used in VM SKUs
- Azure Marketplace images and partner appliances
- Container images and OCI artifacts you run in Azure
- If a given artifact contains the same upstream files or bundled packages, treat it as in‑scope until proven otherwise.
- Search for embedded or statically‑linked copies
- Scan container images, web application bundles, and static assets for Bootstrap references (versions ≤ 4.6.2 in some trackers) or for the vulnerable component patterns the original report described (carousel link handling). Use recursive filesystem searches, SCA tools, and container image scanners.
- Strengthen application‑level defenses
- Regardless of the CVE’s rescind status, harden applications:
- Sanitize or escape user‑supplied HTML before inserting it into attributes or markup.
- Use CSP (Content Security Policy) to reduce impact of XSS payloads.
- Apply server‑side validation and whitelisting for inputs that will be rendered as HTML attributes.
- Consider upgrading to modern Bootstrap versions or frameworks that avoid risky attribute‑based APIs.
- Improve SBOM and attestation consumption
- Ingest Microsoft’s CSAF/VEX feeds into your triage pipeline so that product attestations are machine‑readable for automation.
- Maintain a living inventory (SBOM + runtime checks) for cloud images and endpoints so attestation gaps can be quickly identified and validated.
- Track vendor attestation rollouts
- Microsoft committed to expanding VEX/CSAF coverage over time. Subscribe to MSRC feeds or the CSAF/VEX feed endpoints to get automated updates when new product attestations are published. Don’t rely on a single snapshot.
How to read and interpret the “KnownAffected” list in Microsoft’s VEX
Microsoft’s VEX JSON attaches product IDs and product version nodes under the product_tree. When the VEX item lists a product version as “known_affected,” that means Microsoft’s inventory process found the component present in that build and chose to mark the product as “potentially affected.” For the CVE in question Microsoft’s published JSON lists CBL‑Mariner 2.0 and Azure Linux 3.0 and specific build artifacts by product ID in the product tree. That is a precise machine‑actionable mapping for operators running those artifacts. Use the product ID to map back to your asset inventory and to your change control systems; that makes automated patching or mitigation possible with high confidence.
Critical analysis: the good, the bad, and the nuance
Notable strengths
- Vendor transparency through machine‑readable attestations: Microsoft’s VEX publication is a best‑practice move and helps reduce ambiguity for customers running attested products. It reduces investigative workload for Azure Linux customers by giving a deterministic signal.
- Explicit rescind handling: The visibility of the rescind status (CVE marked rejected) across vendor and aggregator databases helps reduce wasted remediation cycles once the technical consensus is reached that the library’s intended behavior excludes the reported risk.
Potential risks and weaknesses
- Operational misinterpretation: Administrators may misread Microsoft’s attestation as a negative guarantee for all Microsoft products. That misreading is dangerous: absence of attestation != absence of vulnerable code. The industry must still rely on artifact‑level verification.
- Scanner and database lag: Different CVE mirrors refresh at different cadences. Some tooling will keep surfacing the original CVE until databases are reconciled, causing alert fatigue and potential misprioritization.
- Application design risk remains: Even if the library is not changed, how applications use UI frameworks still matters. Unsafe rendering of user‑controlled content is a real XSS risk regardless of whether a library maintains sanitization responsibilities. The rescind clarifies responsibilities — it does not remove the underlying attack vector that poor input handling creates.
Conclusion — clear guidance for WindowsForum readers and admins
- Microsoft’s VEX/CSAF entry demonstrates the right kind of modern vendor transparency: it names Azure Linux (CBL‑Mariner lineage) as a product Microsoft checked and found to include the component, and it provides machine‑readable mapping so Azure Linux customers can act. That attestation is authoritative for those named artifacts.
- However, Azure Linux is not the only possible Microsoft artifact that might include the same upstream code. Other Microsoft‑shipped kernels, images, and appliances may carry the same files or embedded userland copies depending on build choices. Because Microsoft’s VEX rollout is phased and product‑by‑product, absence of a product name in VEX means “not yet attested,” not “definitively safe.” Verify other Microsoft artifacts via SBOMs, binary inspection, or wait for additional VEX attestations.
- Operationally, treat the VEX entry as a deterministic signal for Azure Linux, and treat other Microsoft products as requiring verification. Patch or remediate Azure Linux artifacts per Microsoft guidance, reconcile scanner noise with the rescind metadata, and continue to harden application‑level rendering and input handling to reduce XSS risk regardless of CVE status.
Following those steps will let security teams take advantage of Microsoft’s increasing supply‑chain transparency without falling victim to a false sense of security about un‑attested artifacts.
